Didn't work for me, it work on your hubitat?
Not tried yet mine is still in transit
This seems to work.
New drivers compatible with HE v 2.2.4 available. [Release] Generic Zigbee Drivers with Presence and Recovery - Markus Project - Oh-La LABS Community
Hi Markus,
I recently bought a LoraTap 3-gang Tuya switch:
The ic used in this device is TYZS3: https://developer.tuya.com/en/docs/iot/device-development/module/zigbee-module/tyzs-series-module/zigbeetyzs3ipexmodule?id=K989rjm3c1z55
Double press is on, long press is off. This works. With the switch driver.
Can I also use single press?
COPY AND PASTE THIS ROW TO THE DEVELOPER: fingerprint model:"TS0043", manufacturer:"_TZ3000_bi6lpsew", profileId:"0104", endpointId:"01", inClusters:"0000,000A,0001,0006", outClusters:"0019", application:"42"
This is the info from when de device was found:
Manufacturer: _TZ3000_bi6lpsew
Product Name:
Model Number: TS0043
deviceTypeId: 210
more...
manufacturer : _TZ3000_bi6lpsew
idAsInt : 1
inClusters : 0000,000A,0001,0006
endpointId : 01
profileId : 0104
application : 42
outClusters : 0019
initialized : true
model : TS0043
stage : 4
manufacturer :
idAsInt : 2
inClusters : 0001,0006
endpointId : 02
profileId : 0104
application :
outClusters :
initialized : true
model :
stage : 4
manufacturer :
idAsInt : 3
endpointId : 03
profileId : 0104
application :
outClusters :
initialized : true
model :
stage : 4
Do you think you can make the single press work also?
I hope this is enough info.
Thanks for all your hard work!
Markus isn't on the community anymore but check out this thread for a driver that works.
Thanks for the tip!
Go this in my log today, I can not recall if this is the right forum.
COPY AND PASTE THIS ROW TO THE DEVELOPER: fingerprint model:"3320-L", manufacturer:"CentraLite", profileId:"0104", endpointId:"01", inClusters:"0000,0001,0003,0020,0402,0500,0B05", outClusters:"0019"
It is not the right forum to send this to the developer. You need to go to the other forum as the developer no longer has access to this one. The link from this post earlier in this thread will bring you there, just go to “community”.
This is a standard iris v2 contact sensor, is there a reason you're not using the generic zigbee contact sensor driver we provide for this device?
Does it support presence & recovery?
Sensors that are standard ZHA1.2 should need neither.
I have some Iris sensors that have stayed online since March of 2019.
Yep, same here. Iris and Centralite aren't the ones that have issues in my experience. It was only my Xiaomi/Aqara that ever fell off the network, and since I have substantially improved my Zigbee mesh, I haven't had any dropoffs at all in probably a year now.
I don't think there is a need to use this driver over the built-in drivers at this point.
FYI to anyone,
This driver works great with this "MOES ZigBee Smart Plug Dual USB". The socket can be switched separately from the USB ports via the child devices.
Just tried this driver for my Osram Smart+ Outdoor Plugs. Works really fine! Have 5 plugs out of which only two has worked painlessly before, now only one is still giving me headaches. (Think it's because of placement without any good repeater, but that will have to be an issue for another day!) Big thanks!
Hi, Thanks for the drivers. Using them for a number of my devices .
Here's the fingerprint for a Samotech MS-104BZ dual switch:
fingerprint model:"TS011F", manufacturer:"_TZ3000_pmz6mjyu", profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,0006", outClusters:"0019,000A", application:"41"
And a Samotech MS-104Z switch:
fingerprint model:"TS0121", manufacturer:"_TYZB01_iuepbmpv", profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,0702,0B04", outClusters:"0019", application:"43"
And a Samotech SM314 dimmer:
fingerprint model:"Dimmer-Switch-ZB3.0", manufacturer:"Samotech", profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,0008,0B05,1000", outClusters:"0019", application:"03"
Thanks again!
Hi, to confirm, your driver for Generic Zigbee Outlet was a God Send!
I bought 2 ZBMini to replace a stupid fibaro dual relay to control my simple central heating (Heat/Water)
I though you may want the fingerprint from your Toolbox Driver:
dev:2262021-01-24 11:17:40.439 infoCOPY AND PASTE THIS ROW TO THE DEVELOPER: fingerprint model:"01MINIZB", manufacturer:"SONOFF", profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,1000", outClusters:"1000"
Many Thanks
can you make a driver for this
https://nedis.dk/da-dk/product/smart-living/smart-home/belysning/550735173/smart-fjernbetjening-zigbee-4-knapper-batteri-medfolger-hvid
the log is:
COPY AND PASTE THIS ROW TO THE DEVELOPER: fingerprint model:"TS0215A", manufacturer:"_TZ3000_fsiepnrh", profileId:"0104", endpointId:"01", inClusters:"0000,0001,0500,0501", outClusters:"0019,000A", application:"43"
The author of this driver is no longer active on this forum so I'm afraid your request will not get heard here.
too bad... anyone knows how to perhaps rewrite an existing 4 button driver with the above informations?
