Yes the Heroku was through the destructions on the app install. 5 bucks lighter we are re-educated on that front, so yes exploring the server/PC approach. I have a Plex server on an older Win11(home) laptop and that works fine and thru Echo too. I switch off and on external access as and when I want to use it for music.
I do have another Win10 that cannot be upgraded to Win 11, it is an older I7 laptop so I may well go down the Linux road there. I will test out using Docker for the local server, which to be honest makes me happier than cloud.
If you search âecho speaksâ in the forum, there are posts regarding how to setup the ES server in a docker container. I couldnât get it working properly with docker for Windows, but it was easy to get working with Ubuntu, even though I was a Ubuntu virgin. Once I had that set up, I figured that I might as well install Pi-Hole, the NTP server, and move over my Homebridge server.
Its not bad using docker for windows, pretty much the same commands as linux, just have to run from command prompt. Only catch is on Windows a bridged connection is not supported so you have to set the host IP with the environment variable to get it to work right. I documented the commands to get it going somewhere in one of these multiple threads about it.
i'm trying to get the docker container running on my raspberry pi through Portainer, but having some trouble and not totally sure which of the many guides in these forums i should be using.
when i setup a container from the docker hub tonesto7/echo-speaks-server and run it, i get this error: "exec /usr/local/bin/docker-entrypoint.sh: exec format error". is that because the architecture for that image is amd64 and my pi is armv7?
I have a Realtek RTD1296 AMR Cortex-A53 processor in my QNAP NAS and cannot get Echo Speaks to run on that as I also get the exec format error message.
Very new to docker so I am guessing the same as you that this is not compatible with our specific processors. Hopefully someone here will tell us otherwise and help withour installations???
Iâve been somewhat learning docker through a few other services, but I do think the architecture is the issue. That image is only good for one platform (amd64 for linux x86-64) which is not ARM like we both have.
I think we have to build our own docker images, which we can do using the provided docker file from the GitHub repo.
I did that, using the 2.8.0 tonesto7 version, and deployed the container successfully in a portainer stack using the docker-compose script from TonyF (but it didnât like the volume path so I commented that out.) my config page did show as working, but it also showed a second IP of 10.6.0.1 which is what I see in the logs even though I specified 192.168.1.x in the config, and I think thatâs why i still canât get the app to work yet.
unfortunately the tonesto7 image is the wrong architecture for my pi and that container won't run.
i used docker build to create my own image, which does run, but i'm seeing this in the logs when it starts:
IP Address: 192.168.1.99
IP Address: 10.6.0.1
1-20-2023 - 3:58:59am error: Config Check Did Not Pass
1-20-2023 - 3:58:59am info: ** Echo Speaks Config Service (v2.8.0) is Running at (IP: 10.6.0.1 | Port: 8091) | ProcessId: 1 **
1-20-2023 - 3:58:59am info: ** On Heroku: (false) **
1-20-2023 - 3:58:59am info: Checking for Server Version Updates...
the first IP is the host, and the second IP i think is related to my VPN which also runs on my host. i'm guessing this has something to do with me using network_mode: host ? should i try to use a bridge network for this container instead?
Set the ENV Variable 'ipAddress' to the correct IP.
You can just prepend ipAddress=192.168.1.99 on the same line before whatever command you use to start the container. May also want to toss a --restart=always in there also at the end.
i'm actually using portainer stacks which i find make it much easier to make quick adjustments and redeploy
version: "3"
services:
echo-speaks-server-arm:
# local arm image I built
image: echo-speaks-server:latest
container_name: echo-speaks-server-arm
restart: unless-stopped
network_mode: host
environment:
- ipAddress=192.168.1.99
ports:
- "8091:8091"
# I keep getting stack errors if this is uncommented
# volumes:
# - './data:mnt/es-data'
however I was using "IPADDRESS" instead of "ipAddress". In changing that, the logs no longer show the incorrect 10.x.x.x address anymore.
