No SSL cert setup here. I would PM @jpage4500 your device log after enabling debug mode -- hopefully he can help get it fixed.
Sent one with Https and one with http
From what you have said not sure he can as I wonder if it something with my hub.
I cannot connect using https either.
I see the error:
03/10 00:03:36 E HubitatManager fetchHsm: Exception:Read error: ssl=0xb4000073bb0cb018: Failure in SSL library, usually a protocol error error:10000410:SSL routines:OPENSSL_internal:SSLV3_ALERT_HANDSHAKE_FAILURE (external/boringssl/src/ssl/tls_record.cc:592 0xb4000074eb042810:0x00000003)
Is it a Pixel 7? That's what I have too.. now I'm even more confused. I remember when first working on this app I had issues with really old devices and https.. that's likely why I was using http by default.
Are you able to use the app remotely? If so, https is working but it's this specific Hubitat SSL certificate that's causing the issue.
I'll keep researching and figure something out.
Is there a way to tell the SSL engine to ignore certificate errors (only when in local mode)?
I wonder if it's related to the hub somehow, too. What model hub do the people who are having SSL trouble have?
Yes
Yes
See my PM
Edit I can now connect via HTTPS
Should I update to the latest revision or should I wait until all issues are solved out?
@jpage4500 I am confirming that the problem is solved with the new release -- thank you!
Marc
Is there a way to edit the stock button icons? I am using the gray push button on my dashboard for mute and I want to put the "mute" label on it.
Here's the image; you could edit it and put it on the Hub's filemanager and select it from there
If you having the same issue make sure you check your SSL certificate and if it's not working clear it out and reboot the hub.
HD+ can't connect via https or the web UI (or both)? I don't have that many test devices so if anyone does have issues with this latest update connecting can you let me know:
- can you view the web UI page on your PC via https (ie:
https://hubitat.local/)? - what device and OS are you running?
- if it's possible can you send me a device log (menu -> about -> support -> select email app and it should pre-fill my email in the to: field)
I'll look at ways to make it easier to switch between http and https (like the checkbox I had a while back).. if I can detect a SSL certificate issue than I can also try auto-switching too.
CORRECTION : YES!
Galaxy S20 Android version 13
What have I done? I cannot access remotely at all now.
Log sent.
Here's the image;
Thanks.
Now I cannot even log in remotely. Clearly I am doing something wrong.
I went back to version 1.0.2319 and all works well now.
Here's the cloud error - http:504 (gateway timeout)
03/10 15:04:54 E CustomInterceptor HTTP_ERROR: 11) http:504 10258ms https://cloud.hubitat.com/api/****/apps/445/devices, RESP:null
03/10 15:04:54 D HubitatManager fetchDevicesBrief:onFailure: error:code:504, msg:No response from hub
I don't see any other errors such as local only https traffic. The change I made shouldn't have any effect for cloud/remote traffic
Let me try to update now and see what happens.
