Premium Services - Revisited
Most things with Iris were okay to control only on premise. I work away from home a week at a time so remote control would be great. This weekend I could have used remote control of garage doors when Wife locked herself out of the house and I forgot to add the custom code to the schlage lock. Fortunately I had a picture of the default codes to send her.
Did you disable Cloud Dashboards? Or haven't you created a Dashboard yet?
Because to help her, all you had to do is push the button(s) on your phone. Better yet, add it to hers too. :slight_smile:
I have created dashboards, but the majority of the time garage door openers and the Schlage Lock do not respond to the commands although apparently paired correctly. I still assume you have to be on local network, if not, this is where I'm getting confused.
Navigate to:
Apps:your dashboard
At the bottom, below your selections of devices is a pair of links:
Local LAN link to Dashboard
Cloud link to Dashboard
They seem obvious what they do but if, on you phone, while at home, follow the Cloud link. Then in you phone’s browser, save the page as an icon on your home page.
Next time you’re out and about, try that saved icon.
Remember though, the Dashboard does not ‘fix’ mesh issues. If you cannot control a device via the Device Info page, it won’t work better via a Dashboard.
https://www.howtogeek.com/196087/how-to-add-websites-to-the-home-screen-on-any-smartphone-or-tablet/
I haven't had my hub that long but what i got working first just works. No devices have dropped off. Everything just keeps working. So from that perspective you are doing great.
I always thought Hubitat had the greatest potential. I haven't changed my mind.
Thank you for the clarification. I understand how to add cloud links such as this, but everything I had read before, seemed to indicate things would only work if inside the LAN. Thank you for clarifying this is possible outside the LAN. Another HA forum that I frequent had mentioned improvement in documentation and this would be a big one.
When I get home I'm moving the hub, a "central" location is difficult in the way my house is laid out, but I"ll try to get as close as I can. I have AT&T fiber and a modem update killed my Eero setup, and I've been using their AirTies. I'll see if I can't get Eero up again to help. Last looking at a Ubiquiti setup to solidify my network.
I like being in the middle. Not an expert, but not a total newb either. Helps to draw out things that aren't quite as obvious to the less experienced with a product.
Keep in mind you could always get a set of powerline ethernet adapters, if a switch or hub with an ethernet port is not convenient. That makes for pretty flexible placement...
The following is my device of choice, whenever I have to move my hub close to the device being paired. It has a built-in ethernet port.
(P.S. to the new people: Don't forget to run a zwave repair, after you put back the Hub):
My HE hub is not even close to being centrally located in my house. While I agree that centrally locating the Hub would be ideal, for many of us it is not practical. So, instead I chose to build solid Zigbee and Z-Wave mesh networks using about 6 Iris 3210-L outlets. These repeat both Zigbee and Z-Wave. Once I added these strategically throughout the house, everything has been very reliable and performance has become very consistent. I have also standardized on Lutron Caseta for all of my Smart Light Switches and Dimmers. I am amazed at how much faster and more reliable the Lutron Clear Connect technology is compared to my old GE/Jasco Z-Wave switches.
I forgot those had both radios in them! When I was on ST, I was using a custom DTH that exposed the Z-Wave repeater as a device. Do you have a driver that does that on HE by chance?
I don't personally, but @srwhite does... :wink: (Note: I personally am only using the built-in drivers for the 3210-L for both the Zigbee and Z-Wave portions of the 3210-L)
Z-Wave side
Zigbee side
Thank you sir. Much appreciated!
I use the stock drivers. The zigbee portion gets added as a generic zigbee outlet and the zwave portion gets added as a generic zwave repeater device. No 3rd party driver required.
As @ogiewon mentioned, there is also @srwhite's driver that includes additional power reporting and zwave status reporting. Both great additions if you need them but not necessary for basic functionality.
Yeah, I skipped adding the Z-Wave side of it (because I forgot the damn thing has two radios). Soooo, off to pairing land I go! :wink:
Ah..get ready and hopefully you don't have too many of these to pair. The hokey-pokey dance can be tiring.
I had to pair the Z-Wave side of these devices in the same room as my Hubitat Elevation. Then I moved them to their final location. After all were paired, I ran a Z-Wave Repair.
This plug is in my office, about 2' from my hub, fortunately. I've had problems with this plug in the past (mostly due to it getting splashed with saltwater a couple times when it was serving as my saltwater reservoir pump controller which I replaced with an outdoor GE/Jasco plug). So now, it's regulated to being just a Zigbee repeater and nothing more. :smiley: But, now it will be both a Zigbee AND a Z-Wave repeater.
It's unplug, hold button, plug in, let go after 3 seconds, right? If it's as I remember, a power strip does great for that.
Not for the Z-Wave side.
Start the Z-Wave Pairing process on your hub. Then quickly press the button on the 3210-L 8 times. If it doesn’t pair the first time, keep trying...
If you press and hold the button, you'll factory reset it and the Zigbee side will be un-paired as well.
Ahhhh, gotcha. Thanks for that.
