New version on GitHub. Be sure to update all 3 parts.
Push upgrades, Added Priority Speaker features
Added to the list
Added to the list
New version on GitHub...
Parent and Child apps:
07/07/20 - Sounds Setup now in Parent App
Be sure to go into the parent app and setup your sounds!
New version on Github...
Driver:
2.2.3 - 07/10/20 - Added user selectable Priority colors
Be sure to go into the device and select your colors and then hit 'save'
Has anybody with multiple hubs tried to use Hubconnect to create a virtual "What Did I Say" device? I'm trying, but haven't got it working quite yet.
Use-case: I've put the WDIS tile on my tablet dashboards around the house (very high WAF). But I'd like the tile to capture announcements from all 3 hubs in home that have the Sonos connect app is installed. My thinking is that if I put a custom Hubconnect driver on the 2 of the hubs that shadows the actual WDIS device on my main hub (and I include the Follow Me device in announcements on the other hubs), then the tile will "catch" all announcements, independent of the hub from which they originate.
Would love any input or ideas.....or better ways to solve it?
All you need to do is 'share' the Follow Me device. Then select this device like you normally would on the other hubs to capture speech.
Ah, didn’t realize a plain SpeechSynthesis driver would work. I was trying to over-complicate with a custom driver. Now it’s so easy — damn, Bryan, you ruined my fun.
I did. Sorry, don't have github. BTW, no support. usage at your own risk.
http://www.apache.org/licenses/LICENSE-2.0
metadata
definition(name: "HubConnect zFollow Me Driver", namespace: "shackrat", author: "Alan Eisen")
capability "Initialize"
capability "Actuator"
capability "Speech Synthesis"
capability "Music Player"
capability "Notification"
capability "Refresh"
command "playAnnouncement", [[name:"Text*", type:"STRING", description:"Text to play"],
[name:"Volume Level", type:"NUMBER", description: "Volume level (0-100)"],
[name:"Restore Volume Level",type:"NUMBER", description: "Restore volume (0-100)"]]
command "playAnnouncement", [[name:"Text*", type: "STRING", description:"Text to play"],
[name:"Title*", type:"STRING", description: "Title to display on Echo Show devices"],
command "playAnnouncementAll", [[name:"Text*", type:"STRING", description:"Text to play"],
[name:"Title*", type:"STRING", description: "Title to display on Echo Show devices"]]
command "playTextAndRestore", [[name:"Text*", type:"STRING", description:"Text to play"]]
command "playTrackAndRestore", [[name:"Track URI*", type:"STRING", description:"URI/URL of track to play"]]
command "setVolume", [[name:"Volume Level*", type:"NUMBER", description: "Volume level (0-100)"]]
command "setVolumeSpeakAndRestore",
[[name:"Volume Level*", type:"NUMBER", description:"Volume level (0-100)"],
[name:"Text*", type:"STRING", description:"Text to speak"],
command "setVolumeAndSpeak", [[name:"Volume Level*", type:"NUMBER", description:"Volume level (0-100)"],
[name:"Text*", type:"STRING", description:"Text to speak"]]
command "sendFollowMeSpeaker", [[name:"Follow Me Request*", type:"JSON_OBJECT", description:"JSON-encoded command string (see source)"]]
command "sendQueue", ["string", "string", "string"]
command "updateVersion"
//command "deviceNotification", ["string"]
attribute "bpt-whatDidISay", "string"
attribute "whatDidISayCount", "string"
attribute "latestMessage", "string"
attribute "latestMessageDateTime", "string"
attribute "bpt-speakerStatus1", "string"
attribute "bpt-speakerStatus2", "string"
attribute "bpt-speakerStatus3", "string"
attribute "bpt-queue1", "string"
attribute "bpt-queue2", "string"
attribute "bpt-queue3", "string"
attribute "bpt-queue4", "string"
attribute "bpt-queue5", "string"
def setVersion(){
appName = "FollowMeDriver"
version = "v2.1.1"
dwInfo = "${appName}:${version}"
sendEvent(name: "dwDriverInfo", value: dwInfo, displayed: true)
def updateVersion() {
log.info "In updateVersion"
setVersion()
def deviceNotification(value)
parent.sendDeviceEvent(device.deviceNetworkId, "deviceNotification", value)
def playAnnouncement(String message, String title, volume=null, restoreVolume=null) {
parent.sendDeviceEvent(device.deviceNetworkId, "playAnnouncement", message, title, volume, restoreVolume)
def playAnnouncement(String message, volume=null, restoreVolume=null) {
parent.sendDeviceEvent(device.deviceNetworkId, "playAnnouncement", message, volume, restoreVolume)
