I'm seeing a few things with the new firmware. Button 5.0 crashes on me with a Groovy error on line 68. I'm selecting a Wallmote device. Select Held, release and other options then it crashes.
RM 5.0 when go through creating rules sometime when you are done making your selection and the screen updates it acts like you saved but you didn't. SO, you are left back at the selection screen again. This happens on prediction, Trigger and Action. I think is some with the UI. If you go through it the original selections are made and available.
Thanks, bravenel. I think I have sorted out the button issue. Had to removed Reboot and re-install. That seemed to work.
RM Rule: I will send once I recreate another rule. It may not be until the weekend. I was moving over the rules that I can take advantage of the predicative feature.
Here is the Button 5.0 crashing. I have existing Button 3.1. childs. I tried to add a 5.0 just to see how it works and it crashed. Had to delete the child to make it go away, I could not interact with it after those errors. Will try rebooting.
Reboot seems to have fixed the BC 5.0 error I posted, at least I cant get it to crash anymore.
I never removed the app, since I have a bunch of 3.1 child still in there.
I have found an issue that is more pressing!
I have two hubs C5 is all my legacy devices and C7 that only has 1 S2 device > Moving devices to C7. Now that they have been up and running for the past 12 hours.
When you going to logs the hub hangs both devices. I can get into everything else but not the log section.
I did attempt to reboot. It didn't fix that. As soon as it reboots it is hung.
Both hubs are the same.
