[Release] Fibaro FGD-212, FGS-224, FGS-223 and FGS-222
After updating to the latest version of the code from cjcharles, the configuration button now caused the two child devices to show up. Everything is working perfectly now.
My changes wouldn't have helped with child device creation, but you would have seen 4 extra commands under the parent. All good hopefully
C7 hub 2.3.5.152, just installed as FGS 223. Using FGS 223 driver.
It created the 2 children (metering switch device). Physical buttons and device on/off working.
But there is no status update displayed in the device page.
No way to create a working tile for it on my dashboard.
I can select as new driver for the child and tried several which also did not work right.
Ideas?
The FGS-223 driver was modified by @cjcharles.
Please try to update the driver you are using to this driver and test again. Well, that is unless you are already using the updated version.
Summary
  • Copyright 2016 Eric Maycock and modified by cjcharles0
  • Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • Fibaro FGS-223 Double Switch 2
  • Author: Eric Maycock (erocm123)
metadata {
definition (name: "Fibaro Double Switch 2 FGS-223", namespace: "cjcharles0", author: "Eric Maycock and updated by Chris Charles") {
capability "Sensor"
capability "Actuator"
capability "Switch"
capability "Polling"
capability "Configuration"
capability "Refresh"
capability "Energy Meter"
capability "Power Meter"
capability "Health Check"
capability "PushableButton"
capability "HoldableButton"
command "reset"
command "componentOn"
command "componentOff"
command "componentRefresh"
command "componentReset"
fingerprint mfr: "010F", prod: "0203", model: "2000", deviceJoinName: "Fibaro Double Switch 2"
fingerprint mfr: "010F", prod: "0203", model: "1000", deviceJoinName: "Fibaro Double Switch 2"
fingerprint deviceId: "0x1001", inClusters:"0x5E,0x86,0x72,0x59,0x73,0x22,0x56,0x32,0x71,0x98,0x7A,0x25,0x5A,0x85,0x70,0x8E,0x60,0x75,0x5B"
simulator {
tiles(scale: 2){
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
		tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
		   attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
		   attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
		   attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
		   attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
        tileAttribute ("statusText", key: "SECONDARY_CONTROL") {
       		attributeState "statusText", label:'${currentValue}'
valueTile("power", "device.power", decoration: "flat", width: 2, height: 2) {
		state "default", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat", width: 2, height: 2) {
		state "default", label:'${currentValue} kWh'
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
	state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.needUpdate", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
        state "NO" , label:'', action:"configuration.configure", icon:"st.secondary.configure"
        state "YES", label:'', action:"configuration.configure", icon:"https://github.com/erocm123/SmartThingsPublic/raw/master/devicetypes/erocm123/qubino-flush-1d-relay.src/configure@2x.png"
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
	state "default", label:'reset kWh', action:"reset"
main(["switch"])
details(["switch",
         "refresh","reset","configure"])
preferences {
input description: "Once you change values on this page, the corner of the "configuration" icon will change orange until all configuration parameters are updated.", title: "Settings", displayDuringSetup: false, type: "paragraph", element: "paragraph"
generate_preferences(configuration_model())
private getCommandClassVersions() {
0x20: 1, // Basic
0x25: 1, // Switch Binary
0x70: 2, // Configuration
0x98: 1, // Security
0x60: 4, // Multi Channel
0x8E: 2, // Multi Channel Association
0x26: 1, // Switch Multilevel
0x87: 1, // Indicator
0x72: 2, // Manufacturer Specific
0x5B: 1, // Central Scene
0x32: 3, // Meter
0x85: 2, // Association
0x86: 1, // Version
0x9B: 1, // Association Command Configuration
0x90: 1, // Energy Production
0x73: 1, // Powerlevel
0x30: 1, // Sensor Binary
