Release 2.3.9.135 Available
Changes from 2.3.8.140
Platform Changes
- Z-Wave Long Range support for C-8 and C-8 PRO hubs. (To include using Long Range, you must use SmartStart)
- Brand new Dashboards page that looks similar to Rooms, Devices, and Apps.
- New local Dashboards 2.0 with updated look/feel and drag/drop design functionality.
- Basic support for IntelliJ Idea based development using a simple hub code upload plugin.
- Improved restore confirmation dialog.
New Apps
- New Visual Rules Builder app.
New Devices
- Shelly Z-Wave Plug
- Minoston MP31ZP Smart Plug
- MCO Home Touch Panel Switch (510 Series)
- MCO Home Dimmer Switch (MH-DT511)
- Swidget Z-Wave Dimmer
- Swidget Z-Wave Switch
- Swidget Z-Wave Switch Multisensor
- Swidget Z-Wave Dimmer Multisensor
- MCO Home Occupancy Sensor
- MCO Home Air Quality Sensor (A2-ZW)
- MCO Home Micro Switch (MH-S220)
- MCO Home IR Thermostat (IR2900-ZW)
New Compatible Devices
- MCO Home TPS (MH-S511) using MCO Home Touch Panel Switch driver
- MCO Home TPS (MH-S512) using MCO Home Touch Panel Switch driver
- MCO Home TPS (MH-S513) using MCO Home Touch Panel Switch driver
- MCO Home Occupancy Sensor (OS11) using MCO Home Occupancy Sensor Driver
- MCO Home Occupancy Sensor (OS12) using MCO Home Occupancy Sensor Driver
- MCO Home Dry Contact Micro Switch (MH-DS221) using MCO Home Micro Switch driver
- Linkind Smart Dimmer Switch using Generic Matter Dimmer
- ThirdReality Garage Door Tilt Sensor using Generic Zigbee Contact Sensor (no temp)
Bug Fixes
- Fix configure() bug in Generic Z-wave Plus Thermostat Driver
- Fix supportedThermostatModes invalid format in Heatit Z-TRM3 driver.
- Improvements to supervision encapsulation for Z-Wave S2 devices, in built-in drivers, preventing false duplicate detection/drops on outgoing packets.
- Fixed Advanced RGB(W) driver(s) refresh issues (hopefully all of them).
- Rule 5.1:
- Fixed %date% for Stays triggers.
- Fixed Time Since Event for decimal event values.
- Fixed sendMsg method in Onkyo AVR driver.
- Fixed Z-Wave device fingerprint matching, specifically when using mfr, prod and deviceId style fingerprints.
Release 2.3.9.136 Available
Changes from 2.3.9.135
Platform Changes
- Added support for clock and weather tiles (for built-in OpenWeather driver) to Easy dashboards. [check this post for more details ]
- Added support for arbitrary fan/thermostat modes to Fan and Thermostat tiles on Easy dashboards.
Bug Fixes
- Removed HTML from tooltips on Logs page and Easy dashboards.
- Fixed the issue with HSM tile not updating status.
Release 2.3.9.141 Available
Changes from 2.3.9.136
Platform Changes
- Added cloud support for Easy dashboards.
- Added drag and drop support for local Hubitat dashboards.
Bug Fixes
- Fixed runaway background z-wave exclusion when user clicks Cancel in remove device dialog.
- Removed full device list in dashboard configuration dialog to free up screen space.
- Basic Rule: Fixed Only Between Two Times Restriction.
Release 2.3.9.142 Available
Changes from 2.3.9.141
Bug Fixes
- Fixed dashboard background and scrolling (bug introduced in .141).
- Easy dashboard fan icon now grays out when the fan is off.
- Easy dashboard home link now follows Navigation to - Dashboards page check in dashboard options.
- Rule 5.1: Fixed cancel rule actions for delay.
Release 2.3.9.143 Available
Changes from 2.3.9.142
Bug Fixes
- Fixed broken drag/drop on Hubitat dashboards with non-fixed cell width/height.
- Easy dashboard thermostat icon/background now reflect on/off status for the device.
- Fixed the cause of "Layout was Null" error message for Hubitat dashboards.
Release 2.3.9.147 Available
Changes from 2.3.9.143
Platform Changes
- Added Easy dashboards to legacy dashboard menu page (used by mobile app, too).
- Added drag and drop support to cloud Hubitat dashboards.
- Added a Back button to Easy dashboards if there is any browse history available (e.g. in mobile app).
New Devices
- Jasco PRO Water Leak Sensor
- Jasco PRO Plugin Smart Switch
- Third Reality Vibration Sensor
- NodOn 1 relay module (SIN-4-1-20) using Generic Zigbee Switch
- NodOn dual relay (SIN-4-2-20) using Generic Zigbee Multi-Endpoint Switch
- NodOn metering relay (SIN-4-1-21) using Generic Zigbee Outlet
- IKEA Ormanas LED Strip using Advanced Zigbee RGBW Bulb
- IKEA TRADFRI bulb E27 WW globe 806lm using Advanced Zigbee bulb
- IKEA TRADFRI bulb GU10 WW 345lm8 using Advanced Zigbee bulb
- IKEA TRADFRI bulb E14 WS candle 470lm using Advanced Zigbee CT bulb
- frient Zigbee Range Extender REXZB-111 using kea TRADFRI Signal Repeater
Bug Fixes
- Rule 5.1: Fixed Time Since Event with variable value.
- Basic Rule: Fixed issue with Restrictions.
- Fixed optional tile toggle mix-up when creating Easy dashboard.
Release 2.3.9.150 Available
Changes from 2.3.9.147
Platform Changes
- Improved drag/drop on Hubitat dashboards.
- Added individual button naming to Easy dashboard button tiles.
- Added separator and media player tiles to Easy dashboards.
- Added an option to pre-populate Easy dashboard with all of the room's devices.
[check out this post for more details on the new Easy Dashboard features]
New Devices
- TouchWand WallWand
- TouchWand GP9000
Bug Fixes
- Got rid of "empty" fan and thermostat modes on Easy dashboard.
- Synchornized cloud Easy dashboard to match local Easy dashboard.
Release 2.3.9.153 Available
Changes from 2.3.9.150
Platform Changes
- Added PIN security to Easy dashboard and Hubitat Safety monitor tile.
- Added calendar tile to Easy dashboard.
- Added background color and icon customization to Easy dashboard.
Check out this post for more details
Bug Fixes
- Fixed some drag and drop issues with Hubitat dashboard.
- Room Lights: Fixed Physical selection for Conditions and Disable/Enable.
Release 2.3.9.154 Available
Changes from 2.3.9.153
Bug Fixes
- Fixed wrong buttons showing on the Add Device page.
- Fixed an issue preventing some hubs from creating backups compatible with Z-Wave LR.
- Basic Rule: Fixed error thrown with multiple thermostats selected.
New Driver Features
- Added 3-Way configuration options to Zooz Zen32/Zen72/Zen71
