[RELEASE] Aqara (B1) Smart Curtain Motor (ZNCLDJ11LM & ZNCLDJ12LM) Driver
// B1 100%:
msgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
// B1 60% ????:
// B1 0%
msgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
@claytonelliott it looks like the attribute sent is only if the curtain is open or closed. Not the percentage. There is probably a different attribute I need to read. I've made a change to see if it's available in cluster 0x0102 as is indicated in packet captures I found for your curtain type.
Please install the new driver from the repo. With debug mode on, run the same as before: open, close, setposition 60, but also setposition 46.
For the battery, please leave debugging on and wait for an hour or two and see if you get anything in the logs with the battery data.
EDIT: Driver updated, please test with the latest version.
OPEN WORKS
CLOSE WORKS
SET 60 WORKS
SET 46 WORKS
LOG:
dev:72020-04-19 01:59:16.250 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:16.244 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:59:16.241 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:59:16.239 pm debugPARSE START---------------------
dev:72020-04-19 01:59:16.228 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:16.221 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:59:16.218 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:59:16.216 pm debugPARSE START---------------------
dev:72020-04-19 01:59:16.066 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:16.053 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:16.052 pm debugGETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-19 01:59:16.050 pm debugcluster 000D
dev:72020-04-19 01:59:16.046 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:59:16.045 pm debugGETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-19 01:59:16.042 pm debugcluster 000D
dev:72020-04-19 01:59:16.040 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-19 01:59:16.038 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:59:16.038 pm debugPARSE START---------------------
dev:72020-04-19 01:59:16.032 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-19 01:59:16.030 pm debugPARSE START---------------------
dev:72020-04-19 01:59:11.775 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:11.768 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-19 01:59:11.764 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-19 01:59:11.760 pm debugPARSE START---------------------
dev:72020-04-19 01:59:11.557 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:11.551 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:59:11.547 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:59:11.545 pm debugPARSE START---------------------
dev:72020-04-19 01:59:11.533 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42380000} {}, delay 2000]
dev:72020-04-19 01:59:11.524 pm debugSet Position: 46%
dev:72020-04-19 01:59:11.518 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:11.514 pm debugsetPosition(position: 46)
dev:72020-04-19 01:59:11.512 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:59:11.509 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:59:11.506 pm debugPARSE START---------------------
dev:72020-04-19 01:59:11.371 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:11.362 pm debugGETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-19 01:59:11.358 pm debugcluster 000D
dev:72020-04-19 01:59:11.351 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:59:11.351 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:11.347 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-19 01:59:11.344 pm debugPARSE START---------------------
dev:72020-04-19 01:59:11.343 pm debugGETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-19 01:59:11.341 pm debugcluster 000D
dev:72020-04-19 01:59:11.337 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:59:11.332 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-19 01:59:11.329 pm debugPARSE START---------------------
dev:72020-04-19 01:59:01.113 pm debugPARSE END-----------------------
dev:72020-04-19 01:59:01.106 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-19 01:59:01.102 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-19 01:59:01.099 pm debugPARSE START---------------------
dev:72020-04-19 01:59:00.829 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42700000} {}, delay 2000]
dev:72020-04-19 01:59:00.823 pm debugSet Position: 60%
dev:72020-04-19 01:59:00.812 pm debugsetPosition(position: 60)
dev:72020-04-19 01:58:58.393 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:58.387 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:58:58.383 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:58:58.381 pm debugPARSE START---------------------
dev:72020-04-19 01:58:58.365 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:58.359 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:58:58.355 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:58:58.353 pm debugPARSE START---------------------
dev:72020-04-19 01:58:58.206 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:58.196 pm debugGETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-19 01:58:58.187 pm debugcluster 000D
dev:72020-04-19 01:58:58.183 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:58:58.183 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:58.176 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-19 01:58:58.173 pm debugPARSE START---------------------
dev:72020-04-19 01:58:58.172 pm debugGETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-19 01:58:58.170 pm debugcluster 000D
dev:72020-04-19 01:58:58.165 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:58:58.159 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-19 01:58:58.156 pm debugPARSE START---------------------
dev:72020-04-19 01:58:44.017 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:44.011 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:58:44.006 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:58:44.003 pm debugPARSE START---------------------
dev:72020-04-19 01:58:41.900 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:41.893 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-19 01:58:41.890 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-19 01:58:41.887 pm debugPARSE START---------------------
dev:72020-04-19 01:58:41.873 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:41.860 pm debugmsgMap: [raw:catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01 , profileId:0104, clusterId:0102, clusterInt:258, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:]
dev:72020-04-19 01:58:41.856 pm debugParsing: catchall: 0104 0102 01 01 0040 00 E85F 00 00 0000 01 01
dev:72020-04-19 01:58:41.854 pm debugPARSE START---------------------
dev:72020-04-19 01:58:41.724 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:41.712 pm debugGETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-19 01:58:41.710 pm debugcluster 000D
dev:72020-04-19 01:58:41.705 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:58:41.699 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:41.697 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {00000000} {}, delay 2000]
dev:72020-04-19 01:58:41.696 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-19 01:58:41.694 pm debugPARSE START---------------------
dev:72020-04-19 01:58:41.693 pm debugSet Position: 0%
dev:72020-04-19 01:58:41.690 pm debugGETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-19 01:58:41.687 pm debugcluster 000D
dev:72020-04-19 01:58:41.682 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-19 01:58:41.673 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-19 01:58:41.673 pm debugsetPosition(position: 0)
dev:72020-04-19 01:58:41.671 pm debugclose()
dev:72020-04-19 01:58:41.670 pm debugPARSE START---------------------
dev:72020-04-19 01:58:25.532 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:25.522 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-19 01:58:25.517 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-19 01:58:25.514 pm debugPARSE START---------------------
dev:72020-04-19 01:58:25.323 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42C80000} {}, delay 2000]
dev:72020-04-19 01:58:25.318 pm debugSet Position: 100%
dev:72020-04-19 01:58:25.304 pm debugsetPosition(position: 100)
dev:72020-04-19 01:58:25.301 pm debugopen()
dev:72020-04-19 01:58:22.672 pm debugPARSE END-----------------------
dev:72020-04-19 01:58:22.665 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CE5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CE5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CE, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 01:58:22.659 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CE5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CE, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 01:58:22.653 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CE5FE84C3F753CDF8CCF0484
dev:72020-04-19 01:58:22.650 pm debugPARSE START---------------------
dev:72020-04-19 01:58:19.813 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42C80000} {}, delay 2000]
dev:72020-04-19 01:58:19.807 pm debugSet Position: 100%
dev:72020-04-19 01:58:19.795 pm debugsetPosition(position: 100)
dev:72020-04-19 01:58:19.792 pm debugopen()
dev:72020-04-19 01:58:14.259 pm debugrefresh() model='lumi.curtain.hagl04'
dev:72020-04-19 01:58:14.231 pm infoinitialize()
dev:72020-04-19 01:58:14.228 pm debugupdated()
AND HERE'S THE LOG OF THE FEW HOURS AFTER TESTING:
dev:72020-04-19 05:31:16.745 pm debugPARSE END-----------------------
dev:72020-04-19 05:31:16.739 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EE5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EE5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EE, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 05:31:16.735 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EE5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EE, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 05:31:16.729 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EE5FE84C3F753CDF8CCF0484
dev:72020-04-19 05:31:16.726 pm debugPARSE START---------------------
dev:72020-04-19 05:05:52.778 pm debugPARSE END-----------------------
dev:72020-04-19 05:05:52.769 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 ED5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 ED5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[ED, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 05:05:52.763 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 ED5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[ED, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 05:05:52.758 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 ED5FE84C3F753CDF8CCF0484
dev:72020-04-19 05:05:52.755 pm debugPARSE START---------------------
dev:72020-04-19 05:05:44.179 pm debugPARSE END-----------------------
dev:72020-04-19 05:05:44.171 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EC5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EC5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EC, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 05:05:44.165 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EC5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EC, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 05:05:44.161 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EC5FE84C3F753CDF8CCF0484
dev:72020-04-19 05:05:44.158 pm debugPARSE START---------------------
dev:72020-04-19 03:17:11.675 pm debugPARSE END-----------------------
dev:72020-04-19 03:17:11.670 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EB5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EB5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EB, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 03:17:11.666 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EB5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EB, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 03:17:11.661 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EB5FE84C3F753CDF8CCF0484
dev:72020-04-19 03:17:11.658 pm debugPARSE START---------------------
dev:72020-04-19 03:08:04.914 pm debugPARSE END-----------------------
dev:72020-04-19 03:08:04.908 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EA5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EA5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EA, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 03:08:04.905 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EA5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EA, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 03:08:04.901 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 EA5FE84C3F753CDF8CCF0484
dev:72020-04-19 03:08:04.898 pm debugPARSE START---------------------
dev:72020-04-19 02:55:40.372 pm debugPARSE END-----------------------
dev:72020-04-19 02:55:40.367 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E85FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E85FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E8, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:55:40.363 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E85FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E8, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:55:40.358 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E85FE84C3F753CDF8CCF0484
dev:72020-04-19 02:55:40.355 pm debugPARSE START---------------------
dev:72020-04-19 02:55:18.549 pm debugPARSE END-----------------------
