[Release] BWA Spa Manager (Cloud Control & Direct Local TCP)
These two Hubitat applications allow one to connect to a network-connected spa, which is equipped with a:
NOTE: You can disconnect the terminal block to make it easier to work with.
Plug everything in and confirm you can access the EW11's web interface.
I drilled a small hole in the bottom of the hot tub's plastic media device enclosure, routed the cable in, and stashed the EW11 in there. The media pocket has the added benefit of being unshielded, unlike the rest of the tub, which has foil insulation.
Configure EW11 Web Interface
  1. Set a static ip address for the EW11 in your home network router and verify your EW11 has this static address on the EW11 Status Home Page.
  2. Set the EW11 listening port to 4257
  3. Set the IP address and port in the parent device driver's preferences section, and save the page.
  4. Issue the parent devices drivers' "Configure' command and verify that the State Variables displayed show your spa's accessory configuration.
Integrate your spa Balboa BP Control System WiFi Module or Elfin EW11 to the Hubitat environment with the following features:
  1. View real-time temperature
  2. Set the spa's clock time to the same as the Hubitat Hub.
  3. Set heatingSetPoint temperature
  4. Turn on/off lights and pumps
  5. Set & automate High/Low & Rest/Ready modes to reduce energy usage
  6. Control spa using Hubitat's Rules/WebCore
  7. Set temperature scale (°F|°C)
  8. Integrated HTML table showing spa status
Choose from one type of connection below for spa control:
1. Cloud Control App & Drivers (Legacy)
  • The Hubitat Hub indirectly connects to the Control System WiFi Module via the internet BWA Cloud Server.
    • The BWA Cloud server often loses connection to the Control System WiFi Module, which makes this app unreliable,
  • Requires Spa Control - BWA mobile app for spa configuration and access.
    • Download the app from Apple/Google app stores and create a username and password.
    • Install app/drivers using HPM.
2. Direct Local TCP Drivers (New)
  • The Hubitat Hub connects directly to either the Spa Control System WiFi Module or Elfin-ew11 RS-485 via the home network.
  • Since the Hubitat Hub creates a raw TCP socket directly to the Spa Control System WiFi Module, this parent driver provides a fast & robust connection.
  • The Spa's WiFi module must be on the same network as the Hubitat hub.
  • Requires Spa Control - BWA mobile app for spa network configuration and access.
    • Install parent driver using HPM.
  • Creates several child device virtual switches to refresh spa status & control the spa's pumps, lights, heat mode (Ready/Rest), and heat range (high/low).
Version Notes on GitHub
Connection Type Version Release Date
Cloud Version 2.0.2 Mar-11-2025
Local Version 2.2.0 May-27-2026
Please be advised that this latest release, with all these new features, may introduce some unwanted bugs that we hope to identify and correct. Each spa has a different configuration (e.g., pumps, lights, blowers, misters, etc.), so I can only test on my BullFrog A7L model. If your current release of BWA Spa Manager is working and you are completely satisfied, I would suggest you not overwrite your working release and install this on a separate hub (if you have multiple hubs).
New 'BWA Spa Manager - Local' Version Announcement
  • A new Spa Manager App - Local installation starter app is now part of the application suite to help users with the initial install the required drivers below.
  • The new app will also assist {optionally} to rename the spa's parent driver.
  • Spa parent device child switches are automatically created when the app is first installed.
HPM Install/Upgrade FAQs:
New Installs:
  • Install via HPM are highly recommended. Search for BWA Spa Manager and select the BWA Spa Manager - Local App version.
Previous Versions of this App:
  • If you try to upgrade a previous version via HPM and notice that your hub has multiple versions of the device drivers or libraries listed below, use HPM to uninstall the app.
  • If HPM displays an error with removing this app, use HPM's 'Package Manager Settings' option and then select ' Un-Match a Package to make HPM remove any of it's cached information of the previous versions of this app.
  • Check the hub's drivers code and library code views for residual files listed below, If they exists, manually delete ALL/ANY of the application's drivers, app and libraries files that might still be installed. This will allow HPM to install as a fresh new install.
  • Perform a new install via HPM. Search for BWA Spa Manager and select the Local version to install. HPM will automatically launch the Application and create the required spa control devices.
