How do I register this device for admin if it was used by someone else?
Did the person from whom you purchased the hub perform a full reset first? That wipes the hub and de-registers that person's Hubitat account from being associated with the hub.
The previous owner would have to provide you the admin login/password, or initiate the transfer for you.
From the FAQ:
Log into my.hubitat.com with your current admin account and select Registered Hub then select Hub Details . On the Hub Details you will see a place where you can Replace existing Admin with a different Hubitat user. Be sure to create a Hubitat Account for your new email by visiting the following page: My Hubitat
I bought it on ebay. I don't know who the previous owner.
Presumably the eBay seller can provide that information to you?
Can you email him to remove the hubitat from his account at my.hubiat.com ?
This is a completely unacceptable answer. As long as there is some sort of verification of new ownership, hubitat should be able to de-register it for use by a new person. I bought mine from Amazon (not a private seller) and it already is registered to another admin account. There doesn't seem to be any support options for this scenario.
Tagging @support_team.
Amazon is not supposed to send out returned units, but they have been. So it is likely Support can/will help you reset the unit.
Your situation is very different than someone purchasing a “used” hub from eBay, which is of indeterminate provenance. It is not uncommon for stolen merchandise to be sold on eBay.
Sorry for the confusion. If you could please open a return case using the "Hub is not new" option, we would be glad to take care of the replacement. Unfortunately, Amazon has been known to put a returned unit back in stock from time to time.
I have this same issue. Is there a reset for this or do I have to return to Amazon?
@bobbyD see above. Do I have to return this or can you reset it remotely?
Yes, please send me a private message along with your Hubitat account and hub ID (or MAC address).
@bobbyD PM sent
@bobbyD @support_team
I have the same issue. I bought a house with hubitat system and it is registered to the previous owner. I have tried contacting the previous owner to deregister his account but he cant be bother to provide any help. My whole house system is not working now as a result as im unable to claim the hub. Are you able to help resetting the device so i can claim it and set up my house. Thanks
I ended up buying a new one. Sounds like that wont help you. Sorry.
Thanks for your reply.
If you didn't inherit the hub with an active subscription, then you should be able to perform a Full Reset following these instructions: Soft Reset | Hubitat Documentation
Otherwise I think if not able to do the Full Reset for some reason, your best bet to contact support would be to use this support form for account issues: Account Issues – Hubitat Support
