RA2 keypad, is it possible to run events when buttons are held, or double tapped?
I use Radio RA2 and just got Hubitat last night setting up some integrations. When I use the built in button configurator it seems like it's only possible to select a button and select "is pressed" as an action, no "press and hold" etc. I tried advanced button config the 3rd party app but it seems to be the same.
Basically what I'm trying to do is this so I'd love any suggestions. I have a keypad in my kitchen and one in the front foyer, both have an "Evening" button on them. In the kitchen, if that button is pressed it sets all the kitchen lights to certain levels (done on the RA2 main repeater not Hubitat). Then on the front foyer one if I press the evening button, it sets all the lights on the first floor to set levels as well but NOT the kitchen lights.
What I'd love to have happen is if I press and hold, or double tap the kitchen evening button, it also runs the foyer evening scene (basically presses the foyer's evening button, or alternatively hubitat could just set the lights itself). Then same with the front foyer, if I press it once it sets the first floor lights without the kitchen, but if I press and hold it then it also triggers the kitchens evening scene as well.
Also side question but how long should it take to respond if I have keypad buttons run things like Hue lights or Nanoleaf? If I have a keypad button set to toggle the Nanoleaf or turn on Hue lights, it takes a good 3-5 seconds before it actually does anything so I end up pressing the keypad button a few times.
Thanks!
Just wanted to quickly add using the 3rd party advanced button control does seem to toggle the Hue and Nanoleaf way faster almost instant compared to the built in one.
Held and double tapped are not supported for Lutron Keypads at the moment. You could get held on it by calling it a Pico instead of a Keypad (Lutron doesn't know the difference). Picos don't support double tap either. The problem with double tap for these is that it has to be implemented through timing, as opposed to devices that actually report it.
Thanks held is preferred over double tap anynway. Was wondering if adding it as a Pico would work so I'll give that a try and mess around with that.
How many buttons does your keypad have? Not counting the raise/lower buttons.
They are all different, the kitchen one has 6 at the moment as I haven't ordered the custom engraving but soon it will have 5 in total (the 4 space and then 1). The front foyer one is the same, but some of the others just have 3 in total.
Up to 5 will work fine as a Pico. You may want to play around with the held timing on the device page.
Great thanks so much I'll give it a try now and see how it goes. I'll never have more than 5 as I try to keep the keypads with as minimum number of buttons as possible as I prefer the bottom one always being All Off, so I find it looks better when there's at least 1 space between the top buttons and the All Off one. 6 looks too cluttered, harder to quickly hit one without paying attention. :slight_smile:
Hi, came on this thread searching for how to implement 'held' on a 6-button +R/L Lutron Keypad. Is it possible to duplicate the keypad as a Pico but only for the buttons I need to work off the 'held' command? I'd like to map buttons 1, 2, 3, 18 and 19 to held commands but leave the other buttons alone (on the original device) as there are some pretty lengthy rules operating them that I'd rather not have to re-create. Guessing this is a stretch but thought I'd try. Thanks
Not possible with the built-in drivers. Pico's have weird button number mapping, while a keypad does not. This would require a custom driver.
This is the reason I still keep HomeSeer running at the same time as Hubitat as I just use it for any held, or double tap type actions. Not sure why Hubitat doesn't support it as it's definitely a Hubitat limitation as even Indigo supports this.
Not so much a "limitation" as it is something that (a) Lutron doesn't support natively, and (b) no one as ever asked for before. The latter is more significant than the former, because obviously we implemented things for Pico that Lutron doesn't support.
We can add this to the feature request list for Lutron drivers.
I would kindly add my name to the list of those asking for both items to be added to the feature request for the Lutron Driver:
  1. Held Button functionality for Lutron Keypads,
  2. Keypad Button Double Click with in a specific amount of time (I understand that this will be more complicated and involved).
In the mean time I am trying the workaround of setting up the Lutron Keypad device as a pico device ('p') yet it does not seem to be working. I have tried various values of set delay for hold under the device preferences yet it seems with the latest version even a momentary button press (under ~50 ms) is being counted as a held button despite having the delay time for hold set much higher. I am using the current log viewer to see this. Does the workaround of setting up the Keypad (at least for button component numbers 2,3,4,5,6) as a pico no longer work?