0x28: 1, // Switch Toggle Binary
0x2B: 1, // Scene Activation
0x75: 2 // Protection
//log.debug description
def result =
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result += zwaveEvent(cmd)
//log.debug "Parsed ${cmd} to ${result.inspect()}"
} else {
log.debug "Non-parsed event: ${description}"
def statusTextmsg = ""
result.each {
    if ((it instanceof Map) == true && it.find{ it.key == "name" }?.value == "power") {
        statusTextmsg = "${it.value} W ${device.currentValue('energy')? device.currentValue('energy') : "0"} kWh"
    if ((it instanceof Map) == true && it.find{ it.key == "name" }?.value == "energy") {
        statusTextmsg = "${device.currentValue('power')? device.currentValue('power') : "0"} W ${it.value} kWh"
if (statusTextmsg != "") sendEvent(name:"statusText", value:statusTextmsg, displayed:false)
return result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
log.debug "BasicReport $cmd"
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd, ep=null) {
logging("BasicSet: $cmd : Endpoint: $ep")
if (ep) {
def event
childDevices.each { childDevice ->
if (childDevice.deviceNetworkId == "$device.deviceNetworkId-ep$ep") {
childDevice.sendEvent(name: "switch", value: cmd.value ? "on" : "off")
if (cmd.value) {
event = [createEvent([name: "switch", value: "on"])]
} else {
def allOff = true
childDevices.each {
childDevice ->
if (childDevice.deviceNetworkId != "$device.deviceNetworkId-ep$ep")
if (childDevice.currentState("switch").value != "off") allOff = false
if (allOff) {
event = [createEvent([name: "switch", value: "off"])]
} else {
return event
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd, ep=null)
logging("SwitchBinaryReport: $cmd : Endpoint: $ep")
if (ep) {
def event
if (cmd.value) {
} else {
def allOff = true
childDevices.each {
childDevice ->
if (childDevice.currentState("switch")?.value != "off") allOff = false
if (allOff) {
} else {
return event
} else {
def cmds =
cmds << encap(zwave.switchBinaryV1.switchBinaryGet(), 1)
cmds << encap(zwave.switchBinaryV1.switchBinaryGet(), 2)
return response(commands(cmds)) // returns the result of reponse()
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd, ep=null) {
logging("MeterReport: $cmd : Endpoint: $ep")
def result
def cmds =
if (cmd.scale == 0) {
result = [name: "energy", value: cmd.scaledMeterValue, unit: "kWh"]
} else if (cmd.scale == 1) {
result = [name: "energy", value: cmd.scaledMeterValue, unit: "kVAh"]
} else {
result = [name: "power", value: cmd.scaledMeterValue, unit: "W"]
if (ep) {
def childDevice = childDevices.find{it.deviceNetworkId == "$device.deviceNetworkId-ep$ep"}
if (childDevice)
childDevice.sendEvent(result)
def combinedValue = 0.00
childDevices.each {
if(it.currentValue(result.name)) combinedValue += it.currentValue(result.name)
return createEvent([name: result.name, value: combinedValue])
} else {
(1..2).each { endpoint ->
cmds << encap(zwave.meterV2.meterGet(scale: 0), endpoint)
cmds << encap(zwave.meterV2.meterGet(scale: 2), endpoint)
def zwaveEvent(hubitat.zwave.commands.multichannelv4.MultiChannelCapabilityReport cmd)
//log.debug "multichannelv4.MultiChannelCapabilityReport $cmd"
if (cmd.endPoint == 2 ) {
def currstate = device.currentState("switch2").getValue()
if (currstate == "on")
sendEvent(name: "switch2", value: "off", isStateChange: true, display: false)
else if (currstate == "off")
sendEvent(name: "switch2", value: "on", isStateChange: true, display: false)
else if (cmd.endPoint == 1 ) {
def currstate = device.currentState("switch1").getValue()
sendEvent(name: "switch1", value: "off", isStateChange: true, display: false)
sendEvent(name: "switch1", value: "on", isStateChange: true, display: false)
def zwaveEvent(hubitat.zwave.commands.multichannelv4.MultiChannelCmdEncap cmd) {
//logging("MultiChannelCmdEncap ${cmd}")
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
log.debug "AssociationReport $cmd"
if (zwaveHubNodeId in cmd.nodeId) state."association${cmd.groupingIdentifier}" = true
else state."association${cmd.groupingIdentifier}" = false
def zwaveEvent(hubitat.zwave.commands.multichannelassociationv2.MultiChannelAssociationReport cmd) {