dev:72020-04-19 02:55:18.544 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E75FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E75FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E7, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:55:18.514 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E75FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E7, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:55:18.510 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E75FE84C3F753CDF8CCF0484
dev:72020-04-19 02:55:18.508 pm debugPARSE START---------------------
dev:72020-04-19 02:55:16.046 pm debugPARSE END-----------------------
dev:72020-04-19 02:55:16.040 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E65FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E65FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:55:16.037 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E65FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:55:16.033 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E65FE84C3F753CDF8CCF0484
dev:72020-04-19 02:55:16.031 pm debugPARSE START---------------------
dev:72020-04-19 02:54:27.649 pm debugPARSE END-----------------------
dev:72020-04-19 02:54:27.643 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E55FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E55FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E5, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:54:27.639 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E55FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E5, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:54:27.634 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E55FE84C3F753CDF8CCF0484
dev:72020-04-19 02:54:27.631 pm debugPARSE START---------------------
dev:72020-04-19 02:38:31.555 pm debugPARSE END-----------------------
dev:72020-04-19 02:38:31.549 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E45FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E45FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E4, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:38:31.544 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E45FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E4, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:38:31.539 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E45FE84C3F753CDF8CCF0484
dev:72020-04-19 02:38:31.536 pm debugPARSE START---------------------
dev:72020-04-19 02:38:28.358 pm debugPARSE END-----------------------
dev:72020-04-19 02:38:28.353 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E35FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E35FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E3, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:38:28.349 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E35FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E3, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:38:28.345 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E35FE84C3F753CDF8CCF0484
dev:72020-04-19 02:38:28.343 pm debugPARSE START---------------------
dev:72020-04-19 02:32:59.295 pm debugPARSE END-----------------------
dev:72020-04-19 02:32:59.285 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E15FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E15FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E1, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:32:59.275 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E15FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E1, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:32:59.267 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E15FE84C3F753CDF8CCF0484
dev:72020-04-19 02:32:59.263 pm debugPARSE START---------------------
dev:72020-04-19 02:32:59.036 pm debugPARSE END-----------------------
dev:72020-04-19 02:32:59.025 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E05FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E05FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E0, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:32:59.016 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E05FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E0, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:32:59.010 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 E05FE84C3F753CDF8CCF0484
dev:72020-04-19 02:32:59.007 pm debugPARSE START---------------------
dev:72020-04-19 02:28:19.746 pm debugPARSE END-----------------------
dev:72020-04-19 02:28:19.740 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DF5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DF5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DF, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:28:19.737 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DF5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DF, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:28:19.733 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DF5FE84C3F753CDF8CCF0484
dev:72020-04-19 02:28:19.730 pm debugPARSE START---------------------
dev:72020-04-19 02:22:17.941 pm debugPARSE END-----------------------
dev:72020-04-19 02:22:17.935 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DD5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DD5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DD, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:22:17.932 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DD5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DD, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:22:17.928 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DD5FE84C3F753CDF8CCF0484
dev:72020-04-19 02:22:17.925 pm debugPARSE START---------------------
dev:72020-04-19 02:21:05.207 pm debugPARSE END-----------------------
dev:72020-04-19 02:21:05.201 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DC5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DC5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DC, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:21:05.197 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DC5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DC, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:21:05.192 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DC5FE84C3F753CDF8CCF0484
dev:72020-04-19 02:21:05.190 pm debugPARSE START---------------------
dev:72020-04-19 02:20:50.783 pm debugPARSE END-----------------------
dev:72020-04-19 02:20:50.777 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DA5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DA5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DA, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:20:50.773 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DA5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DA, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:20:50.767 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 DA5FE84C3F753CDF8CCF0484
dev:72020-04-19 02:20:50.763 pm debugPARSE START---------------------
dev:72020-04-19 02:20:17.658 pm debugPARSE END-----------------------
dev:72020-04-19 02:20:17.653 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D95FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D95FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D9, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:20:17.649 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D95FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D9, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:20:17.645 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D95FE84C3F753CDF8CCF0484
dev:72020-04-19 02:20:17.642 pm debugPARSE START---------------------
dev:72020-04-19 02:19:33.578 pm debugPARSE END-----------------------
dev:72020-04-19 02:19:33.573 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D85FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D85FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D8, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:19:33.569 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D85FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D8, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:19:33.565 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D85FE84C3F753CDF8CCF0484
dev:72020-04-19 02:19:33.563 pm debugPARSE START---------------------
dev:72020-04-19 02:19:31.140 pm debugPARSE END-----------------------
dev:72020-04-19 02:19:31.134 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D75FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D75FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D7, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:19:31.130 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D75FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D7, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:19:31.125 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D75FE84C3F753CDF8CCF0484
dev:72020-04-19 02:19:31.122 pm debugPARSE START---------------------
dev:72020-04-19 02:15:49.989 pm debugPARSE END-----------------------
dev:72020-04-19 02:15:49.983 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D65FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D65FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D6, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:15:49.980 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D65FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D6, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:15:49.976 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D65FE84C3F753CDF8CCF0484
dev:72020-04-19 02:15:49.974 pm debugPARSE START---------------------
dev:72020-04-19 02:15:49.958 pm debugPARSE END-----------------------
dev:72020-04-19 02:15:49.952 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D55FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D55FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D5, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:15:49.948 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D55FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D5, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:15:49.944 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D55FE84C3F753CDF8CCF0484
dev:72020-04-19 02:15:49.942 pm debugPARSE START---------------------
dev:72020-04-19 02:15:44.464 pm debugPARSE END-----------------------
dev:72020-04-19 02:15:44.459 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D45FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D45FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D4, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:15:44.456 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D45FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D4, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:15:44.452 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D45FE84C3F753CDF8CCF0484
dev:72020-04-19 02:15:44.449 pm debugPARSE START---------------------
dev:72020-04-19 02:12:44.376 pm debugPARSE END-----------------------
dev:72020-04-19 02:12:44.369 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D25FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D25FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D2, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:12:44.365 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D25FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D2, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:12:44.360 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D25FE84C3F753CDF8CCF0484
dev:72020-04-19 02:12:44.357 pm debugPARSE START---------------------
dev:72020-04-19 02:07:39.298 pm debugPARSE END-----------------------
dev:72020-04-19 02:07:39.292 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D15FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D15FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D1, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:07:39.288 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D15FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D1, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:07:39.284 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D15FE84C3F753CDF8CCF0484
dev:72020-04-19 02:07:39.281 pm debugPARSE START---------------------
dev:72020-04-19 02:05:23.898 pm debugPARSE END-----------------------
dev:72020-04-19 02:05:23.892 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D05FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D05FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D0, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:05:23.887 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D05FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D0, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:05:23.882 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 D05FE84C3F753CDF8CCF0484
dev:72020-04-19 02:05:23.879 pm debugPARSE START---------------------
dev:72020-04-19 02:02:47.643 pm debugPARSE END-----------------------
dev:72020-04-19 02:02:47.636 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CF5FE84C3F753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CF5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CF, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:02:47.629 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CF5FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CF, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-19 02:02:47.626 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 CF5FE84C3F753CDF8CCF0484
dev:72020-04-19 02:02:47.623 pm debugPARSE START---------------------
And I still don't see any battery info. Also checked the dashboard tiles at the very end. Sliders still work. And now the sliders seem to show the accurate position. But the button and it's icon don't do anything and the status showing on the button icon is inaccurate
@claytonelliott It's because it is not being received, working on that.
