With current issues with webcore and latest firmware versions, I've rolled back and started moving my pistons to RM. I have one that is a lot more complex than others, it controls my downstairs lighting based on lux levels, time of day and whether there is motion.
I'm not sure how to start with this in RM, so would appreciate any advice or whether there are any apps that would make this a bit easier to set up?
Good luck with that. You will probably need about 6 - 8 rules to do that.
Here is a piston for my dining room light that I have split into 2 rules. Mon to Thurs and Fri to Sun.
Apologizing in advance as I’m only reading your use description, since pistons are very foreign to me. Can you not do this with Simple Lighting and Motion Lighting apps instead?
Why a 10 minutes change in the timing for Friday to Sunday? It's an indoor light. I'm analyzing your piston, I "translated" all my pistons to RM and SL
Its 1 hr and 10 minutes.
The reason being we are up later at the weekends than during the week.
This means when we are away it looks like we are at home and up later at the weekends.
No other reason.
Your piston is very interesting, but I believe you must split it and shrink it, I don't understand why you have 2 separate triggers for different times, I mean one for night and one for day time but anyway the lux and the motion defines the rule, I think you can eliminate the daytime times completely, but, I can't find the special part of your piston in RM, the random turn off between 10 minutes and 1 hour. I'm looking.
I'm not being rude, my first language is not English, sorry if my post sounds like rude. Just trying to help.
You will have to say a lot worse for me to take things as being rude. Anyway.
The reason it is written like this is that the lights will always turn on between the set times, 09:00 - 22:33 Mon to Thu, if the lux level is below a certain level, whether we are at home or not.
22:33 - 09:00, the lights will turn on if the lux is below a certain level and there is motion.
As I've said before, the lights will always come on and turn off every day whether we are at home or not, hopefully giving the impression that someone is home.
I know I've asked this before but thought I'd give a very gentle nudge in case it may be possible.
In the other app ( ) there is the ability to put in random delays/wait times between 2 values.
e.g. wait randomly between 37 and 78 minutes.
seconding what @BorrisTheCat said this is a fairly straight forward setup in rooms manager. full disclosure i am the developer of the app.
this is one of the typical setup users use rooms manager for. once you have the app installed shouldnt take the first one more than 30 mins to setup. after that for each room will probably take 10 mins.
should you need any help setting up i would be glad to help answer any questions.
Sorry to be thick here but this is still early days for me with RM but I don't see how I can set up 2 actions within one rule.
Are you saying that the first rule waits 37 minutes on false and then runs a second rule that turns the light off after a random wait.
I could see how that would work.
Did you test the setting >7 for illuminance? I believe you want to turn on the lights if the illuminance is below 7, I think its <7, but maybe I'm just confusing the logic. Thanks for posting the rule.
Edit: curious, where is located the lux sensor, in the outdoor?
