Question on strobe effect when at certain levels
So I have a rule where the rear hallway lights are 100% during the day and 20% at night.
This rule has worked for months and months.
Suddenly, when running the night rule, the lights then started to strobe or flicker on and off.
So I set the night time dim level to 50% which mostly solved the problem.
However I really want the dim level to be 20%.
Thinking that bulbs were failing I bought 2 new high quality bulbs. Different brand.
Same exact behavior.
Replaced a zooz zen72 with a brand new one to see if this helps.
So far setting dim level to 20% works, but setting to 100% it flickers badly.
Setting it to 95% seems to fix it
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
I would start with Zooz's troubleshooting steps for this exact problem:
https://www.support.getzooz.com/kb/article/657-lights-flicker-with-my-zen72-dimmer-switch/
Thanks, other than making sure the bulb is listed as dimmable, how to know whether it will work without flicker?
As the support article suggests, consider wiring in a bypass. 2 (LED) bulbs may be too light of a load at lower levels.
Did you read the article?
Make sure they are compatible with TRIAC or leading-edge dimmers specifically, as mentioned there. The bypass idea above is also in the article.
Looking at a bulb on Amazon I see it states dimmable, but I do not see whether it is triac or not.
What is weird is that it worked without flicker for a long time and then suddenly started really bad flickering
Sounds like a cheap bulb going bad to me.