I've added two commands to test with:
"Get Position"
"Get Position Alt"
First Run "SetPosition 46" and then turn on debug logging and run the two commands above. Wait 10 seconds between each.
Hopefully that gives us the data, it's the right commands, just seem to be something not working as expected. We'll have to keep testing.
Dashboard tiles will not work as expected until we can get the position data back. Sorry for all the testing, but the documentation on what to run here is very limited and trial and error is the only way forward.
I did it a couple times. I think this includes at least one of them if not both:
dev:72020-04-20 05:54:37.665 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:37.659 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 01 115F 01 01 , profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:01, direction:01, data:[]]
dev:72020-04-20 05:54:37.656 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 01 115F 01 01
dev:72020-04-20 05:54:37.653 pm debugPARSE START---------------------
dev:72020-04-20 05:54:35.839 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:35.831 pm debugmsgMap: [raw:catchall: 0104 0001 01 01 0040 00 E85F 00 01 115F 01 01 , profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:01, direction:01, data:[]]
dev:72020-04-20 05:54:35.828 pm debugParsing: catchall: 0104 0001 01 01 0040 00 E85F 00 01 115F 01 01
dev:72020-04-20 05:54:35.826 pm debugPARSE START---------------------
dev:72020-04-20 05:54:34.156 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:34.149 pm debugmsgMap: [raw:catchall: 0104 0013 01 01 0040 00 E85F 00 01 115F 01 01 , profileId:0104, clusterId:0013, clusterInt:19, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:01, direction:01, data:[]]
dev:72020-04-20 05:54:34.146 pm debugParsing: catchall: 0104 0013 01 01 0040 00 E85F 00 01 115F 01 01
dev:72020-04-20 05:54:34.144 pm debugPARSE START---------------------
dev:72020-04-20 05:54:33.493 pm debugcmd: [he raw 0xE85F 1 0x01 0x0013 {04 5F 11 00 00 55 00}, delay 2000, he raw 0xE85F 1 0x01 0x0001 {04 5F 11 00 00 21 00}, delay 2000, he raw 0xE85F 1 0x01 0x000D {04 5F 11 00 00 55 00}, delay 2000]
dev:72020-04-20 05:54:33.481 pm debuggetPositionAlt()
dev:12020-04-20 05:54:31.913 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 E3AD68C58A753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 E3AD68C58A753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68AD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E3, AD, 68, C5, 8A, 75, 3C, DF, 8C, CF, 04, 84]]
dev:12020-04-20 05:54:30.889 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 E2AD68C58A753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 E2AD68C58A753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68AD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E2, AD, 68, C5, 8A, 75, 3C, DF, 8C, CF, 04, 84]]
dev:12020-04-20 05:54:26.695 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 E0AD68C58A753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 E0AD68C58A753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68AD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E0, AD, 68, C5, 8A, 75, 3C, DF, 8C, CF, 04, 84]]
dev:12020-04-20 05:54:21.960 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 DEAD68C58A753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 DEAD68C58A753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68AD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DE, AD, 68, C5, 8A, 75, 3C, DF, 8C, CF, 04, 84]]
dev:12020-04-20 05:54:18.903 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 DDAD68C58A753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 DDAD68C58A753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68AD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DD, AD, 68, C5, 8A, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-20 05:54:15.096 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:15.090 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:54:15.087 pm debugmsgMap: [raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:54:15.082 pm debugParsing: read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000
dev:72020-04-20 05:54:15.079 pm debugPARSE START---------------------
dev:72020-04-20 05:54:14.883 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:14.874 pm debugGETTING POSITION: long => 1110966272, BigDecimal => 46
dev:72020-04-20 05:54:14.871 pm debugcluster 000D
dev:72020-04-20 05:54:14.868 pm debugmsgMap: [raw:E85F01000D1055003900003842, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42380000, clusterInt:13, attrInt:85]
dev:72020-04-20 05:54:14.863 pm debugParsing: read attr - raw: E85F01000D1055003900003842, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00003842
dev:72020-04-20 05:54:14.860 pm debugPARSE START---------------------
dev:72020-04-20 05:54:12.797 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:12.792 pm warnUnhandled Event - description:read attr - raw: E85F0100010A210020B2, dni: E85F, endpoint: 01, cluster: 0001, size: 0A, attrId: 0021, encoding: 20, command: 01, value: B2 | msgMap:[raw:E85F0100010A210020B2, dni:E85F, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:B2, clusterInt:1, attrInt:33]
dev:72020-04-20 05:54:12.790 pm debugmsgMap: [raw:E85F0100010A210020B2, dni:E85F, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:B2, clusterInt:1, attrInt:33]
dev:72020-04-20 05:54:12.785 pm debugParsing: read attr - raw: E85F0100010A210020B2, dni: E85F, endpoint: 01, cluster: 0001, size: 0A, attrId: 0021, encoding: 20, command: 01, value: B2
dev:72020-04-20 05:54:12.782 pm debugPARSE START---------------------
dev:72020-04-20 05:54:10.702 pm debugPARSE END-----------------------
dev:72020-04-20 05:54:10.697 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:54:10.695 pm debugmsgMap: [raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:54:10.690 pm debugParsing: read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000
dev:72020-04-20 05:54:10.688 pm debugPARSE START---------------------
dev:72020-04-20 05:54:10.512 pm debugcmd: [he raw 0xE85F 1 0x01 0x0013 {10 00 00 55 00}, delay 2000, he raw 0xE85F 1 0x01 0x0001 {10 00 00 21 00}, delay 2000, he raw 0xE85F 1 0x01 0x000D {10 00 00 55 00}, delay 2000]
dev:72020-04-20 05:54:10.501 pm debuggetPosition()
dev:12020-04-20 05:54:08.066 pm warnUnhandled Event - description:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 DCAD68C58A753CDF8CCF0484 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 68AD 00 00 0000 00 00 DCAD68C58A753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68AD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DC, AD, 68, C5, 8A, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-20 05:54:05.271 pm debugrefresh() model='lumi.curtain.hagl04'
dev:72020-04-20 05:54:05.243 pm infoinitialize()
dev:72020-04-20 05:54:05.240 pm debugupdated()
dev:72020-04-20 05:53:50.742 pm debugrefresh() model='lumi.curtain.hagl04'
dev:72020-04-20 05:53:50.712 pm infoinitialize()
dev:72020-04-20 05:53:50.709 pm debugupdated()
dev:72020-04-20 05:53:43.570 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:53:43.550 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:53:14.099 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:53:13.875 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:52:58.853 pm infoinitialize()
dev:72020-04-20 05:52:38.085 pm debugPARSE END-----------------------
dev:72020-04-20 05:52:38.053 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:52:38.050 pm debugmsgMap: [raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:52:38.045 pm debugParsing: read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000
dev:72020-04-20 05:52:38.043 pm debugPARSE START---------------------
