Ok so my workaround is the only way. That's a bummer.
I have another question unrelated to the first. The clone rule option will list all rules from both rule machines. I had thought this was to be a very easy way to transfer rules from 4.1 to 5. However the legacy rules simply give an error.
Is this something your working on to do as I've suggested and move rules over? Or do the legacy rules not belong there?
The older Rule Machine and Rule 5 are not compatible. When I brought this up in Beta testing, it was (in so many words) said that these apps were so different there is no possible way to make one type import into another.
So I not sure it is so much of a bug as it is a limitation of how these work behind the scenes. I don't think there is much hope of importing one to another, and frankly Bruce is right, why would you want to?
If you are changing something like wanting to use Predicates, you probably should be rethinking (and likely rewriting) the whole thing anyway. By the time you delete, insert, and change things it isn't the old rule at that point.
Maybe Bruce would be able to put a warning in the UI that says to not try and clone or import old Rule into Rule 5?
I had a feeling that was the way. I had also tried exporting and importing manually, only to get the same error so yes I ended up doing exactly that. Rewriting from scratch
As to why switch? The writing on the wall says global variables are going away once rule machine 4.1 is retired, and so one way or another any rules which use them will have to move. I'm just getting a head start on it.
No, "retired" means only that you cannot create new rules in this version. New Rule versions have been introduced several times in the past, and some people still have rules dating back to the original version. There is no reason to change your rules if everything is working fine--though wanting to test things or try new features is certainly valid in itself.
I'm one of those people with Rules extending back years:
One interesting element of that is... this is not the same hub as they originated on. No surprise to those that have done this as well, but those Rules were all created on a C-3 and the whole backup was restored onto a C-5 about 2 months ago. The C-3 is retired now, back in its original box. The Rules never missed a beat during or after migration.
If so, this is a bug. It should only list the rules for that particular parent.
Checked, this is not the case. Rule Machine Legacy only offers its child rules for export/import/clone, and likewise Rule Machine only offers Rule 5.0 rules for that.
And, as documented in the release notes, it is not possible to import Rule-4.1 rules into Rule Machine:
Yes thanks Bruce. I can confirm now after updating to 2.2.8.138 that it is listing rules available to clone as you have stated. The original post was under 2.2.8.136.and it was showing all rules at the time. But no longer.
Ok but when legacy is retired, will there still be global variables for those 4.1 and older rules? I had thought that once the app is gone they'll go with it. If not then it'll save me alot of unnecessary work.
I had a couple of Global Variables setup for regression testing of HubConnect but maybe a week or two ago I deleted a lot of the structure of my test environment... ST was blown away, and Global Variables. I guess it's just too much fun to discard things
Again, "retirement" just means that you won't be able to install it as new. Existing installations will not break. So, as long as you keep Rule Machine Legacy (the parent app) around, global variables will continue to work. That is where they are stored. And you can't remove the parent app without removing all child apps in the process--the child apps being rules (verison 4.x and older)--so there's no need to worry about these two items separately. Unless you accidentally remove it and disregard the warning in the UI that will also remove all rules, of course.
Unfortunately if the device become active again before the timer expires, the job doesn't actually cancel and remains in the job list and then the switch duly turns off.
You don't really need a 'cancelable' delay (although you can). The way to do this is use 'Wait for Elapsed Time' to get the delay. Like all Waits, it is cancelled automatically if the rule is triggered.
