Having an issue with this driver, can't update config, therefore can't pull data.
IRIS IL03_1 plugs according to the back, data from device page as follows:
- endpointId: 01
- application:
- softwareBuild:
- inClusters: 0000,0003,0006,0402,0B05,FC01,FC02
- outClusters: 0003,0019
- model: 1113-S
- manufacturer: iMagic by GreatStar
Tracing logs show the following:
dev:2792020-02-03 12:38:02.430 am errorPOWER REPORTING CONFIG FAILED- error code:134
dev:2792020-02-03 12:38:02.427 am traceParsed data... Evt: [:], msg: [raw:catchall: 0104 0B04 01 01 0040 00 EDB7 00 00 0000 07 01 86000505, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EDB7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 05, 05]]
dev:2792020-02-03 12:38:02.420 am traceMsg: Description is catchall: 0104 0B04 01 01 0040 00 EDB7 00 00 0000 07 01 86000505
dev:2792020-02-03 12:38:00.406 am debugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x00, data: [0x0b, 0x00], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0xedb7, isClusterSpecific: false, sourceEndpoint: 0x00, profileId: 0x0000, command: 0x00, clusterId: 0x8021, destinationEndpoint: 0x00, options: 0x0040)
dev:2792020-02-03 12:38:00.402 am warnDID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 EDB7 00 00 0000 00 00 0B00
dev:2792020-02-03 12:38:00.399 am traceParsed data... Evt: [:], msg: [raw:catchall: 0000 8021 00 00 0040 00 EDB7 00 00 0000 00 00 0B00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:EDB7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0B, 00]]
dev:2792020-02-03 12:38:00.383 am traceMsg: Description is catchall: 0000 8021 00 00 0040 00 EDB7 00 00 0000 00 00 0B00
dev:2792020-02-03 12:37:58.405 am errorPOWER REPORTING CONFIG FAILED- error code:134 dev:2792020-02-03 12:38:02.430 am errorPOWER REPORTING CONFIG FAILED- error code:134
Any Ideas?