dev:72020-04-20 05:52:38.032 pm debugPARSE END-----------------------
dev:72020-04-20 05:52:38.027 pm warnUnhandled Event - description:read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000 | msgMap:[raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:52:38.025 pm debugmsgMap: [raw:E85F0100130C5500210000, dni:E85F, endpoint:01, cluster:0013, size:0C, attrId:0055, encoding:21, command:01, value:0000, clusterInt:19, attrInt:85]
dev:72020-04-20 05:52:38.020 pm debugParsing: read attr - raw: E85F0100130C5500210000, dni: E85F, endpoint: 01, cluster: 0013, size: 0C, attrId: 0055, encoding: 21, command: 01, value: 0000
dev:72020-04-20 05:52:38.017 pm debugPARSE START---------------------
dev:72020-04-20 05:52:37.919 pm debugPARSE END-----------------------
dev:72020-04-20 05:52:37.858 pm debugGETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-20 05:52:37.858 pm debugGETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-20 05:52:37.851 pm debugcluster 000D
dev:72020-04-20 05:52:37.846 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-20 05:52:37.846 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-20 05:52:37.830 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-20 05:52:37.827 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-20 05:52:37.828 pm debugPARSE START---------------------
dev:72020-04-20 05:52:37.824 pm debugPARSE START---------------------
dev:72020-04-20 05:52:28.496 pm debugPARSE END-----------------------
dev:72020-04-20 05:52:28.489 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-20 05:52:28.485 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-20 05:52:28.482 pm debugPARSE START---------------------
dev:72020-04-20 05:52:27.759 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42380000} {}, delay 2000]
dev:72020-04-20 05:52:27.717 pm debugSet Position: 46%
dev:72020-04-20 05:52:27.704 pm debugsetPosition(position: 46)
This includes both the battery and the position event. I've uploaded a new version of the driver. For the battery I included a command, please click "Get Battery" and show me the debug logs and a screenshot of the battery% if it updates on the driver page.
The percentage shown, does it make sense? Can you charge it and see if you get 100%? From what I see it should be 89% if still the same as in the logs.
The position reporting should now be correct. With debug mode on, run the same as before: open, close, setposition 60, but also setposition 46.
If the correct position is shown in the driver page, then test with the Dashboard. If all is working as expected then I don't need these logs, just the ones for the battery. If the position is still not reported correctly, please run setposition 60 and click the "Get Position" and "Get Position Alt" and show me the logs.
I'll have to test further in the morning here. My wife is already asleep in the room with the curtains. For now I've updated the driver and hit "Get Battery" It now shows Battery: 89 and Battery: 94 under Current States on each respective motor's device page so that is definitely progress and seems correct (most of my testing has been done with the 89 battery so it will be less full). I'll charge them tomorrow and do the complete round of testing.
Until then, I've got a question I thought I would run by you. I'm struggling trying to get an old Z-wave lamp plug/dimmer to work. I have several of these and would love to get them working. Any ideas? Details are here: Monster Central - Z-wave devices - OLD
Great, then I will set battery status to update once every 24 hours or so. That won't drain anything and should be plenty to keep it correct. Pressing refresh will also update it when I'm done with the driver.
Do you charge them in-place? If so, please connect and charge with the debug logging on and we can see if we get some messages when done charging and/or unplugging the charger.
I'm sorry, I wouldn't know, I don't have any z-wave devices, where I live there's not many to choose from which run on an allowed frequency. The US frequency coincides with a mobile communication band here in China. @bcopeland is the z-wave expert here in the community and maybe has some ideas for you.
Looking forward to seeing the results of this testing, I think we might have reached a working model now.
Yes you can charge in place. I haven't charged yet but I can certainly try charging in place tomorrow
I'll reach out to him
Please update the driver before you do more testing. I've added a scheduled event to take place once every 12 hours to get the battery level. It is automatically activated when the device is installed or the hub reboots. To manually activate it click Initialize.
With the curtain starting at open position and debug logging still on I did the following today in this order and all is in the log below:
  • updated driver
  • hit initialize
  • plugged in charge cable on motor in place
  • waited 2-3 hours
  • checked device and shows screen shot below (battery updated but not sure if position data is correct)
  • checked dashboard tiles and the status is different for my two curtains even thought they are both fully open ( see screenshot #2, but this seemed to correct itself once I moved the curtains)
  • went back to device and clicked "close" ( it worked)
  • went back to device and clicked "open" ( it worked)
  • set postion to 60 (it worked and also updated current states to show "60" and "partially open")
  • set postion to 46 (it worked and also updated current states to show "46" and "partially open")
  • checked dashboard and slider shows position "46" and is near the middle
  • on dashboard I moved slider of same curtain to 75, 92 and 100. All functions works as expected!
  • on dashboard I clicked curtain icon and both curtains closed and showed "closed". Then I clicked icon again and both curtains opened and showed "open"
All seems to be working correctly now! Good work! I'll keep doing random testing and let you know if anything acts weird but if you don't hear from me assume it's all working with my setup :slight_smile:
dev:72020-04-21 03:13:52.512 pm debugPARSE END-----------------------
dev:72020-04-21 03:13:52.508 pm debugmsgMap: [raw:E85F0100000807003003, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:03, clusterInt:0, attrInt:7]
dev:72020-04-21 03:13:52.503 pm debugParsing: read attr - raw: E85F0100000807003003, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 03
dev:72020-04-21 03:13:52.500 pm debugPARSE START---------------------
dev:72020-04-21 03:12:55.823 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:55.819 pm debugCHANGING device.currentValue('position') = 0, curtainPosition = 100
dev:72020-04-21 03:12:55.815 pm debugdevice.currentValue('position') = 0, curtainPosition = 100
dev:72020-04-21 03:12:55.790 pm debugFully Open
dev:72020-04-21 03:12:55.787 pm debugSETTING POSITION: long => 1120403456, BigDecimal => 100
dev:72020-04-21 03:12:55.780 pm debugGOT POSITION DATA: long => 1120403456, BigDecimal => 100
dev:72020-04-21 03:12:55.777 pm debugcluster 000D
dev:72020-04-21 03:12:55.774 pm debugmsgMap: [raw:E85F01000D105500390000C842, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42C80000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:12:55.770 pm debugParsing: read attr - raw: E85F01000D105500390000C842, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 0000C842
dev:72020-04-21 03:12:55.767 pm debugPARSE START---------------------
dev:72020-04-21 03:12:55.635 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:55.627 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:55.625 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:12:55.597 pm debugSending request for the actual position...
