Thank you.
Just upgraded and went back into the app to save those pages again.
I am still seeing an error - looks a bit different now. Do you suggest I restart the hub?
[app:1488](http://hubitat.local/logs#app1488)2021-11-19 09:47:42.675 am [error](http://hubitat.local/installedapp/configure/1488)groovy.lang.MissingMethodException: No signature of method: user_app_BPTWorld_Device_Check_Plus_Child_291.clearPresenceMap() is applicable for argument types: () values: [] on line 1140 (method checkDeviceHandler)
I read the discussion in the HPM thread and I still didn't see a clear announcement. If you saying we need to stop using HPM for (some or all of) your apps, you should make a clear statement to that effect.
Doing the Un-match just tells HPM to forget about the existing package. I did that and the result is DCP is no longer listed in HPM anywhere.
(This is not a complaint! I appreciate all you do and contribute)
You might want to put that this statement that Bundle Manager is needed in the thread for each of your apps.
I do see you put the message inside the apps, however - thanks for that!
I wasn't interested in the beta of Bundle Manager, so I did not subscribe to that thread when you started it. That you've now edited the first post after the fact doesn't make this easier to find.
Hi Bryan - is it possible to make the delay before sending notifications configurable ? I created a child to be triggered by Mode changing to Sleep. It checks various switches and tries to change them to the appropriate value. However, it ends up sending me a notification of devices being in the room mode, even though they end up in the right mode just a few seconds later. Those include the switches that Device Check should be correcting.
It seems that an additional 30 sec pause before sending the notification would probably fix the problem - so if you had a setting for how long to wait that would be great. I'm not sure why the switches are not immediately set to the right value by Device Check Plus - but it's clear that less than a minute later they end up in the right place.
I see that jlv's comment back in April 21 never got a response, but I've run into the same thing. It seems that DCP does not have a means to check the conditions after a delay. It's going to check immediately when the trigger event happens. I also thought Device TIme in State was meant to address this but instead it just causes repeated triggers as long as that condition is still true.
I'm assuming that the only way to address this need is to create a virtual trigger and then use Rule Machine to watch for the real trigger, wait for the delay time and then trigger DCP to do its checks.
Would be great to have this delay option between the initial trigger and the beginning of DCP checks.
It would also be great to have a configurable delay between the triggering of DCP and sending notifications, as described in my previous post. (That only makes sense if DCP has been configured to try fixing switches that are wrong).
Combining those:
DCP trigger event
Delay 1
DCP checks conditions
DCP tries to fix switches that are wrong
Delay 2
DCP sends notification if anything is still wrong
I ended up building my solution using RM (to give me the delay after the check), a virtual switch, and the app Device Status Announcer (to give me a nicely worded announcement). I can detail those if there is interest, but they are off topic for this thread as I no longer use DCP.