'BWA Spa Manager - Local' TCP Control Application Files
Filename Type Version
BWA Spa Manager App - Local.groovy App Version 0.0.4
Balboa Hot Tub Local Driver.groovy Parent Device Driver Version 0.0.4
Balboa Hot Tub Local Child Switch.groovy Child Device Driver Version 0.0.4
Balboa-Hot-Tub-API-Library.groovy App Library Version 0.0.4
SanderSoft-Library.groovy Main Library Version 0.0.5
BWA Spa Manager - Local Application Installation Screen
Hi Kurt - first, thank you for the work you put into this. I just got around to updating ~ not sure what version I was running previous but I'm now running into an issue with child devices and hoping you might be able to help. My pumps are single-speed only so they only respond to on/off... if I change them to binary switches they work fine but as soon polling runs they revert back. I also tried the local driver and pumps don't get discovered at all (the only child objects that show up are Heat Mode and Temp Range.
Oh, sorry to hear that. I'm guessing that the app is not checking for the pump speeds in the cloud based version of this app and assumes a Low, High, Off, like my Bullfrog A7.
Just curious, is your Balboa controlled spa on the same home network as your hubitat hub? If so, have you tried the newer 'BWA Spa Manager - Local TCP Direct Connection' in HPM. It does not use the cloud for control and accesses the spa direct for control.
oh yes - I guess I didnt say that correctly, when I said I tried the local driver - I meant the new App with Local direct connection. When it discovers the child objects it doesn't see any pumps at all just finds
The new Balboa Hot Tub Local Parent Device Driver has an On/Off' switch attribute that when activated (for example via a dashboard, WebCore or Rule), will turn on all "detected" spa pumps and lights for you to prepare the spa for one's pleasure. The child device switches are for individual spa controls for the dashboard.
The Balboa Hot Tub Local Parent Device Driver also has some "commands" to cycle spa pumps through their speeds, set the spa's internal clock to the time on the hub, etc....
OK that is different than what I'm used to / was expecting - I did see where I could turn everything on from the parent.
Let me know if this version works for you. I have been using this local version of the Balboa Spa app for sometime. It works better/faster than the original cloud control version.
I still get random WiFi Spa Module disconnects from my Netgear Orbi system. It appears that Balboa's WiFi controller is prone to these and re-connects after a small amount of time.
Here is a chart of the Spa WiFi's disconnects (black) and Online (Green) below:
The parent driver tracks Online/Offline as Present/Not Present attribute
I don't use any dashboards - so the real advantage to me was the Alexa integration - being able to say "Alexa, turn on spa pump 1" or "turn on spa lights" - I can't figure out how to do that with local integration - since when I added it just configures the parent with just one on/off... even if a rename it to something other than Balboa Hot Tub Local Driver :slight_smile: it just turns on all the pumps but not the lights
This parent and child devices will work with Alexa for voice control. You just need to add those devices and switches to Amazon Alexa Skill so that Alexa can gain access to them.
Suggestions:
  • Create a virtual switch and use Hubitat Rules to turn on and off the pumps and lights you chose with the parent devices commands.
  • Create Alexa Routines to automate several spa controls, like "Alex, turn on the Spa Lights" and/or "Alexa Turn on the spa pumps" and these can control the virtual switch which activates a Hubitat Rule to send commands to the parent driver.
The next version of this app , I will add child switches for control of pumps on/off and lights on/off. It will take a few days or more to add these. Thanks for the suggestions.
I was incorrect, the spa lights do not turn on with the parent On/Off switch, it only controls the pumps. I will add lights to this parent switch so that lights and pumps all turn on or off.
Please clarify if this also works with balboa’s ControlMySpa controller. Is there another app that can bring it into Hubitat?
I cannot confirm since I do not have balboa’s ControlMySpa on my Bulfrog/Balboa spa. It will not hurt to add either the cloud or local control via HPM and see if it integrates to Hubitat. If not, simply remove the app from Hubitat.