dev:72020-04-21 03:12:55.594 pm debugClosed
dev:72020-04-21 03:12:55.592 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:12:55.592 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:12:55.590 pm debugcluster 000D
dev:72020-04-21 03:12:55.586 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:12:55.586 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:12:55.584 pm debugcluster 000D
dev:72020-04-21 03:12:55.580 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:12:55.580 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:12:55.578 pm debugPARSE START---------------------
dev:72020-04-21 03:12:55.574 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:12:55.572 pm debugPARSE START---------------------
dev:72020-04-21 03:12:39.564 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:39.557 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:12:39.553 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:12:39.550 pm debugPARSE START---------------------
dev:72020-04-21 03:12:39.473 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42C80000} {}, delay 2000]
dev:72020-04-21 03:12:39.466 pm debugSet Position: 100%
dev:72020-04-21 03:12:39.455 pm debugsetPosition(position: 100)
dev:72020-04-21 03:12:39.452 pm debugopen()
dev:72020-04-21 03:12:37.302 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:37.299 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:12:37.291 pm debugClosed
dev:72020-04-21 03:12:37.289 pm debugSETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-21 03:12:37.283 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:12:37.280 pm debugcluster 000D
dev:72020-04-21 03:12:37.277 pm debugmsgMap: [raw:E85F01000D1055003900000000, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:00000000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:12:37.277 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:37.273 pm debugParsing: read attr - raw: E85F01000D1055003900000000, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00000000
dev:72020-04-21 03:12:37.272 pm debugmsgMap: [raw:E85F0100000807003004, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:04, clusterInt:0, attrInt:7]
dev:72020-04-21 03:12:37.270 pm debugPARSE START---------------------
dev:72020-04-21 03:12:37.268 pm debugParsing: read attr - raw: E85F0100000807003004, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 04
dev:72020-04-21 03:12:37.265 pm debugPARSE START---------------------
dev:72020-04-21 03:12:37.106 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:37.102 pm debugCHANGING device.currentValue('position') = 100, curtainPosition = 0
dev:72020-04-21 03:12:37.102 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:37.099 pm debugdevice.currentValue('position') = 100, curtainPosition = 0
dev:72020-04-21 03:12:37.094 pm debugSending request for the actual position...
dev:72020-04-21 03:12:37.091 pm debugClosed
dev:72020-04-21 03:12:37.089 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:12:37.088 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:12:37.087 pm debugcluster 000D
dev:72020-04-21 03:12:37.083 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:12:37.083 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:12:37.080 pm debugcluster 000D
dev:72020-04-21 03:12:37.076 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:12:37.077 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:12:37.075 pm debugPARSE START---------------------
dev:72020-04-21 03:12:37.070 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:12:37.067 pm debugPARSE START---------------------
dev:72020-04-21 03:12:20.740 pm debugPARSE END-----------------------
dev:72020-04-21 03:12:20.733 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:12:20.729 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:12:20.726 pm debugPARSE START---------------------
dev:72020-04-21 03:12:19.870 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {00000000} {}, delay 2000]
dev:72020-04-21 03:12:19.861 pm debugSet Position: 0%
dev:72020-04-21 03:12:19.832 pm debugsetPosition(position: 0)
dev:72020-04-21 03:12:19.829 pm debugclose()
dev:72020-04-21 03:10:57.222 pm debugPARSE END-----------------------
dev:72020-04-21 03:10:57.214 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:10:57.210 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:10:57.207 pm debugPARSE START---------------------
dev:72020-04-21 03:10:56.143 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42C80000} {}, delay 2000]
dev:72020-04-21 03:10:56.137 pm debugSet Position: 100%
dev:72020-04-21 03:10:56.124 pm debugsetPosition(position: 100)
dev:72020-04-21 03:09:40.731 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:40.726 pm debugCHANGING device.currentValue('position') = 0, curtainPosition = 100
dev:72020-04-21 03:09:40.723 pm debugdevice.currentValue('position') = 0, curtainPosition = 100
dev:72020-04-21 03:09:40.715 pm debugFully Open
dev:72020-04-21 03:09:40.712 pm debugSETTING POSITION: long => 1120403456, BigDecimal => 100
dev:72020-04-21 03:09:40.707 pm debugGOT POSITION DATA: long => 1120403456, BigDecimal => 100
dev:72020-04-21 03:09:40.704 pm debugcluster 000D
dev:72020-04-21 03:09:40.700 pm debugmsgMap: [raw:E85F01000D105500390000C842, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42C80000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:09:40.695 pm debugParsing: read attr - raw: E85F01000D105500390000C842, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 0000C842
dev:72020-04-21 03:09:40.693 pm debugPARSE START---------------------
dev:72020-04-21 03:09:40.554 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:40.549 pm debugCHANGING device.currentValue('position') = 75, curtainPosition = 0
dev:72020-04-21 03:09:40.539 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:40.537 pm debugdevice.currentValue('position') = 75, curtainPosition = 0
dev:72020-04-21 03:09:40.532 pm debugSending request for the actual position...
dev:72020-04-21 03:09:40.529 pm debugClosed
dev:72020-04-21 03:09:40.526 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:09:40.526 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:09:40.524 pm debugcluster 000D
dev:72020-04-21 03:09:40.519 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:09:40.519 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:09:40.516 pm debugcluster 000D
dev:72020-04-21 03:09:40.512 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:09:40.512 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:09:40.509 pm debugPARSE START---------------------
dev:72020-04-21 03:09:40.505 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:09:40.502 pm debugPARSE START---------------------
dev:72020-04-21 03:09:36.458 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:36.451 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:09:36.447 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:09:36.444 pm debugPARSE START---------------------
dev:72020-04-21 03:09:36.290 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42C80000} {}, delay 2000]
dev:72020-04-21 03:09:36.282 pm debugSet Position: 100%
dev:72020-04-21 03:09:36.270 pm debugsetPosition(position: 100)
dev:72020-04-21 03:09:34.453 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:34.445 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:09:34.441 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:09:34.438 pm debugPARSE START---------------------
dev:72020-04-21 03:09:34.190 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42B80000} {}, delay 2000]
dev:72020-04-21 03:09:34.185 pm debugSet Position: 92%
dev:72020-04-21 03:09:34.177 pm debugsetPosition(position: 92)
dev:72020-04-21 03:09:32.203 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:32.199 pm debugCHANGING device.currentValue('position') = 0, curtainPosition = 75
dev:72020-04-21 03:09:32.195 pm debugdevice.currentValue('position') = 0, curtainPosition = 75
dev:72020-04-21 03:09:32.187 pm debug75% Partially Open
dev:72020-04-21 03:09:32.184 pm debugSETTING POSITION: long => 1117126656, BigDecimal => 75
dev:72020-04-21 03:09:32.179 pm debugGOT POSITION DATA: long => 1117126656, BigDecimal => 75
dev:72020-04-21 03:09:32.176 pm debugcluster 000D
dev:72020-04-21 03:09:32.172 pm debugmsgMap: [raw:E85F01000D1055003900009642, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42960000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:09:32.169 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:32.167 pm debugParsing: read attr - raw: E85F01000D1055003900009642, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00009642
dev:72020-04-21 03:09:32.165 pm debugPARSE START---------------------
dev:72020-04-21 03:09:32.164 pm debugmsgMap: [raw:E85F0100000807003003, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:03, clusterInt:0, attrInt:7]
dev:72020-04-21 03:09:32.159 pm debugParsing: read attr - raw: E85F0100000807003003, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 03
dev:72020-04-21 03:09:32.157 pm debugPARSE START---------------------
dev:72020-04-21 03:09:32.008 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:32.000 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:31.997 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:09:31.993 pm debugSending request for the actual position...
