I'd like to know if your stuff can help me with my use-case. I have a Carrier Infinity system, just so you know what thermostat I have. I have one room with three ceiling vents. What I want to do is simple. When the heat is running, close those vents, otherwise open the vents.
The new versions of MyPuckDevice (v2.5),MyFlairVent (v1.6) have been modified to expose the battery level based on the system voltage value returned by the Flair APIs.
If you are a contributor, just download the new code using the same selffy download link.
All you need to do is to copy &paste the new code over the existing device's code under the IDE and save.
Hi Newman - seems simple enough. I'm using the flair service manager app and the device handlers, but wrote my own programs to control the vents. You could easily do the same with Webcore or RM, assuming Hubitat can see the state of your thermostat. When thermostat in heating mode/state, close vents. If thermostat not in Hubitat, then still possible, but may require extra work to create a program that first detects the temp of the air coming through the vent, then closes them if hotter than X.
Nice, thanks! I imagine it won't be too hard for me to figure out how to get the list of schedules via a /api/structures/<home-id>/relationships/schedules API call. Let me know if I'm being naive. I'll try this out at some point in my spare time.
I just installed some Flair vents and they are working well to even out temperatures in my home. Now I am looking into integrating them into some automations and came across this plugin.
I am using an Ecobee thermostat and have Ecobee temp sensors throughout the house. I am letting the ecobee control the set point. The Flair puck is only functioning as a hub to connect the vents, but isn't used as a temp sensor or controller in any way.
Before the flair vents, I used a rule to turn off the HVAC when Windows/Doors were open and back to Auto HVAC heat/cool mode when all Windows/Doors close.
I would like to make that a little more advanced with the Flair vents. What I would like is if I open a door/window within a given room, I want the vent in that room to close, and then have that room excluded from the calculation for average temp with the HVAC set point.
Is something like that possible with this integration?
In order to create such automation, you'd need to use a rule engine (like RM or webcore) and create your own rules or use my zoning smartapp (ecobeeSetZoneWithSchedule) which already has some built-in automations with my own devices (flair, ecobee)
