Edit
{Currently running Vera with about 40 devices. Went through the wiki, supported devices and the forum to check compatibility.}
Looking at switching from Vera and need drivers for the following devices:
GoControl GC-TBZ48L Battery Powered Smart Thermostat {Works}
Intermatic HA05C Screw In Module {Works see below, basement has a 3 way and 3 pull chain lights. Z wave 3 way and the three screw in modules works well }
Leviton VRCZ4-MR 4 Zone controller with Switch {no joy}
NewTone NFS20Z 20A Load Control
Zooz ZEN27 3 way Switch (ST modified driver don't know if it works) {works}
Too big an investment and the device are serving important rolls in my HA.
I really like the Leviton's, having the zone controls at a switch is nice.
Matt
Oct 2019 bought a Hubitat elevation!
Just getting started but able to get the Intermatic HA05C Screw In Modules paired.
Added as a Generic Z-Wave Switch.
No luck with the 'Intermatic HA05C Screw In Module' for me so far. I couldn't get the Zwave scan to pick it up. I think this is the one I have and once again no joy for me. I may have been doing something wrong with this one not sure.
The Zen 27 works. Just use the generic zwave dimmer driver.
It's a bit talkative, and zooz is reportedly updating its firmware to be less chatty. Once that's done, I expect we may see a device driver for it on Hubitat.
I second the Zooz stuff. I've had great luck with every Zooz device I've tried. I had even emailed their support folks a couple times prior to my trying Hubitat (I took a brief detour down OpenHAB and Home Assistant routes... yuck) and they really did go above and beyond to try and help me.
Somewhat ironically... They are ultimately who sold me on Hubitat because I had asked the support folks if they'd heard of it and their response was a very positive "Yeah and we test all of our devices on Hubitat." So that was one of the things that made me decide to go ahead spend the $130 on my first HE Hub.
Welcome. Another thing you might want to look at for the thermostat is the App "Thermostat Scheduler". It makes it very easy to schedule times and temps. Works great with this thermostat.
Thanks all. I'll update the OP as reply's come in.
Don't know why I bought the Leviton zone version. In Vera it can trigger 6 sense's as well as the load at the device.
I'll get my GoControl thermostat tomorrow, and then can finish it.
Should work as it is right now, but I haven't tested it on a real device yet to work out the kinks. There are a ton of parameters on this thing, so plenty of code to have mistakes in.
I'm having to go back and replace my Remotec ZTS-500 thermostats, as they do not have a minimum run time or minimum off time and are cycling my HVAC way too often/too fast.
I've just completed porting my App and Driver for the Leviton VRCZ4-M04 Zone Controller from SmartThings to Hubitat Elevation. I'll probably do some additional tweaking, but you should find the current versions fully functional -- have a try and let me know?
Thanks, I don't have time right now to play with my setup, but will try to get it working next week and get you feedback.
Thanks for doing the driver, I have two of the zone controllers and find the 4 switches very useful in my old Vera setup.