dev:72020-04-21 03:09:31.990 pm debugClosed
dev:72020-04-21 03:09:31.988 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:09:31.987 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:09:31.986 pm debugcluster 000D
dev:72020-04-21 03:09:31.981 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:09:31.981 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:09:31.979 pm debugcluster 000D
dev:72020-04-21 03:09:31.976 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:09:31.975 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:09:31.973 pm debugPARSE START---------------------
dev:72020-04-21 03:09:31.969 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:09:31.966 pm debugPARSE START---------------------
dev:72020-04-21 03:09:20.061 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:20.053 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:09:20.049 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:09:20.046 pm debugPARSE START---------------------
dev:72020-04-21 03:09:19.899 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42960000} {}, delay 2000]
dev:72020-04-21 03:09:19.894 pm debugSet Position: 75%
dev:72020-04-21 03:09:19.885 pm debugsetPosition(position: 75)
dev:72020-04-21 03:09:16.976 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:16.972 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:09:16.964 pm debugClosed
dev:72020-04-21 03:09:16.961 pm debugSETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-21 03:09:16.954 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:09:16.951 pm debugcluster 000D
dev:72020-04-21 03:09:16.948 pm debugmsgMap: [raw:E85F01000D1055003900000000, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:00000000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:09:16.943 pm debugParsing: read attr - raw: E85F01000D1055003900000000, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00000000
dev:72020-04-21 03:09:16.940 pm debugPARSE START---------------------
dev:72020-04-21 03:09:16.836 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:16.819 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:16.816 pm debugCHANGING device.currentValue('position') = 46, curtainPosition = 0
dev:72020-04-21 03:09:16.812 pm debugSending request for the actual position...
dev:72020-04-21 03:09:16.811 pm debugdevice.currentValue('position') = 46, curtainPosition = 0
dev:72020-04-21 03:09:16.802 pm debugClosed
dev:72020-04-21 03:09:16.801 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:09:16.799 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:09:16.797 pm debugcluster 000D
dev:72020-04-21 03:09:16.766 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:09:16.765 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:09:16.762 pm debugcluster 000D
dev:72020-04-21 03:09:16.760 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:09:16.757 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:09:16.756 pm debugPARSE START---------------------
dev:72020-04-21 03:09:16.750 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:09:16.748 pm debugPARSE START---------------------
dev:72020-04-21 03:09:07.780 pm debugPARSE END-----------------------
dev:72020-04-21 03:09:07.772 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:09:07.769 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:09:07.766 pm debugPARSE START---------------------
dev:72020-04-21 03:09:06.900 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {00000000} {}, delay 2000]
dev:72020-04-21 03:09:06.895 pm debugSet Position: 0%
dev:72020-04-21 03:09:06.884 pm debugsetPosition(position: 0)
dev:72020-04-21 03:06:00.533 pm debugPARSE END-----------------------
dev:72020-04-21 03:06:00.529 pm debugCHANGING device.currentValue('position') = 0, curtainPosition = 46
dev:72020-04-21 03:06:00.526 pm debugdevice.currentValue('position') = 0, curtainPosition = 46
dev:72020-04-21 03:06:00.518 pm debug46% Partially Open
dev:72020-04-21 03:06:00.515 pm debugSETTING POSITION: long => 1110966272, BigDecimal => 46
dev:72020-04-21 03:06:00.508 pm debugGOT POSITION DATA: long => 1110966272, BigDecimal => 46
dev:72020-04-21 03:06:00.505 pm debugcluster 000D
dev:72020-04-21 03:06:00.501 pm debugmsgMap: [raw:E85F01000D1055003900003842, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42380000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:06:00.496 pm debugParsing: read attr - raw: E85F01000D1055003900003842, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00003842
dev:72020-04-21 03:06:00.493 pm debugPARSE START---------------------
dev:72020-04-21 03:06:00.492 pm debugPARSE END-----------------------
dev:72020-04-21 03:06:00.487 pm debugmsgMap: [raw:E85F0100000807003004, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:04, clusterInt:0, attrInt:7]
dev:72020-04-21 03:06:00.483 pm debugParsing: read attr - raw: E85F0100000807003004, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 04
dev:72020-04-21 03:06:00.480 pm debugPARSE START---------------------
dev:72020-04-21 03:06:00.353 pm debugPARSE END-----------------------
dev:72020-04-21 03:06:00.342 pm debugPARSE END-----------------------
dev:72020-04-21 03:06:00.339 pm debugCHANGING device.currentValue('position') = 60, curtainPosition = 0
dev:72020-04-21 03:06:00.336 pm debugdevice.currentValue('position') = 60, curtainPosition = 0
dev:72020-04-21 03:06:00.336 pm debugSending request for the actual position...
dev:72020-04-21 03:06:00.329 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:06:00.328 pm debugClosed
dev:72020-04-21 03:06:00.327 pm debugcluster 000D
dev:72020-04-21 03:06:00.326 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:06:00.323 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:06:00.320 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:06:00.317 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:06:00.317 pm debugcluster 000D
dev:72020-04-21 03:06:00.315 pm debugPARSE START---------------------
dev:72020-04-21 03:06:00.313 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:06:00.306 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:06:00.304 pm debugPARSE START---------------------
dev:72020-04-21 03:05:56.151 pm debugPARSE END-----------------------
dev:72020-04-21 03:05:56.144 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:05:56.140 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:05:56.137 pm debugPARSE START---------------------
dev:72020-04-21 03:05:55.579 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42380000} {}, delay 2000]
dev:72020-04-21 03:05:55.575 pm debugSet Position: 46%
dev:72020-04-21 03:05:55.566 pm debugsetPosition(position: 46)
dev:72020-04-21 03:04:46.931 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:46.927 pm debugCHANGING device.currentValue('position') = 0, curtainPosition = 60
dev:72020-04-21 03:04:46.924 pm debugdevice.currentValue('position') = 0, curtainPosition = 60
dev:72020-04-21 03:04:46.916 pm debug60% Partially Open
dev:72020-04-21 03:04:46.913 pm debugSETTING POSITION: long => 1114636288, BigDecimal => 60
dev:72020-04-21 03:04:46.907 pm debugGOT POSITION DATA: long => 1114636288, BigDecimal => 60
dev:72020-04-21 03:04:46.904 pm debugcluster 000D
dev:72020-04-21 03:04:46.901 pm debugmsgMap: [raw:E85F01000D1055003900007042, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42700000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:04:46.896 pm debugParsing: read attr - raw: E85F01000D1055003900007042, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00007042
dev:72020-04-21 03:04:46.895 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:46.894 pm debugPARSE START---------------------
dev:72020-04-21 03:04:46.891 pm debugmsgMap: [raw:E85F0100000807003003, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:03, clusterInt:0, attrInt:7]
dev:72020-04-21 03:04:46.886 pm debugParsing: read attr - raw: E85F0100000807003003, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 03
dev:72020-04-21 03:04:46.884 pm debugPARSE START---------------------
dev:72020-04-21 03:04:46.719 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:46.714 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:04:46.712 pm debugSending request for the actual position...
dev:72020-04-21 03:04:46.706 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:04:46.706 pm debugClosed
dev:72020-04-21 03:04:46.703 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:04:46.703 pm debugcluster 000D
dev:72020-04-21 03:04:46.699 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:04:46.696 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:04:46.694 pm debugcluster 000D
dev:72020-04-21 03:04:46.693 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:04:46.689 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:04:46.690 pm debugPARSE START---------------------
dev:72020-04-21 03:04:46.683 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:04:46.680 pm debugPARSE START---------------------
dev:72020-04-21 03:04:36.336 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:36.329 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:04:36.326 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:04:36.323 pm debugPARSE START---------------------
dev:72020-04-21 03:04:35.700 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42700000} {}, delay 2000]
dev:72020-04-21 03:04:35.695 pm debugSet Position: 60%
dev:72020-04-21 03:04:35.687 pm debugsetPosition(position: 60)
dev:72020-04-21 03:04:19.163 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:19.160 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:04:19.152 pm debugClosed
dev:72020-04-21 03:04:19.149 pm debugSETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-21 03:04:19.143 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:04:19.140 pm debugcluster 000D
dev:72020-04-21 03:04:19.137 pm debugmsgMap: [raw:E85F01000D1055003900000000, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:00000000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:04:19.132 pm debugParsing: read attr - raw: E85F01000D1055003900000000, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00000000
dev:72020-04-21 03:04:19.129 pm debugPARSE START---------------------
dev:72020-04-21 03:04:18.974 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:18.968 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:18.963 pm debugCHANGING device.currentValue('position') = 100, curtainPosition = 0
dev:72020-04-21 03:04:18.961 pm debugSending request for the actual position...