def playAnnouncementAll(String message, title=null) {
parent.sendDeviceEvent(device.deviceNetworkId, "playAnnouncementAll", message, title)
def playText(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "playText", message)
def playTextAndRestore(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "playTextAndRestore", message)
def playTrack(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "playTrack", message)
def playTrackAndRestore(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "playTrackAndRestore", message)
def restoreTrack(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "restoreTrack", message)
def resumeTrack(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "resumeTrack", message)
def setTrack(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "setTrack", message)
def setVolume(volume) {
parent.sendDeviceEvent(device.deviceNetworkId, "setVolume", volume)
def setVolumeAndSpeak(volume, message) {
parent.sendDeviceEvent(device.deviceNetworkId, "setVolumeAndSpeak", volume, message)
def speak(message) {
parent.sendDeviceEvent(device.deviceNetworkId, "speak", message)
def sendFollowMeSpeaker(status) {
parent.sendDeviceEvent(device.deviceNetworkId, "sendFollowMeSpeaker", status)
def sendQueue(ps, theMessage, duration) {
def installed()
initialize()
updated
def updated()
initialize()
initialize
def initialize()
refresh()
refresh
def refresh()
// The server will update status
parent.sendDeviceEvent(device.deviceNetworkId, "refresh")
sync
def sync()
// The server will respond with updated status and details
parent.syncDevice(device.deviceNetworkId, "omnipurpose")
sendEvent([name: "version", value: "v${driverVersion.major}.${driverVersion.minor}.${driverVersion.build}"])
I am getting 10-15 second delay on all the devices selected in one child app, is that normal?
Side question if we want to use your other apps like the life360 tracker do we have to use follow me child devices or can we just use the devices directly?
No, everything should happen within a second or two.
All speech, from any of my apps, require Follow Me to work.
Wonder if anybody can help me configure Follow Me for the following use case. Been playing with it but just can't seem to get it right.
I want to use it ONLY to populate the What Did I Say (WDIS) tile on my dashboard, but not to send send speak commands to any speech/TTS device. In my many apps and rules, when I want to send a Speak command, I send the text directly to my Sonos and/or other TTS devices. Then I always include the WDIS proxy device as well so that every notification gets onto the tile.
This has resulted in some doublespeak lol. So I removed my Sonos device from the Follow Me configuration, but I'm still not sure I have it right. My config is below is that helps any.
P.S. I understand that FM is required for other BPTWorld apps that speak, but I planned to meet that need through a separate FM child app. Unless this is flawed logic for some reason I'm not appreciating.
Should just have to create a virtual device that uses the follow me driver. Then output to that device and there shouldn’t be any speech. The app isn’t necessary In your case.
Exactly.
Bryan, is there any way to delete the FM app without deleting the device?
Nope, they go hand and hand. If the app created it, then the app will delete it. This is so you don't end up with a bunch of orphaned devices
That's what I was afraid of. What button do I click to get your sympathies?
Hi - new to Hubitat (SmartThings recovering addict), so pardon my simple question...
I installed parent, child, and driver. However, I don't see my Google Home device when setting the app preferences. What do I need to do to have the GH show up?
Installing the Chromecast integration and choosing my Google Home devices there made them available in the Follow Me app...is that the "right" way to enable selection of the GH speakers in other apps?
Welcome to Hubitat!
Yes, to be able to use your Google devices with HE, you need to first setup Chromecast Integration.
2.2.7 - 08/08/20 - Working on the Queue, changes to playing sounds
@bptworld - I have 2.04 installed...what's the recommended way to update and not have to re-do anything? Can I just paste new code from GitHub into existing app code in HE, or ?
BTW, I just did another install from HPM, and it installed another instance of 2.04 alongside my existing 2.04 instance. Is the new version in HPM?
