Okay have to revive this thread
I JUST got around to doing this (mumble, mumble, never ending projects) and it seems to be working great!!!
Couple of notes:
- Disabling the Rings red wire only takes out the Rings ability to control the lights. Everything else including motion alerts / motion zones work fine.
- When installing the HS-FLS100+ G2 make sure you move the motion dial away from the "T" setting otherwise you will be in "Walk Test" mode.. and things will not go well.. not that this ever (just) happened to me of course..
relevant bit from the above link:
OMG. I finally found out what the problem is!
The device has manual dials to set motion sensor time and light sensitivity. If they are on the minimal setting (“T”), the device is put into “Walk Test” mode, in which the light always go on for 5 seconds, irrespective of any other setting. That’s why the Z-wave settings would not work. After moving the dials away from the “T” setting, everything worked as expected!
The manual should really make this clearer. I did find one table there that mentioned something about the different modes… I should have had a closer look before. I just couldn’t imagine it. I had somehow expected that the Z-wave capabilities of this device would be able to override the manual settings, and that’s why I didn’t even touch the dials. This took me forever to get sorted out!
I guess the conclusion is RTFM!!!
posting here for posterity..
edit: the sensor/switch works SO much better than trying to pull in Ring motion events from HA to Node-RED - wasn't getting all the events sometimes. Now also have illuminance and temp as well.. so yayy. Tomorrow plan on hacking my other Ring floodlight cam.