dev:72020-04-21 03:04:18.959 pm debugdevice.currentValue('position') = 100, curtainPosition = 0
dev:72020-04-21 03:04:18.955 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:04:18.951 pm debugcluster 000D
dev:72020-04-21 03:04:18.950 pm debugClosed
dev:72020-04-21 03:04:18.946 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:04:18.946 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:04:18.939 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:04:18.940 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:04:18.936 pm debugcluster 000D
dev:72020-04-21 03:04:18.935 pm debugPARSE START---------------------
dev:72020-04-21 03:04:18.931 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:04:18.924 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:04:18.920 pm debugPARSE START---------------------
dev:72020-04-21 03:04:02.484 pm debugPARSE END-----------------------
dev:72020-04-21 03:04:02.476 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:04:02.472 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:04:02.468 pm debugPARSE START---------------------
dev:72020-04-21 03:04:02.353 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {00000000} {}, delay 2000]
dev:72020-04-21 03:04:02.348 pm debugSet Position: 0%
dev:72020-04-21 03:04:02.336 pm debugsetPosition(position: 0)
dev:72020-04-21 03:04:02.333 pm debugclose()
dev:72020-04-21 03:03:42.801 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:42.797 pm debugCHANGING device.currentValue('position') = 0, curtainPosition = 100
dev:72020-04-21 03:03:42.793 pm debugdevice.currentValue('position') = 0, curtainPosition = 100
dev:72020-04-21 03:03:42.785 pm debugFully Open
dev:72020-04-21 03:03:42.782 pm debugSETTING POSITION: long => 1120403456, BigDecimal => 100
dev:72020-04-21 03:03:42.775 pm debugGOT POSITION DATA: long => 1120403456, BigDecimal => 100
dev:72020-04-21 03:03:42.772 pm debugcluster 000D
dev:72020-04-21 03:03:42.768 pm debugmsgMap: [raw:E85F01000D105500390000C842, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:42C80000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:03:42.762 pm debugParsing: read attr - raw: E85F01000D105500390000C842, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 0000C842
dev:72020-04-21 03:03:42.759 pm debugPARSE START---------------------
dev:72020-04-21 03:03:42.601 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:42.600 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:42.596 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:03:42.594 pm debugSending request for the actual position...
dev:72020-04-21 03:03:42.588 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:03:42.588 pm debugClosed
dev:72020-04-21 03:03:42.585 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:03:42.585 pm debugcluster 000D
dev:72020-04-21 03:03:42.580 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:03:42.578 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:03:42.575 pm debugcluster 000D
dev:72020-04-21 03:03:42.573 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:03:42.570 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:03:42.570 pm debugPARSE START---------------------
dev:72020-04-21 03:03:42.563 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:03:42.560 pm debugPARSE START---------------------
dev:72020-04-21 03:03:26.411 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:26.403 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:03:26.399 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:03:26.396 pm debugPARSE START---------------------
dev:72020-04-21 03:03:26.186 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {42C80000} {}, delay 2000]
dev:72020-04-21 03:03:26.181 pm debugSet Position: 100%
dev:72020-04-21 03:03:26.169 pm debugsetPosition(position: 100)
dev:72020-04-21 03:03:26.166 pm debugopen()
dev:72020-04-21 03:03:24.211 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:24.206 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:03:24.196 pm debugClosed
dev:72020-04-21 03:03:24.192 pm debugSETTING POSITION: long => 0, BigDecimal => 0
dev:72020-04-21 03:03:24.185 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:03:24.181 pm debugcluster 000D
dev:72020-04-21 03:03:24.176 pm debugmsgMap: [raw:E85F01000D1055003900000000, dni:E85F, endpoint:01, cluster:000D, size:10, attrId:0055, encoding:39, command:01, value:00000000, clusterInt:13, attrInt:85]
dev:72020-04-21 03:03:24.166 pm debugParsing: read attr - raw: E85F01000D1055003900000000, dni: E85F, endpoint: 01, cluster: 000D, size: 10, attrId: 0055, encoding: 39, command: 01, value: 00000000
dev:72020-04-21 03:03:24.166 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:24.163 pm debugPARSE START---------------------
dev:72020-04-21 03:03:24.160 pm debugmsgMap: [raw:E85F0100000807003004, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:04, clusterInt:0, attrInt:7]
dev:72020-04-21 03:03:24.154 pm debugParsing: read attr - raw: E85F0100000807003004, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 04
dev:72020-04-21 03:03:24.150 pm debugPARSE START---------------------
dev:72020-04-21 03:03:24.031 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:24.003 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:23.997 pm debugdevice.currentValue('position') = 0, curtainPosition = 0
dev:72020-04-21 03:03:23.986 pm debugClosed
dev:72020-04-21 03:03:23.980 pm debugSending request for the actual position...
