Since I switched from H7 to H8 Pro I have a problem with devices stop to respond in webcore pistons. When I recheck them in a piston they start to work again. It is strange as those same devices respond on direct command (e.g. on/off) from Hubitat interface.
I never had similar problems with H7.
Any suggestions?
B.
I am curious what types of devices you observe this behavior with.
For me, Sengled and Innr ZigBee bulbs were specifically symptomatic, as described here. I found that when I paused then resumed (or edit and save) the piston, everything worked for some period of days or weeks.
Not a solution, but a countermeasure - I created a piston that pauses and resumes 11 bulb-related rules. It runs twice a week and I no longer observe this behavior. The ideal situation would be to learn why the commands are not being processed, but I chose a band-aid for now.
Hi,
unfortunately pause/resume did not work for me. Only rechecking non-responsive device in a Webcore pistone worked. But only for some time. As far as I can see it is happening with IKEA bulbs, IKEA socket and other non-IKEA zigbee devices. The problem is that I cannot find patern. It NEVER happened with C-7 in the past.
The only solution for me is to migrate back to C-7.
