For what it's worth, the Resideo (new name, same crappy support) servers seem to be at least partially down. I'm unable to log in. I did run across a link to the server status page: Resideo Status
Hello Guys ,
I use this app with T10. When I set the unit to Celsius in the App, I get Celsius readings for the thermostat, but not for the remote sensors. All readings for the remote sensors are in Fahrenheit. Is there away to modify this app to have Celsius for the remote sensors?
I am very new to this. Just installed Hubitat and connected z wave devices to it. I have a situation where I( have to use Honeywell D6 Pro (split system). For the life of me I can not figure out how to connect and run this WiFi thermostat from Hubitat. I downloaded the driver and app into Hubitat. When I am trying to create a thermostat with the specified driver, it is not asking me for anything like IP or MAC. It just creates a thermostat that is not connected to anything.
Can you help me out with the steps of what I need to do. Really appreciate any help.
Because you are new, I just want to make sure that beyond downloading the code, you're Adding them, right? You will go into the Apps menu item on the left and click Add User App
Then find/select the new app and it will then appear in the list of apps. Then you use that to set the IP, etc.
Again, it's not always clear what "install" means when it gets done twice.. one to add the code and then again to make the code active.
If you haven't installed (and made active ) Hubitat Package Manager (HPM), then I'd suggest you review it for its value. Its purpose is to do all the fetch/download of code.. all the pieces, as one "package". You simply select the name of the Package and finds the code and installs all the apps all the drivers, all the libraries, and so on. You then proceed to using the code, installing it
You may not be familiar with importing code...
use this Import URL: https://raw.githubusercontent.com/HubitatCommunity/hubitatpackagemanager/main/apps/Package_Manager.groovy
In Apps Code, click Import, paste the URL above and click Import. Then go to Apps and again, use the Add User App and find Hubitat Package Manager.
I have a D6 WiFi thermostat that connect through a cloud App to Hubitat (I think that is how it works). When I am editing a dashboard it does not show up as a device I can place on the dashboard. I can only see my T6 z wave thermostat and other devices but not a D6 thermostat.
