Nevermind, i forked a driver myself for it
import hubitat.zigbee.zcl.DataType
metadata {
definition (name: "Nedis Zigbee 4 Button Fob", namespace: "Diondp", author: "Diondp") {
capability "PushableButton"
capability "Configuration"fingerprint inClusters: "0000,0001,0500,0501", outClusters: "0019,000A", manufacturer: "_TZ3000_fsiepnrh", model: "TS0215A" }
preferences {
input name: "debugEnable", type: "bool", title: "Enable debug logging", defaultValue: false
private sendButtonNumber() {
def remoteModel = device.getDataValue("model")
switch(remoteModel){
case "TS0215A":
sendEvent(name: "numberOfButtons", value: 4, isStateChange: true)
break
}def installed() {
sendButtonNumber()
state.start = now()
}def updated() {
sendButtonNumber()
}def refresh() {
// read battery level attributes
return zigbee.readAttribute(0x0001, 0x0020) + zigbee.configureReporting(0x0001, 0x0020, 0x20, 3600, 21600, 0x01)
// this device doesn't support 0021
zigbee.readAttribute(0x0001, 0x0021)
}def configure() {
sendButtonNumber()def configCmds = []
for (int endpoint=1; endpoint<=3; endpoint++) {
def list = ["0006", "0001", "0000","0500","0501"]
// the config to the switch
for (cluster in list) {
configCmds.add("zdo bind 0x${device.deviceNetworkId} 0x0${endpoint} 0x01 0x${cluster} {${device.zigbeeId}} {}")
return configCmds
}def parse(String description) {
if ((description?.startsWith("catchall:")) || (description?.startsWith("read attr -"))) { def parsedMap = zigbee.parseDescriptionAsMap(description) if (debugEnable){ log.debug("Message Map: '$parsedMap'") } name = "pushed" switch(parsedMap.data) { case "[00, 00, FF]": //button = "B" //WebCore friendly button = "4" break case "[01, 00, FF]": //button = "A" //WebCore friendly button = "3" break case "[03, 00, FF]": button = "1" break case "[]": button = "0" break } sendEvent(name: name, value: button, descriptionText: "Button $button was $name",isStateChange:true) } return
