[RELEASE] Aeon-Labs DSC06106 Smart Energy Switch
FYI - @bobbyD recommends to leave descriptionText logging off. I usually turn it on for the devices in an automation only when I create/test the automation. And turn it off promptly after that.
It leaves more room in the logs to catch errors - making Hubitat Support's task easier, should you need their help.
I'll check on that null error.. that shouldn't happen..
So now that that as of June 5 this is in 2.2.1 firmware I assume we should use that instead?
Ever find the issue with the null error? I can't check into my Hub at the moment due to an issue with my RPi so I can't yet upgrade or see if the nulls are still happening at the moment.
Yea.. Every now and then the device sends a malformed report that has no data.. The built-in driver in 2.2.1 checks for this issue
Sounds good. I'll update firmware and switch drivers when I get back onsite.
Is there a firmware file that works with @bcopeland updater? Also, what is the name of the built in driver to use?
I’m not aware of any firmware
Maybe he meant update firmware on the hub.
Correct
I'm trying to use the built in driver but getting this error when I try to Configure:
[error]groovy.lang.GroovyRuntimeException: Could not find matching constructor for: hubitat.device.HubAction(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryGet, hubitat.device.Protocol) (pollDeviceData)
What platform version is on your Hubitat?
Currently, 2.2.2.129.
Running the stock Aeotec Smart Energy Switch driver on 2.2.3.119, it still crashes in config with the same HubAction error.
However, I pulled the driver from GitHub and tried it. It works just fine -- config passed and it is reporting power, voltage, energy and switch status just fine.
Thanks for sharing, default driver wasn't working for me either. I also created a device from github and now it works.
I'm having the same issue... This is my first switch and i can't get it to toggle... Not too happy so far.
Getting that on newest hubitat firmware.
Same exception here. The side effect is that the switch state does not update from on to off or vice versa unless a manual refresh or poll is invoked
I moved back to the older code linked above and it works ok.
Can confirm. Still happening on Hub firmware 2.2.5.131
Tagging @bcopeland in case any of us seeing the error are doing something wrong on our end. Thank you!
Wow.. not sure how that got missed.. Will be fixed in next release
