Haozee Zwave 700 Mutlisensor
Driver for the Haozee Zwave 700 Multisensor. Senses motion, lux, temperature, humidity, tamper.
More info from Amazon:
https://www.amazon.com/700series-Detector-Temperature-Smartthing-Haozee/dp/B0923ZCZRH
NOTE 1: This driver was developed with the Haozee branded device. It may work on the Neo Coolcam version of the device, but I'm not sure as the parameter list appears to be different on the two devices - so the firmware may indeed be different.
NOTE 2: Like every other battery powered device, parameter changes are only made when the device wakes up! You can manually wake it up by pressing the button inside the device by the battery, or waiting until the scheduled wake up happens.
NOTE 3: When USB powered at pairing time, driver can update parameter settings immediately without waiting for wake up.
Features:
- All parameters supported (EXCEPT association related parameters!)
- Adjustable Reporting settings
- Temperature Delta
- Humidity Delta
- Lux Delta
- Time Interval Delta
- Motion Adjustments
- LED Adjustment (flash or no flash on motion)
- Adjustable Sensitivity
- Report on every motion event, or only 1x until motin clears
- "Blind" Time (time after inactive it ignores motion events to reduce # of events/save battery)
- Motion Clear Time
- Programmable Offsets
- Temperature
- Humidity
- Fingerprint added, so device should pick this driver when paired (if included w/S2 security, and if driver is installed before device is paired)
- Wakeup Interval set to 12 hours
- Battery updates every wakeup interval
To-Do:
- Consider adding the association parameters
- Consider adding the lux calibration setting
Installation:
- Install Driver code in Hubitat either by copy/paste from the GitHub location, or by importing the url: https://raw.githubusercontent.com/Botched1/Hubitat/master/Drivers/Haozee%20Zwave%20700%20Multisensor/Haozee%20Zwave%20700%20Multisensor.groovy
- Pair a new device, or on an already paired Haozee Zwave 700 Multisensor device change driver to "Haozee Zwave 700 Multisensor". Click save.
- Edit preferences, save preferences.
Driver can be found on my GitHub or Hubitat Package Manager
- 1.0.0 (05/23/2021) - Initial Version
- 1.0.1 (05/24/2021) - Fixed incorrect text on low battery event. Made motion event text more consistent.
- 1.0.2 (05/24/2021) - Fixed a parsing error when sending preferences to device