also, i was able to get my cookie, but the app still doesnt seem to show me as logged in properly. is this where people were saying they need to reboot?
edit: i rebooted, but the cookie disappeared, presumably because my container doesnt have persistent storage setup. not quite sure why that part isnt working. if i can figure that out, then i''ll publish my image on dockerhub for other arm users.
anyway, after logging in again, it works and i can now see my devices!
edit2: the error i get when deploying tonesto's 2.8.0 image is:
failed to deploy a stack:
Network echo-speaks-server-arm_default
Creating Network echo-speaks-server-arm_default
Created Container echo-speaks-server-arm
Creating Error response from daemon:
invalid volume specification: '/data/compose/30/data:mnt/es-data:rw':
invalid mount config for type "bind":
invalid mount path: 'mnt/es-data' mount path must be absolute
but i dont get that error with TonyFleischer's 2.7.2 image. i know there are some differences between the repos, so maybe Tony added something to his to make that volume work? i dont understand enough about these volumes and how they should be configured
@tonesto7 the process.exit code in the update mentioned is the cause of the issue with the container stopping after several days of running. Commenting out that code has kept the container running after a cookie refresh. I can manage the restart if the container in NodeRed for now but curious your thoughts here with adding code to restart vs stop the container after cookie refresh.
i was able to get the stack to start by removing "mnt" altogether which i guess makes that an absolute path within the container and does what the error message was asking for. didn't need to adjust the local volume path, but seems like that could be useful to move it to somewhere more intuitive to find.
i have no idea yet if these changes will bork something else or if these paths are completely arbitrary.
that said, i uploaded my armv7 images to docker hub last night for both TonyFleischer's 2.7.2 and tonesto7's 2.8.0. i was able to get both of these to work.
the easiest way for me to spin these up is with portainer stacks using docker compose. this simplicity works as long as the image matches the host's architecture (i'm using a Pi4 with raspi os buster). otherwise you'll have to build the images yourself
version: "3"
services:
echo-speaks-server:
# uncomment one image line for your desired architecture. steinauf:armv7; tonesto7:amd64
image: steinauf/echo-speaks-server:2.8.0
# image: tonesto7/echo-speaks-server:latest
environment:
# replace X.X.X.X with your host IP
- hubPlatform=Hubitat
- IPAddressOverride=X.X.X.X
- HOME=/es-data
- ipAddress=X.X.X.X
ports:
- "8091:8091"
volumes:
# Data persistency
- './data:/es-data'
I'm open to suggestions on the general workflow, as well as any efficiency improvements/corrections i could make.
I had to reinstall the app since I had stopped using it since it stopped working with alexa. then discovered I can do a local server, got it setup and running and working, This app found my devices, howver it will not create them, cookie is current and shows im online with amazon.
but it gets the following error...i cant tell what file it cant find...any suggestions?
0:/echo-speaks-server-docker-enablement/docker# docker-compose build
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/lib/python3/dist-packages/docker/transport/unixconn.py", line 30, in connect
sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 718, in reraise
raise value.with_traceback(tb)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/lib/python3/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/lib/python3/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "/usr/bin/docker-compose", line 33, in <module>
sys.exit(load_entry_point('docker-compose==1.29.2', 'console_scripts', 'docker-compose')())
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 200, in perform_command
project = project_from_options('.', options)
File "/usr/lib/python3/dist-packages/compose/cli/command.py", line 60, in project_from_options
return get_project(
File "/usr/lib/python3/dist-packages/compose/cli/command.py", line 152, in get_project
client = get_client(
File "/usr/lib/python3/dist-packages/compose/cli/docker_client.py", line 41, in get_client
client = docker_client(
File "/usr/lib/python3/dist-packages/compose/cli/docker_client.py", line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 197, in __init__
self._version = self._retrieve_server_version()
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
root@e39b349655c0:/echo-speaks-server-docker-enablement/docker#