log.debug "MultiChannelAssociationReport $cmd"
if (cmd.groupingIdentifier == 1) {
if ([0,zwaveHubNodeId,0] == cmd.nodeId) state."associationMC${cmd.groupingIdentifier}" = true
else state."associationMC${cmd.groupingIdentifier}" = false
def zwaveEvent(hubitat.zwave.Command cmd) {
log.debug "Unhandled event $cmd"
// This will capture any commands not handled by other instances of zwaveEvent
// and is recommended for development so you can see every command the device sends
return createEvent(descriptionText: "${device.displayName}: ${cmd}")
def zwaveEvent(hubitat.zwave.commands.switchallv1.SwitchAllReport cmd) {
log.debug "SwitchAllReport $cmd"
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
update_current_properties(cmd)
logging("${device.displayName} parameter '${cmd.parameterNumber}' with a byte size of '${cmd.size}' is set to '${cmd2Integer(cmd.configurationValue)}'")
def refresh() {
def cmds =
cmds << encap(zwave.switchBinaryV1.switchBinaryGet(), endpoint)
commands(cmds, 1000)
def reset() {
logging("reset()")
def cmds =
cmds << encap(zwave.meterV2.meterReset(), endpoint)
def ping() {
def cmds =
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
def poll() {
def cmds =
def configure() {
state.enableDebugging = settings.enableDebugging
logging("Configuring Device For SmartThings Use")
def cmds =
cmds = update_needed_settings()
if (cmds != []) commands(cmds)
def zwaveEvent(hubitat.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
logging("CentralSceneNotification: $cmd")
logging("sceneNumber: $cmd.sceneNumber")
logging("sequenceNumber: $cmd.sequenceNumber")
logging("keyAttributes: $cmd.keyAttributes")
buttonEvent(cmd.keyAttributes + 1, (cmd.sceneNumber == 1? "pushed" : "held"))
def buttonEvent(button, value) {
logging("buttonEvent() Button:$button, Value:$value")
sendEvent(name: value, value: button, isStateChange:true)
def installed() {
def cmds = initialize()
if (cmds != ) commands(cmds)
def updated()
logging("updated() is being called")
sendEvent(name:"needUpdate", value: device.currentValue("needUpdate"), displayed:false, isStateChange: true)
def initialize() {
log.debug "initialize()"
if (!childDevices) {
createChildDevices()
else if (device.label != state.oldLabel) {
childDevices.each {
if (it.label == "${state.oldLabel} (S${channelNumber(it.deviceNetworkId)})") {
def newLabel = "${device.displayName} (S${channelNumber(it.deviceNetworkId)})"
it.setLabel(newLabel)
state.oldLabel = device.label
sendEvent(name: "checkInterval", value: 2 * 30 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
return update_needed_settings()
def on() {
commands([
encap(zwave.basicV1.basicSet(value: 0xFF), 1),
encap(zwave.basicV1.basicSet(value: 0xFF), 2)
def off() {
commands([
encap(zwave.basicV1.basicSet(value: 0x00), 1),
encap(zwave.basicV1.basicSet(value: 0x00), 2)
def componentOn(child) {
logging("componentOn(${child.deviceNetworkId})")
def cmds =
cmds << new hubitat.device.HubAction(command(encap(zwave.basicV1.basicSet(value: 0xFF), channelNumber(child.deviceNetworkId))), hubitat.device.Protocol.ZWAVE)
cmds
def componentOff(child) {
logging("componentOff(${child.deviceNetworkId})")
def cmds =
cmds << new hubitat.device.HubAction(command(encap(zwave.basicV1.basicSet(value: 0x00), channelNumber(child.deviceNetworkId))), hubitat.device.Protocol.ZWAVE)
cmds
def componentRefresh(child) {
logging("componentRefresh(${child.deviceNetworkId})")
def cmds =
cmds << new hubitat.device.HubAction(command(encap(zwave.switchBinaryV1.switchBinaryGet(), channelNumber(child.deviceNetworkId))), hubitat.device.Protocol.ZWAVE)
cmds << new hubitat.device.HubAction(command(encap(zwave.meterV2.meterGet(scale: 0), channelNumber(child.deviceNetworkId))), hubitat.device.Protocol.ZWAVE)
cmds << new hubitat.device.HubAction(command(encap(zwave.meterV2.meterGet(scale: 2), channelNumber(child.deviceNetworkId))), hubitat.device.Protocol.ZWAVE)
cmds
def childReset(child) {
logging("childReset(${child.deviceNetworkId})")
def cmds =
cmds << new hubitat.device.HubAction(command(encap(zwave.meterV2.meterReset(), channelNumber(child.deviceNetworkId))), hubitat.device.Protocol.ZWAVE)
cmds