dev:72020-04-21 03:03:23.977 pm debugSETTING POSITION: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:03:23.971 pm debugGOT POSITION DATA: long => 0, BigDecimal => 0
dev:72020-04-21 03:03:23.968 pm debugGOT POSITION DATA: long => 1073741824, BigDecimal => 2
dev:72020-04-21 03:03:23.967 pm debugcluster 000D
dev:72020-04-21 03:03:23.964 pm debugcluster 000D
dev:72020-04-21 03:03:23.959 pm debugmsgMap: [raw:E85F01000D1C5500390000000000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:00000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:03:23.956 pm debugmsgMap: [raw:E85F01000D1C5500390000004000F02300000200, dni:E85F, endpoint:01, cluster:000D, size:1C, attrId:0055, encoding:39, command:0A, value:40000000, clusterInt:13, attrInt:85, additionalAttrs:[[value:00020000, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]]]
dev:72020-04-21 03:03:23.948 pm debugParsing: read attr - raw: E85F01000D1C5500390000000000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000000000F02300000200
dev:72020-04-21 03:03:23.944 pm debugPARSE START---------------------
dev:72020-04-21 03:03:23.941 pm debugParsing: read attr - raw: E85F01000D1C5500390000004000F02300000200, dni: E85F, endpoint: 01, cluster: 000D, size: 1C, attrId: 0055, encoding: 39, command: 0A, value: 0000004000F02300000200
dev:72020-04-21 03:03:23.938 pm debugPARSE START---------------------
dev:72020-04-21 03:03:07.648 pm debugPARSE END-----------------------
dev:72020-04-21 03:03:07.638 pm debugmsgMap: [raw:catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00, profileId:0104, clusterId:000D, clusterInt:13, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:72020-04-21 03:03:07.633 pm debugParsing: catchall: 0104 000D 01 01 0040 00 E85F 00 00 0000 04 01 00
dev:72020-04-21 03:03:07.630 pm debugPARSE START---------------------
dev:72020-04-21 03:03:06.357 pm debugcmd=[he wattr 0xE85F 0x01 0x000D 0x0055 0x39 {00000000} {}, delay 2000]
dev:72020-04-21 03:03:06.326 pm debugSet Position: 0%
dev:72020-04-21 03:03:06.313 pm debugsetPosition(position: 0)
dev:72020-04-21 03:03:06.302 pm debugclose()
dev:72020-04-21 02:03:16.600 pm debugPARSE END-----------------------
dev:72020-04-21 02:03:16.596 pm debugBattery: 100%, C8
dev:72020-04-21 02:03:16.588 pm debugmsgMap: [raw:E85F0100010A210020C8, dni:E85F, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:C8, clusterInt:1, attrInt:33]
dev:72020-04-21 02:03:16.573 pm debugParsing: read attr - raw: E85F0100010A210020C8, dni: E85F, endpoint: 01, cluster: 0001, size: 0A, attrId: 0021, encoding: 20, command: 01, value: C8
dev:72020-04-21 02:03:16.569 pm debugPARSE START---------------------
dev:72020-04-21 02:03:16.112 pm debugcmd: [he raw 0xE85F 1 0x01 0x0001 {10 00 00 21 00}, delay 2000]
dev:72020-04-21 02:03:16.106 pm infogetBattery()
dev:72020-04-21 12:39:50.353 pm debugPARSE END-----------------------
dev:72020-04-21 12:39:50.347 pm debugBattery: 100%, C8
dev:72020-04-21 12:39:50.346 pm debugPARSE END-----------------------
dev:72020-04-21 12:39:50.335 pm debugmsgMap: [raw:E85F0100000807003003, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:03, clusterInt:0, attrInt:7]
dev:72020-04-21 12:39:50.333 pm debugmsgMap: [raw:E85F01000108210020C8, dni:E85F, endpoint:01, cluster:0001, size:08, attrId:0021, encoding:20, command:0A, value:C8, clusterInt:1, attrInt:33]
dev:72020-04-21 12:39:50.318 pm debugParsing: read attr - raw: E85F01000108210020C8, dni: E85F, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: C8
dev:72020-04-21 12:39:50.318 pm debugParsing: read attr - raw: E85F0100000807003003, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 03
dev:72020-04-21 12:39:50.313 pm debugPARSE START---------------------
dev:72020-04-21 12:14:47.008 pm debugPARSE END-----------------------
dev:72020-04-21 12:14:46.999 pm debugmsgMap: [raw:catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 055FE84C3F753CDF8CCF0484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E85F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[05, 5F, E8, 4C, 3F, 75, 3C, DF, 8C, CF, 04, 84]]
dev:72020-04-21 12:14:46.994 pm debugParsing: catchall: 0000 0013 00 00 0040 00 E85F 00 00 0000 00 00 055FE84C3F753CDF8CCF0484
dev:72020-04-21 12:14:46.990 pm debugPARSE START---------------------
dev:72020-04-21 11:44:47.822 am debugPARSE END-----------------------
dev:72020-04-21 11:44:47.815 am debugBattery: 99%, C6
dev:72020-04-21 11:44:47.811 am debugPARSE END-----------------------
dev:72020-04-21 11:44:47.805 am debugmsgMap: [raw:E85F01000108210020C6, dni:E85F, endpoint:01, cluster:0001, size:08, attrId:0021, encoding:20, command:0A, value:C6, clusterInt:1, attrInt:33]
dev:72020-04-21 11:44:47.804 am debugmsgMap: [raw:E85F0100000807003004, dni:E85F, endpoint:01, cluster:0000, size:08, attrId:0007, encoding:30, command:0A, value:04, clusterInt:0, attrInt:7]
dev:72020-04-21 11:44:47.795 am debugParsing: read attr - raw: E85F0100000807003004, dni: E85F, endpoint: 01, cluster: 0000, size: 08, attrId: 0007, encoding: 30, command: 0A, value: 04
dev:72020-04-21 11:44:47.795 am debugParsing: read attr - raw: E85F01000108210020C6, dni: E85F, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: C6
dev:72020-04-21 11:44:47.791 am debugPARSE START---------------------
dev:72020-04-21 10:49:45.798 am debugPARSE END-----------------------
dev:72020-04-21 10:49:45.794 am debugBattery: 89%, B2
dev:72020-04-21 10:49:45.786 am debugmsgMap: [raw:E85F0100010A210020B2, dni:E85F, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:B2, clusterInt:1, attrInt:33]
dev:72020-04-21 10:49:45.768 am debugParsing: read attr - raw: E85F0100010A210020B2, dni: E85F, endpoint: 01, cluster: 0001, size: 0A, attrId: 0021, encoding: 20, command: 01, value: B2
dev:72020-04-21 10:49:45.765 am debugPARSE START---------------------
dev:72020-04-21 10:49:45.021 am debugcmds: [he raw 0xE85F 1 0x01 0x0001 {10 00 00 21 00}, delay 2000]
dev:72020-04-21 10:49:44.989 am debugrefresh() model='lumi.curtain.hagl04'
dev:72020-04-21 10:49:44.922 am infomakeSchedule()
dev:72020-04-21 10:49:44.913 am debugold model = lumi.curtain.hagl04, new model=lumi.curtain.hagl04
dev:72020-04-21 10:49:44.909 am infoinitializeAdditional()
dev:72020-04-21 10:49:44.877 am infoinitialize()
Now I have another question you might be able to answer. How can I enable "Alexa, open the bedroom curtains"? I'm guessing I get the Alexa app installed and look into configuring it? Any knowledge of Alexa integrations?
It does look like all is in order, I will clean up the driver and release it soon then. I'd probably consider this driver feature complete, but it's possible to catch and show that the curtain is in charging/battery/power supply mode, I see the messages in the log. I think I'd like to add that part if you don't mind testing that as well?
From what I can see in the logs it has 2 states: "Battery powered" and "DC source", there is no separate charging state reported. I think I will just call them "battery" and "DC" in Current States, what do you think? I'll add it when I clean up the rest.
EDIT: There is a standard attribute to use, so I will use that: powerSource - ENUM ["battery", "dc", "mains", "unknown"]
I don't personally use Alexa, but from my understanding you'd end up with having to use "on" and "off" unless you setup a routine:
Not sure if the driver has to support on and off for that to work though, do tell me if that is needed. @ogiewon, do you know?
I don't believe Hubitat's Alexa Skill support curtains/blinds, but I am not 100% sure. I know it does support Switches and Dimmers, so that is definitely an option. Just add
capability "Switch"
and the corresponding on() and off() commands which can simply call the open() and close() commands.
If you add Set Level functionality, perhaps it could simply call the Set Position command.
Thank you. Ok, I will do that, I don't use any integrations with anything so far, but I do see that many of them needs workarounds the moment it's not a light or a simple switch. At least with this added it is more "compatible" than without.
Sure. I don't mind seeing this through to completion. I said I would and I want to help the community...
Yea it looks like something definitely needs to be added within the driver. I added the Hubitat built in Alexa Skill app and then enabled the skill in my Alexa App on my iPhone. It found a couple switches and sensors in Hubitat but not the curtains. And this is what I see in the Hubitat Alexa Skill app settings:
Can we make it a dimmer instead of a switch? This way it can be set to partially open the curtains using "Dim to 50%" etc....? Is there any downside to it being dimmer? If so a switch will be much better than nothing...
Great, there is now a new version, it should have everything, included correct power source. It looks like it switched to DC power when at 99% charged, then at 100% it went back to "battery". Do try it at some point.
It is now exposed as a dimming light. So there is on, off and setlevel.
EDIT: Refresh will get the current battery level and power source as well as the current position.
Yep. I see all that now:
And I refreshed the Skill on my iPhone and the curtains took awhile but they finally showed up as a dimmable bulb. I can't test now but I will in the AM:
And FYI here is the description of the Hubitat skill in the Alexa iPhone App (doesn't mention window shades):
