[RELEASE] HD+ - Android Dashboard
Just my $.02 but it seems like you're using some kind of mode where you're already using a gestures (swipe up) to show the navigation bar. I know Android is headed towards gesture only logic and it might be worth just trying that instead. I personally hated losing the always visible softkeys (MENU/BACK) initially but after some time I've gotten used to the new (iPhone-like) navigation.
Of course maybe I'm just missing something too.. there's a lot of different navigation methods across all Android devices. You could try turning off the "Full Screen" option which might just always show those softkeys on your device too (ie: removing the swipe up)
I've also run into this myself too.. I want to have 1 layout for my phone and use it on a test device but without the geofence logic. When developing this I remember wanting to restore the settings but not enable them (ie: you'd have all your locations setup but the feature would be disabled by default). That might not be working so I'll look. Would that help? I could also prompt what to import too but looking for keep things simple.
Possibly.. I'll add this to my list of http/s things I'm working on. It'd probably just be easier to switch to https completely but I'd like to know if any devices won't work with it first.
Are you trying to just have the video start without doing anything on the dashboard? This isn't exactly that but you can add a video tile and then change the icon to something fixed. That way the streaming won't start until you click on the tile to open it full-screen.
Or, something else you could do is put 1 or more streaming tiles in a folder.
For both of these options if you enable the Auto Return Home setting, the dashboard will return back to the homescreen after 1 minute (or configurable time)
It would be better than nothing, but I'd end up having to delete the locations manually, so I'd rather just have a list of categories that I can choose to import or skip.
What if you changed it to https by default, and if the initial connection attempt fails, automatically fall back to unsecure and set a flag so the app knows not to use https over local? This might be easier than my original suggestion.
Yes. Basically if someone presses the doorbell button, launch the RTSP video so I can see who's there without needing to launch the app on my phone.
I aware of the Auto Home. That was my request a couple years back. Which BTW, Thank You again for adding it.
EDIT: I guess this could be similar to how a motion controller device can wake the screen. If device X turns on, auto launch (press) the RTSP tile/URL. Then auto home can return it, or when the X device turns off.
I have made changes to devices but it then means manually updating all the devices with location so two options of update general and update geo would be good.
Then one person could update and you could restore it to everyone else and untick the geo so only the main update would take. Then you could backup that device again.
Hi @jpage4500, how's this for a possibility. The backup/restore file is easily editable since it's an un-encrypted text file. Could you re-org the text file to put all the unique location info into a separate section? That would make it easy to delete that section if you just wanted to have a template layout. Or you can copy/paste other user's location/presence data to make them a specific restore file?
Honestly, that's what I do for my family. If I make a layout change I backup all 3, with 1 of them being the new 'master' layout. Then I copy/paste the location stuff from the other 2 files into my new layout template. Then I restore those other 2 files. It's not hard but it is a couple of separate lines in the file and you need to know which ones. If they were grouped as location/presence' section that would make it easier.
Maybe that's a good compromise?
@jpage4500 Regarding this:
Another suggestion: is it possible to have the action when activating an Android Auto device automatically be the same as the action that's configured for the same device on the dashboard?
The Android Auto integration is a great concept, but in practice, it's just too complicated to use in a car. I don't want to tap here, tap there, pick a command while I'm driving. I just want to tap a device and know that it will send the command I want. The fewer taps you need to make while driving a car, the better.
On that note, I noticed something that's probably much easier to fix than this change that I suggested earlier and would accomplish the same goal: if there's a button device displayed in Android Auto, and that device only has a single button, don't prompt the user for which button they want to send -- just send "Button 1 pressed" when you tap the main icon in Android Auto.
Would that be possible?
That sounds reasonable. I think by default HD+ will toggle a light or switch but will prompt for sensitive devices like locks, valves or garage doors.. stuff you want to be deliberate with IMO.
btw - it's fine here but there is another HD+ AA thread if that's easier to track questions/suggestions
:point_up: +1
I’d definitely have a use for that feature if it was available.
@jpage4500 for some reason I am not able to change the icon of shortcut link. I tried creating a new shortcut and it has the same probem.
The screenshot below shows the icon that is showing up no matter what I select.
This only happens on my samsung galaxy s23+, which is on version 1.0.2410 of the HD+ app.
It isn't an issue on my samsung 8" tablet, which is on version 1.0.2379 of the HD+ app.
Thank you for any help you can provide.
Marc
bad icon
I see the problem and it'll be fixed in the next release
version 1.0.2422 (beta)
  • allow HD+ to be the default home screen
  • add activity monitor device type
  • support Hubitat Security (https) for Backup and Restore to Hub
  • default all local requests to using https
  • fix using custom custom image for shortcut tiles
LOTS of changes in this one.. as such there's always a chance for an issue or 2 so please let me know if you see anything.
First off, you can now set HD+ as the default home screen. This will prevent users from exiting the app so it could be useful for the wall mounted (Kiosk) tablets. HD+ can still open up other apps (such as app shortcut links) -- something the previous 'app pinning' logic couldn't do.
I'm not sure there's a way to directly prompt you to set HD+ as the default Home app but I can open the app preferences which is usually where this setting can be changed. You can open it from menu -> Security -> Default Launcher
Next up I changed the app to use https by default for all local requests. If for some reason https doesn't work (and let me know if it doesn't), you can switch back to http. If the app is already logged-in, open menu -> Hubitat Hub -> Hub Details and enter "http://HUB_IP" (see screenshot below).
If you're not logged in yet, there's a new checkbox in the login screen which you can uncheck to use http.
Related to https, I added support for Hub Login Security (username/password). If you try to do anything that requires a Hubitat Login, HD+ will prompt you for username & password. This should work for the auto login as well as backup and restore to the Hub features.
Lastly, I added a new device type, Activity Monitor. You can add it like any other HD+ tile (menu -> edit -> add tile (+ button) -> activity monitor.
I wanted something that supplements the Battery Monitor.. I noticed I have some devices that report battery = 0 but are still reporting events. I found the Device Activity Hubitat app but it didn't really work/display on the dashboard. What I'm doing is pretty simple for now -- it'll just display devices ordered by last activity time. If you notice some devices don't have anything listed for the time -- it's a bug (feature?) that I've asked about a few times in the past but no answers yet.
Anyway, I'm open to ideas how to make this more useful.. maybe combing it with battery info as a way to identify which devices need attention.
image ->
This would be doable but wasn't a design goal I had originally or a request that has ever come in since. If you can display variables, there could be some option to write something out to a string in whatever format would work.
getting a load of errors from this so need to go to Http. I would like to use it but need to now why it doesn't work.
one of the errors "unable to connect to server"
a thing to note, when i do discover hub i get can't get hub details.
No issues here.
can you connect to the hub standard web page using https:// ? i can't
That's strange.. I know I get a "not secure" warning in Brave/Chrome. I just noticed that the SSL cert expired on Apr 14, 2021 so that might be why the warning.
I don't know if there will be errors in the device log but if you enable debug mode, do some https actions and send a support log I can take a look.
Hopefully you're able to use http in the meantime
Yes- this works for me. After I log in, it displays my devices.
Do you have a SLL cert set up? I can't find any other settings that would suggest that it allows it to be turned on or off.