private command(hubitat.zwave.Command cmd) {
if (state.sec) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
cmd.format()
private commands(commands, delay=1000) {
delayBetween(commands.collect{ command(it) }, delay)
private encap(cmd, endpoint) {
if (endpoint) {
zwave.multiChannelV4.multiChannelCmdEncap(destinationEndPoint:endpoint).encapsulate(cmd)
} else {
cmd
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
//log.debug cmd
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions) // can specify command class versions here like in zwave.parse
state.sec = 1
return zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def generate_preferences(configuration_model)
def configuration = new XmlSlurper().parseText(configuration_model)
configuration.Value.each
    switch(it.@type)
        case ["byte","short","four"]:
            input "${it.@index}", "number",
                title:"${it.@label}\n" + "${it.Help}",
                range: "${it.@min}..${it.@max}",
                defaultValue: "${it.@value}"
        break
        case "list":
            def items = []
            it.Item.each { items << ["${it.@value}":"${it.@label}"] }
            input "${it.@index}", "enum",
                defaultValue: "${it.@value}",
                options: items
        break
        case "decimal":
           input "${it.@index}", "decimal",
        break
        case "boolean":
           input "${it.@index}", "bool",
                title: it.@label != "" ? "${it.@label}\n" + "${it.Help}" : "" + "${it.Help}",
        break
        case "paragraph":
           input title: "${it.@label}",
                description: "${it.Help}",
                type: "paragraph",
        break
def update_current_properties(cmd)
def currentProperties = state.currentProperties ?: [:]
currentProperties."${cmd.parameterNumber}" = cmd.configurationValue
if (settings."${cmd.parameterNumber}" != null)
    if (convertParam(cmd.parameterNumber, settings."${cmd.parameterNumber}") == cmd2Integer(cmd.configurationValue))
        sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
    else
        sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
state.currentProperties = currentProperties
def update_needed_settings()
def cmds =
def configuration = new XmlSlurper().parseText(configuration_model())
def isUpdateNeeded = "NO"
sendEvent(name:"numberOfButtons", value:"5")
if(!state.associationMC1) {
   logging("Adding MultiChannel association group 1")
   cmds << zwave.associationV2.associationRemove(groupingIdentifier: 1, nodeId: [])
   //cmds << zwave.associationV2.associationGet(groupingIdentifier: 1)
   cmds << zwave.multiChannelAssociationV2.multiChannelAssociationSet(groupingIdentifier: 1, nodeId: [0,zwaveHubNodeId,0])
   cmds << zwave.multiChannelAssociationV2.multiChannelAssociationGet(groupingIdentifier: 1)
if(state.association2){
   logging("Removing association group 2")
   cmds << zwave.associationV2.associationRemove(groupingIdentifier:2, nodeId:zwaveHubNodeId)
   cmds << zwave.associationV2.associationGet(groupingIdentifier:2)
if(state.association4){
   logging("Removing association group 4")
   cmds << zwave.associationV2.associationRemove(groupingIdentifier:4, nodeId:zwaveHubNodeId)
   cmds << zwave.associationV2.associationGet(groupingIdentifier:4)
    if ("${it.@setting_type}" == "zwave"){
        if (currentProperties."${it.@index}" == null)
            isUpdateNeeded = "YES"
            logging("Current value of parameter ${it.@index} is unknown")
            cmds << zwave.configurationV1.configurationGet(parameterNumber: it.@index.toInteger())
        else if (settings."${it.@index}" != null && cmd2Integer(currentProperties."${it.@index}") != convertParam(it.@index.toInteger(), settings."${it.@index}"))
            logging("Parameter ${it.@index} will be updated to " + convertParam(it.@index.toInteger(), settings."${it.@index}"))
            def convertedConfigurationValue = convertParam(it.@index.toInteger(), settings."${it.@index}")
            cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(convertedConfigurationValue, it.@byteSize.toInteger()), parameterNumber: it.@index.toInteger(), size: it.@byteSize.toInteger())
sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
return cmds
def convertParam(number, value) {
def parValue
switch (number){
case 28:
parValue = (value == true ? 1 : 0)
parValue += (settings."fc_2" == true ? 2 : 0)
parValue += (settings."fc_3" == true ? 4 : 0)
parValue += (settings."fc_4" == true ? 8 : 0)
log.debug parValue
break
case 29:
parValue += (settings."sc_2" == true ? 2 : 0)
parValue += (settings."sc_3" == true ? 4 : 0)
parValue += (settings."sc_4" == true ? 8 : 0)
break
default:
parValue = value
break
return parValue.toInteger()
private def logging(message) {
if (state.enableDebugging == null || state.enableDebugging == true) log.debug "$message"
  • Convert 1 and 2 bytes values to integer
    def cmd2Integer(array) {
switch(array.size()) {
case 1:
array[0]
break
case 2:
((array[0] & 0xFF) << 8) | (array[1] & 0xFF)
break
case 3:
((array[0] & 0xFF) << 16) | ((array[1] & 0xFF) << 8) | (array[2] & 0xFF)
break
case 4:
((array[0] & 0xFF) << 24) | ((array[1] & 0xFF) << 16) | ((array[2] & 0xFF) << 8) | (array[3] & 0xFF)
break
def integer2Cmd(value, size) {
switch(size) {
case 1:
[value]
break
case 2:
def short value1 = value & 0xFF
def short value2 = (value >> 8) & 0xFF
[value2, value1]
break
case 3:
def short value3 = (value >> 16) & 0xFF
[value3, value2, value1]
break
case 4:
def short value4 = (value >> 24) & 0xFF
[value4, value3, value2, value1]
break
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def encapsulatedCommand = zwave.getCommand(cmd.commandClass, cmd.command, cmd.data,1)
} else {
log.warn "Unable to extract CRC16 command from ${cmd}"
private channelNumber(String dni) {
dni.split("-ep")[-1] as Integer
private void createChildDevices() {
try {
for (i in 1..2) {
addChildDevice("hubitat", "Generic Component Switch", "${device.deviceNetworkId}-ep${i}",
[completedSetup: true, label: "${device.displayName} (S${i})",
isComponent: false, componentName: "ep$i", componentLabel: "Switch $i"])
} catch (e) {
runIn(2, "sendAlert")
private sendAlert() {
sendEvent(
descriptionText: "Child device creation failed.",
eventType: "ALERT",
value: "failed",
displayed: true,
def configuration_model()
The device will return to the last state before power failure.
0 - the Dimmer 2 does not save the state before a power failure, it returns to the "off" position
1 - the Dimmer 2 restores its state before power failure
Range: 0~1
Default: 1 (Previous State)
This parameter allows you to choose the operating mode for the 1st channel controlled by the S1 switch.
Range: 0~5
Default: 0 (Standard)
This parameter determines how the device in timed mode reacts to pushing the switch connected to the S1 terminal.
Range: 0~2
Default: 0 (Cancel)
This parameter allows to set time parameter used in timed modes.
Range: 0~32000 (0.1s, 1-32000s)
Default: 50
This parameter allows to set time of switching to opposite state in flashing mode.
Range: 1~32000 (0.1s-3200.0s)
Default: 5 (0.5s)
This parameter allows you to choose the operating mode for the 2nd channel controlled by the S2 switch.
Range: 0~5
This parameter determines how the device in timed mode reacts to pushing the switch connected to the S2 terminal.
Range: 0~2
Default: 0 (Cancel)
Default: 50
Default: 5 (0.5s)
Choose between momentary and toggle switch.
Range: 0~2
Default: 2 (Toggle)
This parameter determines how the device will react to General Alarm frame.
Range: 0~3
Default: 3 (Flash)
This parameter determines how the device will react to Flood Alarm frame.
Range: 0~3
Default: 2 (OFF)
This parameter determines how the device will react to CO, CO2 or Smoke frame.
Range: 0~3
Default: 3 (Flash)
This parameter determines how the device will react to Heat Alarm frame.
Range: 0~3
Default: 1 (ON)
This parameter allows to set duration of flashing alarm mode.
Range: 1~32000 (1s-32000s)
Default: 600 (10 min)
The parameter defines the power level change that will result in a new power report being sent. The value is a percentage of the previous report.
Range: 0~100 (1-100%)
Default: 10
Parameter 51 defines a time period between consecutive reports. Timer is reset and counted from zero after each report.
