Hi,
Installed my pf1, with the latest driver. it looks OK,it was detected, but it looks like I can't facilitate it.
I have added a tile to the dashboard "with "Motion" template, but it doesn't become green, whatever I do,
In the logs I can't see anything important:
dev:15702023-01-19 22:27:32.619debugחיישן תנועה סלון sending ZigbeeCommands : [he wattr 0x1F56 0x01 0xFCC0 0x010C 0x20 {03} {115F}, delay 200, he wattr 0x1F56 0x01 0xFCC0 0x0146 0x20 {03} {115F}, delay 200, he wattr 0x1F56 0x01 0xFCC0 0x0144 0x20 {00} {115F}, delay 200]
dev:15702023-01-19 22:27:32.616debugחיישן תנועה סלון setting monitoringMode to undirected (0)
dev:15702023-01-19 22:27:32.613debugחיישן תנועה סלון setting approachDistance to near (3)
dev:15702023-01-19 22:27:32.607debugחיישן תנועה סלון setting motionSensitivity to High (3)
dev:15702023-01-19 22:27:32.605infoחיישן תנועה סלון Debug logging is will be turned off after 24 hours
dev:15702023-01-19 22:27:32.537infoחיישן תנועה סלון Debug logging is true; Description text logging is true
dev:15702023-01-19 22:27:32.534infoחיישן תנועה סלון Updating Presence Saloon model lumi.motion.ac01 manufacturer aqara (driver version 1.2.2 2022/08/21 9:01 AM)
dev:15702023-01-19 22:19:41.094debugPresence Saloon sending ZigbeeCommands : [he wattr 0x1F56 0x01 0xFCC0 0x010C 0x20 {03} {115F}, delay 200, he wattr 0x1F56 0x01 0xFCC0 0x0146 0x20 {01} {115F}, delay 200, he wattr 0x1F56 0x01 0xFCC0 0x0144 0x20 {00} {115F}, delay 200]
dev:15702023-01-19 22:19:41.091debugPresence Saloon setting monitoringMode to undirected (0)
dev:15702023-01-19 22:19:41.087debugPresence Saloon setting approachDistance to far (1)
dev:15702023-01-19 22:19:41.082debugPresence Saloon setting motionSensitivity to High (3)
dev:15702023-01-19 22:19:41.075infoPresence Saloon Debug logging is will be turned off after 24 hours
dev:15702023-01-19 22:19:41.035infoPresence Saloon Debug logging is true; Description text logging is true
dev:15702023-01-19 22:19:41.032infoPresence Saloon Updating Aqara FP1 Presence Sensor RTCZCGQ11LM model lumi.motion.ac01 manufacturer aqara (driver version 1.2.2 2022/08/21 9:01 AM)
dev:15702023-01-19 22:19:27.321debugPresence Saloon sending ZigbeeCommands : [he raw 0x1F56 1 0x01 0xFCC0 {04 5F 11 00 00 0C 01 42 01 44 01 46 01}, delay 200]
dev:15702023-01-19 22:19:27.315warnaqaraReadAttributes() FP1
dev:15702023-01-19 22:18:57.287warnPresence Saloon if no more logs, please pair the device again to HE!
dev:15702023-01-19 22:18:57.188infoPresence Saloon device model lumi.motion.ac01 manufacturer aqara deviceName was set to Aqara FP1 Presence Sensor RTCZCGQ11LM
dev:15702023-01-19 22:18:57.172infoPresence Saloon InitializeVars... fullInit = true (driver version 1.2.2 2022/08/21 9:01 AM)
dev:15702023-01-19 22:18:57.148infoPresence Saloon configure...(driver version 1.2.2 2022/08/21 9:01 AM)
dev:15702023-01-19 22:18:32.759infoPresence Saloon Received ZCL Default Response to Command 02 for cluster:FCC0 , data=[02, 80] (Status: Failure)
dev:15702023-01-19 22:18:32.752debugPresence Saloon parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 1F56 00 00 0000 0B 01 0280, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1F56, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[02, 80]]
What am I doing wrong? how can it be used?
How do you create automation with it?
