Does the latest driver work well with the v3.01 release of ZEN27 firmware?
I stopped using these drivers because I found the ones below instead. They're more up to date and are being actively maintained
It will work if you have them paired without security. If you paired with S2 you have to modify it to get it work. Here is another one which will work on all security and has all the advanced settings as well: [RELEASE] Zooz ZEN Switches Advanced Drivers
On the Zen27 - Is it possible to have the Upper Paddle x3 ONLY push button 5, and not enter inclusion mode?
From the documentation...
3 x tap: enter inclusion (pairing) mode; Scene 2, attribute 04 (button 5)
Or, perhaps another question - Should I care if I enter inclusion mode a bunch?
Use my custom driver linked above, coupled with the newest firmware, yes you can disable the 3x taps for inclusion/exclusion mode from the settings on the ZEN27. No it does not hurt anything but I found it annoying.