Range: 0~120 (1-120s)
Default: 10
Energy level change which will result in sending a new energy report.
Range: 0~32000 (0.01-320 kWh)
Default: 100
Default: 10
Parameter 55 defines a time period between consecutive reports. Timer is reset and counted from zero after each report.
Default: 10
Default: 100
This parameter determines in what time interval the periodic power reports are sent to the main controller.
Range: 0~32000 (1-32000s)
Default: 3600
This parameter determines in what time interval the periodic energy reports are sent to the main controller.
Default: 3600
Send scene ID on single press
Send scene ID on double press
Send scene ID on tripple press
Send scene ID on hold and release
Toggle Mode
1 pushed - S1 1x toggle
4 pushed - S1 2x toggle
5 pushed - S1 3x toggle
1 held - S2 1x toggle
4 held - S2 2x toggle
5 held - S2 3x toggle
Momentary Mode
1 pushed - S1 1x click
2 pushed - S1 release
3 pushed - S1 hold
4 pushed - S1 2x click
5 pushed - S1 3x click
1 held - S2 1x click
2 held - S2 release
3 held - S2 hold
4 held - S2 2x click
5 held - S2 3x click
And make sure the device is looking like this:
When you say "No way to create a working tile for it on my dashboard" what do you mean? you should be able (after adding the child devices to the dashboard app) to create a switch tile for each child.
Yes, I should be able to create a tile. The child id same as you show. "Generic component switch" driver is used. Creating a tile only shows a "?" on the tile and does not work.
Can you give me the URL of this driver? Then I will double check it.
@cjcharles created this thread and the information needed to obtain their version of the driver is in the original post.
Hi,
I have a Fibaro FGS-214, which is similar to the FGS-224 but only a single relay. My main aim with this device is power monitoring. I tried this driver as well as some of the built-in Fibaro drivers. The best I could get is relay on/off, but no power monitoring.
Does anyone have suggestions for other drivers to try? Or for a way for this driver to work with the FGS-214? I'm happy to provide more details and test changes.
And I've just realized the FG-214 doesn't support power monitoring, in spite of what the retailers web page says about it. Never mind everybody. I'll let the retailer know.
That's right. The older FGS-213 and FGS-223 (Fibaro Switch 2/Fibaro Double Switch 2) have power monitoring. The newer FGS-214 and FGS-224 (Fibaro Smart/Double Smart) don't have power monitoring. I'm not sure why, I don't use it much myself but it seems a bit of a backward step. The Fibaro outlets have power monitoring.
Just beginning to learn the ropes of dashboards. Reason I’m posting here is because my question relates to functionality of the Fibaro double switch and the Fibaro dimmer in dashboard. Is there a way to show power meter data of these devices in dashboard? Any and all help very much appreciated :pray:
Make sure the device is assigned to the dashboard.
Add a new tile to your dashboard and select the Attribute tile template.
You can then choose the relevant attribute you want.
Note that this will allow you to add the power (for example) in a seperate tile than the Switch itself.
If you want it on the same tile (layout wise) you can use two tiles one on top of the other.
The Fibaro Dimmer 2 doesn't give power data so you won't get it for those. Likewise while the Fibaro Switch 2 supports power monitoring, the new version (Fibaro Smart/Double Smart) that seems to have replaced it does not support it.
Thank you. I’ll try. Will the hub support power metering for this even though it’s added using a 3rd party app?
What do you mean by 3rd party app? If you mean that you are using a driver that was developed by the comunity then the answer is .......it depends on the dirver itself. Most if not all Fibaro switchs report power and if the driver was writen to support this feature than it will show in Hubitat.
If you have the exact driver name this can be checked.
It's this driver from the package manager * Fibaro Double Switch 2 FGS-223 Documentation | Community Thread | Donate
  • Fibaro Double Switch 2 FGS-223 v1.04 (driver)
Please may someone help me? i'm keen to get power metering with this on a dashboard and also it's touch and go whether or not the 'dumb' switches will power on/off when toggled. Any help much appreciated.
This driver does support power metering.
In my previous reply I explanied how you can present the power metering on the dashboard.
If it not help please explain what else is required.
Ah, thank you. I will try that next time I’m at the setup. I’m sorry I missed it before.
Do you know how to make the ‘dumb’ switches responsive? Sometimes they need to be toggled on then off to work.
