And this one is really ugly. This is the python script running on a raspberry pi that requests the sensor data from the Airthings sensor via a bluetooth dongle. IIRC I just set it up with a cron job that passes in the MAC address of the sensor to pull the data from. It uses the name programmed into the sensor as the name it reports under via MQTT. The MQTT server address is hard coded about 1/2 the way down. I'm publishing it twice - once to an internal MQTT server, and once to IFTTT (replace the key with your own if you want to try that one). It's honestly not all that well thought out, and is obviously just hacked together from the example script provided by Airthings... but as I said before - it's been working for me for months so I'm not going to touch it now...
# MIT License
# Copyright (c) 2018 Airthings AS
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# https://airthings.com
from bluepy.btle import UUID, Peripheral
from datetime import datetime
import sys
from time import time, sleep
import struct
import re
import paho.mqtt.client as paho
import json
import requests
class Sensor:
def __init__(self, name, uuid, format_type, unit, scale):
self.name = name
self.uuid = uuid
self.format_type = format_type
self.unit = unit
self.scale = scale
if len(sys.argv) < 2:
print "USAGE: read_wave.py \"MAC\"\n where MAC is the address of the Wave and on the format AA:BB:CC:DD:EE:FF"
sys.exit(1)
if not re.match("[0-9a-f]{2}([:])[0-9a-f]{2}(\\1[0-9a-f]{2}){4}$", sys.argv[1].lower()):
sys.exit(1)
try:
sensors = []
sensors.append(Sensor("DateTime", UUID(0x2A08), 'HBBBBB', "\t", 0))
sensors.append(Sensor("Temperature", UUID(0x2A6E), 'h', "deg C\t", 1.0/100.0))
sensors.append(Sensor("Humidity", UUID(0x2A6F), 'H', "%\t\t", 1.0/100.0))
sensors.append(Sensor("Radon 24h avg", "b42e01aa-ade7-11e4-89d3-123b93f75cba", 'H', "Bq/m3\t", 1.0))
sensors.append(Sensor("Radon long term", "b42e0a4c-ade7-11e4-89d3-123b93f75cba", 'H', "Bq/m3\t", 1.0))
p = Peripheral(sys.argv[1])
def on_publish(client, userdata, mid):
print "Message Published...."
client = paho.Client()
client.connect("192.168.1.200", 1883, 45)
# Print header row
str_header = "\t"
for s in sensors:
str_header += s.name + "\t"
print str_header
# Get and print sensor data
str_out = ""
date = ""
for s in sensors:
ch = p.getCharacteristics(uuid=s.uuid)[0]
if (ch.supportsRead()):
val = ch.read()
val = struct.unpack(s.format_type, val)
if s.name == "DateTime":
date = str(datetime(val[0], val[1], val[2], val[3], val[4], val[5])) + s.unit
str_out += date
str_out += " "
str_out += sys.argv[2]
else:
str_out += str(val[0] * s.scale) + " " + s.unit
data = {}
data['SensorID'] = sys.argv[2]
data['Name'] = s.name
data['Value'] = val[0]
data['Scale'] = s.scale
data['Unit'] = s.unit
data['Timestamp'] = date
client.publish("house/AirWave/Data/" + s.name,json.dumps(data),qos=1,retain=True)
URL = "https://maker.ifttt.com/trigger/airSensor_" + s.name + "/with/key/<yourkey>"
r = requests.get(url = URL, params = {'value1':val[0],'value2':s.scale,'value3':s.unit})
print str_out
client.publish("house/AirWave/Summary", str_out,qos=1,retain=True)
finally:
client.disconnect()