I think I observed that Home Assistant (HA) can integrate balboa’s ControlMySpa. If you are technical, you could set up HA and integrate HA --> Hubitat.
the mobile app is all together different and not compatible with the Balboa Water Group 50350-07 WI-FI Module (the ControlMySpa has its own sort of gateway/hub vs just connecting to wifi directly) so I would say its very unlikely the integration will work
I set my tub settings to Celsius through the BWA Spa Control app, but it breaks this integration in a few places:
  • the input validation seems hard coded to F: Heating setpoint temperature from 55°F-104°F *(NUMBER)
  • The Temperature Scale variable is set/read as C correctly, but a lot of other vars (Heating Setpoint, Thermostat Setpoint, Temperature) get stuck at 80, even though others seem to be working correctly, e.g. TTSmessage: Your spa is currently at 40.0°C and is ready heating to 40.0°C.
Looking at the code, it seems like the temperatureScale variable is mostly just used for formatting? I don't see much logic for temperature conversion.
I haven't had anyone test the Celsius program's logic, and it clearly needs work on the support side. You've been so helpful in diagnosing the temperature-related issues.
It is true that I convert everything to °F or temperature control as described in the device's setting description. I was thinking that users who prefer Celsius could mentally convert to Fahrenheit when they enter temperature values.
@stefan2718
I have created an updated BWA Local Control version 1.0.0 that supports switching between Fahrenheit and Celsius temperature scales, as well as reflects the spa's temperature scale in the device attributes.
Note: The BWA cloud control app has not been updated and is no longer supported.
BWA Spa Manager Local Direct Control - Version 1.0.0 (Nov-24-2025)
  • Updated Interface Documentation to show the new Elfin EW11 RS485 Interface option. This low-cost option, IMHO, is economical, stable, and configurable via the EW11 WebPage.
  • REQUIRES HPM v1.9.3 or higher for HPM install or update.
    • New driver feature for setting and handling temperature scales.
    • Added new formatted temperature attributes with a suffix of the current temperature scale.
    • Added new advanced device parameters for spa communications.
BWA Spa Manager App - Local.groovy App Version 1.0.0
Balboa Hot Tub Local Driver.groovy Parent Device Driver Version 1.0.0
Balboa Hot Tub Local Child Switch.groovy Child Device Driver Version 1.0.0
Balboa-Hot-Tub-API-Library.groovy App Library Version 1.0.0
SanderSoft-Library.groovy Main Library Version 0.0.7
Hi again... it's been a while. Truth be told I gave up on the newer version last spring and reverted to one of your older (pre HPM package) versions from github that worked just great for me. Well Balboa has gone and broken the cloud version by forcing a subscription so local seems ideal. I can install and configure. My controller and hub are both on static IP, same network and the app sees the spa but I'm lost trying to get to actually work. :frowning:
FWIW I have a ton of the same error over and over:
Dear @kenrok1
I have interfaced my balboa spa controller to the Elfin EW11 RS485 which has been rock solid TCP interface as opposed to the Balboa Spa WiFi Controller interface controller which dropped network connectivity randomly for me and many others that have it installed. See the post above abut another interface option. The Elfin EW11 RS485 device was not difficult to install to the same 4 wire that connects to the OEM Balboa Spa Cloud Controller. I highly recommend it if your OEM WiFi Spa controller is as flaky as mine.
I will see if I can look at the app errors that you are receiving, but I doubt that I will be able to make it work as reliably as the other Elfin RS485 interface from AliExpress.
Did you try the parent device’s ‘Configure’ command? This function should determine if the HE device driver can successfully TCP/IP connect & query your spa’s configuration and return number and state of pumps, temp, heat state, etc…. This needs to complete and be accurate to run the Spa controller functions of my App.
Update: I have successfully connected my OEM Balboa WiFi Spa Controller to HE using my Balboa Local Spa app. Once it connected and I pressed ‘Configure’ in the device, it has been refreshing as long as the WiFi Spa controller stays connected to the local home network. I am looking into the red error on line 855 which is probably due to a corrupted TCP packet received from the Spa controller board.
Hi thanks for looking into this- yes I did the configure and it does read them in that they’re showing in the “Spa configuration” state variables
And if i hit On or Off in the parent everything turns on / off so there is communication- I just seem to be missing the specific control for the individual pumps or lights
In the local device driver, there is a preference setting to create the individual control child switches. Did you set this so that they are created?
