yes @snell agree...
here is a link to a new thread... with a link back to this one too
Updated Version(s):
Change(s):
Hi there, thanks so much for the effort here on this driver. I've skimmed through all 222 posts and cannot figure out if it's actually possible to turn one of the outlets on/off in a rule. I have Active Control enabled and can change the Outlet Mode on the desired outlet on my EB832 manually in the child device commands but can't seem to figure out how to expose this capability elsewhere in Hubitat. Thanks in advance for the help!
In general what you need to do (in Rule machine) is use a Custom Action. It is unfortunately not as easy as a normal switch (because of the multiple outlets and other factors) but it is pretty easy once you are used to it.
For example, when adding an action you:
Here is a screenshot of a sample I made just now, for an EB832 that would turn outlet 1 ON.
That's great, thank you. Pretty easy to setup as you say, unfortunately nothing is actually happening on the Apex when I initiate the action. To be clear, I've created a virtual switch and tied the Rule to the switch like a toggle button. See below.
Try selecting the GetCookie command in the parent device, then trying the Rule again. Sometimes the cookie expires and it does not get renewed before the commands run. I just saw this on my own while checking real quick. I will have to see if there is anything better I can do about the cookies tonight (have to get to work for now).
Sorry had to get to work as well... came back to this, ran the GetCookie command but still nothing happening. Seeing this error on the EB832 log:
dev:12442023-02-04 10:41:57.971 AMerrorgroovy.lang.MissingMethodException: No signature of method: user_driver_Snell_NSChild_EB832_1141.OutletMode() is applicable for argument types: (java.lang.Integer, java.lang.String) values: [7, AUTO]
Possible solutions: OutletMode(java.lang.String, java.lang.String) on line 6245 (method OutletMode)
dev:12442023-02-04 10:41:54.889 AMerrorgroovy.lang.MissingMethodException: No signature of method: user_driver_Snell_NSChild_EB832_1141.OutletMode() is applicable for argument types: (java.lang.Integer, java.lang.String) values: [7, OFF]
I was also trying to search the logs for what happens when I control the outlet from within the EB832 device page, since that is working. Maybe I'm missing something, but I can't get any feedback on what's happening when I send those ON/OFF/AUTO commands.
Looking at the error I think I have it figured out. The outlet number is being sent as an integer, but the function is looking for it as a string.
If you set the rule to send the first parameter as a string, does it work?
That did the trick. Thanks for all your help!
I am glad that it was solved... I am trying to think of a better way to handle it in the first place. Most people will think of the outlet as a number. It cannot get treated that way in the final code though (it has to be sent as a string because it has non-numeric characters). I will see if I can make it handle receiving both types just in case.
Could just overload the method, i.e.
def stringInteger(Integer var) {
log.debug "Integer"
stringInteger(var.toString())
def stringInteger(String var) {
log.debug "String"
Yeah, I know... I dislike overloads though. It just strikes me as a messy thing, something that was ingrained in me MANY decades ago as a programming "no no" (because those languages could not handle it well).
So a little update here. I have a filter pump on the Apex which I aimed to turn off if water sensors at the aquarium detect a leak. I tested the sensors today and the message didn't get sent to the Apex to turn the pump outlet off.
Playing around, I was able to get the comms working again by running the Get Cookie and Refresh commands on the Apex. This kind of manual intervention isn't going to work for the water leak rule. Is there any way to solve this?
Understandable. The cookie problem is an odd duck... It must have expired, but I do not know the interval. I will try some things out.
In the meantime, the workaround could be to trigger a GetCookie and such before the command... Just to make sure the cookie is valid.
Either way I will try to work out a way to make it better tonight.
EDIT:
Testing it with a cookie check every hour instead of once per day (what it currently is set for). Unfortunately this process takes a bit...
Updated Version(s):
Change(s):
any mxm support planned? have a module and happy to share logs as needed!
If you can send me the logging information when you perform a refresh, or send me a copy of the Apex's status.json file (please send either as text in a separate message, not in the main thread) then I can try to incorporate support.
I am always willing to add in new modules and features... but I do not have any specific plans.
Updated Version(s):
Change(s):
NOTE(s):
Thanks for this update!
Hi There!
I'm trying to get this running with my apex, but I'm getting an error in the Logs:
java.lang.NullPointerException: Cannot get property 'Type' on null object on line 667 (method ReceiveJSONData)
2023-09-30 04:20:56.152 PM[info] ChezGallant - Unknown Apex controller type AC5L, please let developer know
Looking at the code, there is no detection of AC5L-- not sure what hardware that corresponds to?
Thanks,
Jason
