The only power monitoring device i currently have is an ancient aeon brick from like 2011 . Now i have a need for a power draw monitoring plug with a fast response time. I don't care about cumulative kw/h or anything, just real time draw so i can determine when the device is active or in stand by.
Thing is, i don't really know how monitoring works in detail as I don't use it. I have a strong aversion to chatty devices. I assume that power monitoring plugs are proactively chatting their current status every x number of seconds?
Any recommend plugs (zigbee or z wave both good, or i guess lan with local integration also okay because i suspect this is one area where a separate app with a hubitat plugin running locally might introduce some capabilities beyond HE's power monitoring abilities)