I also am seeing a strange error show up three times in the log when this 'held' without being held occurs (but might just be related to an LED status from a Keypad not matching a pico):
dev:1302021-12-19 01:39:55.286 am infoGallery Main Keypad button 1 was held
dev:372021-12-19 01:39:54.870 am inforcvd: DEVICE,82,86,9,0
dev:372021-12-19 01:39:54.838 am inforcvd: DEVICE,82,82,9,1
dev:372021-12-19 01:39:54.774 am inforcvd: DEVICE,82,81,9,1
dev:1302021-12-19 01:39:54.755 am errorjava.lang.NullPointerException: Cannot invoke method toInteger() on null object on line 70 (method parse)
dev:372021-12-19 01:39:54.742 am inforcvd: DEVICE,81,86,9,0
dev:1302021-12-19 01:39:54.672 am errorjava.lang.NullPointerException: Cannot invoke method toInteger() on null object on line 70 (method parse)
dev:372021-12-19 01:39:54.659 am inforcvd: DEVICE,81,82,9,1
dev:1302021-12-19 01:39:54.567 am errorjava.lang.NullPointerException: Cannot invoke method toInteger() on null object on line 70 (method parse)
dev:372021-12-19 01:39:54.552 am inforcvd: DEVICE,81,81,9,1
This won't work, ever. Picos have odd button number mappings, so drivers can't be used with Lutron keypads.
Is there any idea or update as to when double tap (or even multitap) for Lutron RA2 Keypads might be added? I understand that such a feature will need to be implemented through timing within the Hubitat, as the RA2 devices don't report double (or multitap) natively.
Basically I just would like a way to Trigger a rule if a particular button is pressed two times with in a set period of time (say 1 second or even 500ms).
Or maybe this is something that could be implemented through the rule machine (or something else that exists today)? I am a novice on using Rules and if/how timing of multiple events within a specific period is something that can be accomplished (something like a delay and wait after the first press).
Any insight or update would be appreciated!
We are still working on it. Double tap for Picos is in the upcoming 2.3.1 release. Keypads will take a bit longer.
What are your goals with the multiple presses? If it's turning on/off lights, I wrote a custom app that can do this. If you want to perform arbitrary actions (turn on/off lights, change mode, whatever), then this won't help, though some people in the past have written rules to handle this kind of thing. You can do basically anything in a rule, though it's a bit more effort.
Here's one example, though nowadays you'd need a Rule with a "Button" trigger for each button number/event (e.g., "button 1 pushed") that you want to keep track of--the "Button Device" trigger in this screenshot no longer exists, and the otherwise similar Button Controller app does not (currently?) support conditional actions. But similar idea:
Or you could wait for support in the driver. :smiley: In the meantime, some app-level workarounds like this are certainly possible.
Your reply is extremely helpful. Thank you.
So here is what I am trying to do:
I want to use a button on a Lutron RA2 Keypad to call different RA2 Scenes based on the number of presses of that button with in a fixed time period. I am an expert with regards to RA2 commands/programming (I know the RA2 Integration Protocol and system behavior extremely well).
So for a particular RA2 Keypad where I want to implement multi press functionality via Hubitat I first would strip away any programming with in RA2 system design software for the particular button.
Then I simply want Hubitat to detect how many times a specific RA2 Keypad button is press with in a fixed amount of time (say 1/2 a second) and act accordingly based on the number of detected presses. Clearly I understand the lag time implications in that single press scenes would experience (ie a half a second plus processing/communication time of RA2 and Hubitat).
If the keypad button is pressed only once then Hubitat would call a specific RA2 scene either by calling (ie pressing) a virtual phantom/button on the RA2 Main Repeater that is programmed with the scene OR by a calling (ie pressing) a button on a virtual/phantom RA2 Keypad that is programmed with the desired scene.
But if the button is pressed twice then Hubitat would call (ie press) a different RA2 virtual/phantom button programmed with desire scene for two presses.
This would be would go up to maybe three or four presses within a half second.
Does that make sense? As you can probably tell I am not much of a programmer or scripter but am willing to learn and experiment. I understand simple IF ELSEIF but the hard part is the timing component!
Also, can you please let me know where I could find the custom app you wrote?
Can do it in Node Red too
So I upgraded to 2.3.1 a few days back. I see "Double Tap" as a command for my Pico remote, but my existing Button Controller does not have it that I can find. Do I have to remove that Button Controller and begin again? Or is there a way to add it and keep what's already been set up?
