add support to turn on screen with motion (front camera)
Done! This feature works when the screensaver is displayed. It uses the front facing camera to detect motion and will turn the screen back on.
For this to be enabled, you have to first grant CAMERA permission. I prompt for permission after you configure the screensaver timeout - in either of the 2 screens below:
@jpage4500 Heya...
Feature request if I may? I changed my theme today, on a whim to look at the current designs. My original settings were lost to the ethers. Is it possible that a 'user theme' can be kept? It would be nice to be able to reset layouts after an experimentation without doing a reload...
Not critical! Just gonna restore a backup. Happy to also report that custom Icons didn't get negatively affected - I just don't see a way to return the color choices if one wanted to abort a theme change.
@jpage4500 Well - YAFR - Yet another feature request.. This one could be deeply powerful - i've not yet explored it too far -
I saw that Mode Manager, in the logs, was showing 'Mode Manager - Morning'. I asked the community how that was done and learned that the app driver has the ability to dynamically modify the Label (and NaME!) of a device. Quick experimentation educated me that indeed, I can dynamically set the value, for example, of the Color Temperature of a lightbulb (for example) into the Device name. Also, importantly, I can put HTML into the name as well!
Here - for example is a CT bulb on my coffee table - dynamically showing its CT value, and dynamically showing the color as a background. This is very cool stuff I think! The log shows:
Potentially, I could customize the names, fonts, sizes, colors - maybe even embedded images (GULP!) (okay. that would just be stupid but... possible!)
Do you think you could push the title through the HTML parser you use? right now my result is this:
I used your app in the beginning and it's been getting better and better. The only thing holding me back from mounting a Kindle fire on my wall is disability to wake and sleep on its own. No other dashboard app seems to natively support this and if you can make it happen you've got a winner on your hands.
I do actually backup all of the device settings when you open the theme dialog and restore it if you hit 'cancel' and not 'ok', But, I checked and it's not still around after you hit OK so once you do that any custom icon color or background colors would be lost. Custom icons, device types, etc shouldn't be affected though.
Edit: an automatic backup wouldn't be a bad idea though.. my hope was you could see the theme applied when selecting the different options but just doing backups anytime a destructive change could be made would be good
Yeah, the Amazon Fire tablet specifically won't let an app turn off the screen fully and then back on again. It's because they don't let you remove the 'swipe' lock screen (which they use for ads). An app can turn the screen on but can't unlock it so it'll just go back to sleep after a short delay.
I have 2 rooted Fire tablets (10" and 7") which I replaced the FireOS with a more standard Android OS so I've never had a problem with the screen fully turning off at night and back on in the morning. But, that wasn't trivial to do so it'd be hard to recommend to others.
The next best option is to set a screensaver and the app will dim the screen as much as possible during 'off' hours and can turn it back on again when configured.
I also just implemented (and still testing on my Fire tablet) motion detection logic that will also wake the screen up. That can't be done if the screen is fully off and the device is asleep.
I'll try to update this support page more with that new option as well
Hi there @jpage4500 you asked about what I'm using the Fully Kiosk Browser app for. I recently bought a Pritom Tronpad L10 tablet to replace my old Samsung SM-T530NU that I was using with your Hubitat Dashboard app. The new tablet is currently sitting on a small shelf below where I plan to mount it to the wall at some point. To answer your question, I installed the Fully Kiosk app for two reasons:
I liked that the app was able to use the camera as a motion sensor to turn on the screen when you approach it and turn back off when no motion is detected.
I also liked the ability to use gif images as a slideshow screensaver when the screen turns off.
You mentioned you might be able to add the features I'm using natively to your app. These particular items would be great additions if you're able to include them. The only additional comment I'd add is it would be convenient to include a date and/or time on the screensaver.
I tried this out and found that I have to be much closer to the camera than I'd like so I decided to go back to the time range I used before but it won't let me. I set the screensaver timeout to 0 like it says and selected the time range as shown on the right in your post but no matter what I do it reverts back to Screensaver.
Hey Joe is it possible to create a folder that displays a list of devices like the battery level one? Reason is I have a ton of lights and honestly the folder with them all is just an ugly mess. A simple list would look nice and clean I think. Maybe a simple door that changes color like icons do it something that denotes the status.
I was wondering whether it would be possible to choose in settings whether we'd like the tile caption to be taken from Name or Label by default. Obviously still overridable by editing the caption in your app. The reason I am asking is due to the way the hub UI displays and sorts the devices in the device list. I had been putting the long descriptive names in the Name field, leaving the Label field to have short nicknames suitable for displaying in dashboards. But I can't sort on Name field in the device list. So I was wondering whether to do it the other way around and put the long more formal names in the Label field, and the friendly shorter names in the Name field. I have been asking for a long time whether they can allow sorting on the Name field but it is beginning to look like it won't happen. Just an idea, not asking you to actually do it at this stage
thanks for that! I'm still fine tuning using the camera to turn the device on but that one's getting close.
It also makes sense to add support for a date/time on the screensaver (it'd be optional as I imagine many people just want the screen to be as dark as possible). The slideshow isn't a bad idea either.. I personally love this Hubitat Google Photo's driver and I could see using it as a source of images or maybe a folder on the device
I also found out this didn't work at all on my 10" Fire tablet which was the only device I was planning on using this feature.. I haven't figured out why yet - I know it has a front-facing camera so I'll have to get that figured out.
Also, there's a few parameters I can tweak for the motion sensitivity. I've stuck with the defaults but I can try to make them available in the UI as well.
Hmm.. that's a good idea! I have 13 lights and I always use the 'group in folder' option after logging in to quickly create a folder with all of them so they don't clutter up the main dashboard. But, like you I don't really love trying to view a specific light in the folder either.
looking at the logic I'm using the first available value from: custom label, label (hub), name (hub)
I know when originally implementing this I was wondering which field to use first.. it might be easy to switch up with a setting - let me look into it further
I have 3 fire HD10 (2019) and HATE the fire OS, BUT I am going to root them!
What OS did you use? Lineage?
I have Lineage on my Samsung 10" in the car and don't have any complaints, but wanted to ask you about the Fire's.
Just updated the app on one of my Fire tablets and the screensaver camera control seems to be working GREAT! although I can tell the backlight is not turning off, just displaying a black screen.
I know the Fire tablets with the fire OS is crap and is the problem, but I still plan on rooting them, THEN it should work fantastic!!!
This app is REALLY turning into something VERY helpful and useful, and a great addition to Hubitat!
And YOU are one of the few developers that is taking a very active and responsive attitude to your app!
Thank You!
