New version on GitHub...
1.2.0 - 12/03/20 - Bug fixes
Hey @bptworld, any chance you could have a look at my suggestions above about the notification text? Thank you so much for the great app!
Added to the list
1.2.1 - 12/04/20 - Pre and Post messages are now optional, new option to include App name in push, new option to include device status in message
That was quick! Thank you so much!
By the way, I tried the new device status in message and I don't think it's working. The notification is the same with or without it
Always, always, always post a debug log when reporting issues. ![]()
Are we talking push or voice, both? Which type of devices?
This is why I need a debug log. ![]()
I get the exact same message if I check the device status message. Here is the log with the option turned on:
1.2.2 - 12/04/20 - Adjustments
Thank you, it works now!
Sorry for being picky, but if you don't have any pre message selected and you deselect the show app name at the start from the notification, it always starts with a blank space. Could that be removed?
I attached a screenshot of my notification with the space in the beginning
Edit:
The issue in my case is in line 1117 of the child app, since a space is added before each device type. Is there a way of checking if the Msg starts with a space and then just remove it?
New version...
1.2.3 - 12/04/20 - Removed spacing in message
Thanks! That fixed it!!
TL/DR: I'm trying to get a notification when a window is left open for 5 minutes and my HVAC goes on. Instead, I get an instant notification that doesn't follow the HVAC at all. See "The Problems" below.
_
I'm testing setting up DCP to notify me if I have doors or windows open when my HVAC goes on.
Right now, I use a webCoRE piston to do this on ST, but I'm getting ready to move all those devices over to my Hubitat. I am looking to not use webCoRE or RuleMachine to accomplish this (since the rule will be complicated).
It looks like DCP should do this, but it's not working the way I expected.
I created a number of virtual contact sensors to test this out with and configured an instance of DCP to monitor them. I'm using my actual thermostat device in the app.
What I'd like to be able to do is simple: if a door or window is open for 5 minutes while the HVAC, send a notification. Only send the notification in that case. If the HVAC is running and I open a door, wait 5 minutes before sending the notification. E.g., I might have needed to open the window to refill the bird feeder; I only want to know if the contact has been left open too long.
The settings in Select Devices are simple:
The settings in Notification Options are just to send a push (and an email). That works.
The only other settings are in Select Trigger. I've tried several different settings here.
The Problems:
As long as "Device State as Trigger" is turned on, I'm find I get a notification the instant I "open" one of the virtual contact sensors.
As long as "Device Time in State as Trigger" is turned on, I get a notification 5 minutes after I "open" one of the virtual contact sensors. And it seems to repeat every 5 minutes.
Both of these happen no matter what is going on with the HVAC. Neither settings for "Use Mode or State" affect this.
The thermostat device is the one from [RELEASE] Universal Ecobee Suite, Version 1.8.01, but I had similar behavior using a virtual thermostat device (I switched to the real thing thinking the virtual one wasn't working).
I can collect and post debug logs if that's helpful. But am I just using this wrong?
Give the new version on GitHub a try.
That's definitely working better. But it looks like the "Device Time in State as Trigger" doesn't work in conjunction with the "Device State as Trigger".
E.g., I want a notification if a contact has been left open 5 minutes after the HVAC is running.
Right now, it looks like these are separate checks. I'm getting a notification after 5 minutes of any of the contacts open. I'm also getting a notification if any of the contacts are open and the HVAC goes on.
Just found this and installed, amazing app thank you so much!
New version...
Adjusted speak() to reflect the new parameters.
Be sure to also update Follow Me.
I have constant issues with all scenes completing correctly. I've tried metering, disabled optimization, anything I can think of.
This looks like a great app to monitor and 'fix' devices. I know I can create child app for each scene with all devices but wondering if there's a more efficient method to check scenes specifically.
Any suggestions for this use case? Thanks in advance!
Hi @bptworld - Since i upgraded to the latest Hubitat release, this app has been throwing a groovy exception so I have lost my ability to receive messages with the status.
It looks like everything still works as expected up to the message creation per my logs;
Any idea on what I need to do to fix that?
1.2.6 - 11/19/21 - Fix for speech
