Do the DNI is this.
So you might need to go into Devices and remove any duplicates or all items and reinstall your app again and start over?
Really hard to tell, but it's basically tell you that you have two devices listed as the exact same and it doesn't know what it do as these should be unique.
Thanks for the info! I did have a Ring Virtual Camera in Devices that I was able to remove. I tried uninstalling "Unofficial Ring Connect" from Hubitat Package Manager and get the following Fatal Error.
Now when I try to add New User App I have "Unofficial Ring Connect" listed 3 times. This must be the problem however I can't figure out how to remove everything to start over.
To manually remove the apps, go to the “Apps” menu and instead of going to Hubitat Package Manager, scroll down until you see “Unofficial Ring Connect”. Click on the app and click on the red “Remove” button on the bottom left. You will need to remove all 3 apps.
You should then go to your devices and ensure that you do the same for all of them that weren’t removed by the app - click on the red “Remove Device” on the bottom right. If it tells you the device is used by an app, you will want to click on the links to the right of “In Use By” and remove the device from those apps.
The "Unofficial Ring Connect" app is actually not even listed under Apps I guess because it never completely installs while going through the initial setup before I get the "Unexpected Error" message mentioned above. It's only listed 3 times under the "+Add User App" button. I have been able to remove anything that refers to "Ring" under the Devices.
Two things that I would try if you are still getting the error:
Reboot the hub (Not sure it would do anything, but who knows!)
I would try doing a back-up (saved locally) and then restore it (from file) - that can help resolve some database issues... though I wouldn’t know that this would fit in that category...
Others in the forum might have other/better ideas...
Agreed.
I'd definitely reboot your hub through the settings UX, remove all the related apps and devices, reboot again, and then re-install if everything looks good and clean.
I ended up going to "Apps Code" and found 3 copies of the "Hubitat Ring Integration(Unoffical)" and just deleted those then went to "Drivers Code" and deleted "Ring Virtual Camera" but was unable to delete "Ring API Virtual Device"
Now I no longer have 3 copies of "Unofficial Ring Connect" under the "+Add User App" button however Hubitat Package Manager still reports that I have "Hubitat Ring Integration (Unofficial) and I still get the "Fatal error occurred, rolling back" when I try to uninstall it I guess because I still have a copy of "Ring API Virtual Device" listed under Drivers Code. I'm just not sure why it won't let me remove it.
I did do a reboot of the hub as you suggested but have yet to try doing a back-up and restore.
[EDIT] It looks like I can't remove the "Ring API Virtual Device" under Drivers Code because it reports it is being used by [Location]
I tried doing a back-up to local file and restore and am experiencing the same problems.
I tried doing a repair in Hubitat Package Manager and that didn't help either.
So basically, I can't completely install and can't uninstall to do a clean install. If anyone else has any suggestions I would sure appreciate any help I can get. Thanks!
I ran into this issue when I accidentally share the ring devices on hub mesh and unable to delete.
There is a way to force delete the device but take it as you own risk cause deleting a wrong device could be fatal without backup or knowing how to recover.
@Navat604@SoundersDude Thanks for the suggestions. i think I will contact support to try and get "Hubitat Ring Integration (Unofficial)" completely removed from Hubitat Package Manager so I can start over. Thanks again for your help!
Here's the response I got from Customer Support Services...
Thank you for your time and continued support. For help with custom apps and drivers, I suggest reaching out to our active community members. You may search their posts or post your own at community.hubitat.com.
If anyone else has any other ideas how to solve this problem I would greatly appreciate it. Thanks!
Have you done a "soft reset" where you do a backup, then do a soft reset, then a restore (not just a backup/restore)--go to your hub's IP address, port 8081 then:
@rob9 Thanks for the reply! I had not tried the soft reset part. After doing the soft reset and restoring from backup, I tried again and am still getting all the mentioned errors above.
Apologies in advance..a short search through the 496 messages in this thread didn't yield an answer, but I'll admit, I didn't read every one so I might be asking something that's been covered already.
What's the safest recommended way to upgrade this app and drivers. I've still got a version from the original developer (i.e. before ring added 2fa) for most of my code. I believe I have one device or something I added later from the newer repository. But it all played well together so I left it.
Some number of months ago though 2fa broke my setup and I noticed the version history in the latest app code notes an update for 2fa I don't have. So now I'm trying to figure out how I best upgrade everything and there's a few stories of things going South on this thread, so I figured it's worth confirming the recommended process... In guessing:
Remove devices
Remove app
Update groovy code
Reinstall app
Reinstall devices
That the right order to do it in to just update everything to the latest in the repository?
Is there another way that doesn't recreate all the devices? As I'm pretty sure that breaks all my RM code that uses them.. Or are all other options just playing with fire so I should deal with it?
As I recall, following the steps you outlined is the best approach. You may want to create placeholders (virtual devices) if they are used in Apps.
It is possible to just update the code (via Rule Machine works) but this will not work well and will cause issues down the line where new device discovery will no work properly.
