Is there an app for HE that can turn on / off lights randomly to make it look like someones home? Thanks
I have one in webcore that works very well.
Welcome to Hubitat!
Maybe Vacation Lighting Director, available in Hubitat Package Manager? I haven't used it, but @nh.schottfam has some pretty good apps in general.
If you haven't tried HPM yet, you should. It makes discovering and installing apps much easier. T
Ok I think this is stable enough now to release as a beta. This is a package manager for Hubitat that makes installing and managing your apps and drivers easier. It allows you to install an app (for example Ecobee suite that has 13 apps and 2 drivers) with "one click" instead of having to do each one manually. It also automatically checks to see if new versions of anything installed using this app are available. As time goes on I hope more developers will come on board (if apps you use aren't su…
Hi, there is also - [RELEASE] At Home Simulator
I Haven't used any of them, I wrote my own using RM. I might try one of these though
Thanks, I'll check this out.
Just to give you ideas, here's my RM rule that I use to turn on my downstairs hall and loo light to look like someone is home when we are away.
I have different ones for different rooms.
BTW. Spot the mistake that I've just noticed. You can tell we haven't been away for some time.
Vacation Lighting Director requires the use of modes. I do not use modes and cannot use that package.
