Getting ready to add a portable backup generator, not whole house. Electrician is installing an interlock kit on main breaker. When running on generator the main is turned off. Problem with that is it’s difficult to determine when main utility comes back on. I can find sensors that sound a siren but would really like somothat can send me a notification.Anyone know of anything like that?
If I’m understanding your setup correctly, there will be a generator inlet whose breaker is interlocked with the main breaker.
So when the generator is in use, all electrical circuits in your house will be powered by the generator, and the main breaker cannot be turned on. If this is correct, where are you planning to place a power monitor to detect if utility power is restored?
You might be better off with an 8-10 circuit transfer switch, so some of your circuits will remain on utility power.
I have the same setup and have one of the alarm sensors. Curious to hear if anyone has any other ideas.
that being said, i just realized that i have a refoss panel monitor that I haven’t finished installing that would probably do the trick. ![]()
Looks like the refoss would have to sense current draw. With breaker off there wouldn’t be.
Wonder if one could tie into the siren and trigger something??
Good point. I’m sure if I tried hard enough, I could find a way to wire the siren sensor to a dry contact sensor. Just spitballing ideas at this point.
This on the mains, volts greater than 20 mains up else mains down.
Correct me if I am wrong, because I do not own these. It would register kW due to the CTs on the phases versus voltage right? The only voltage measurement would be the line side for the device itself.
Regardless, the OP can use any wattage on a known dead circuit, when in back up mode.
That is why the link i sent includes links to the manuals. You dont need to own them to know what values they report and i’ve rather let the manuals correct you.
I think the issue will be you have to be on or before the main breaker, and it won't be code compliant nor a good idea to have a device reading directly on the main breaker. If the main is off, there will be no current flow, and no reliable way to see when power comes back.
The only option I can think of is a "meter reader", if you have a more modern meter, it has an IR that can be read via a light sensor, and possibly with some homemade solution like an esp32, you could determine if power was on or off.
Not sure if this is still available, or if your meter is compatible, but there is the frient Electricity Meter Interface that might work. Not sure if this has a driver in Hubitat either. There are similar solutions, but they seem to be much tougher to find than in the past.
That was my original plan. But when the electrician suggested the interlock it seems a better solution. More flexible as to which circuits I can use. Not tied in to just the few. More hassle, but a whole lot cheaper.
It appears that has to sense current draw. And since it would have to be before the mains with the mains off there is no current. I may be wrong on this, but seems that way.
This looks promising. Have to see what kind of meter I have and whether it would detect just voltage.
Be interesting if you figure this out.
Gonna be a month or so till the electrician does the install so I have time to research. Appreciate all the suggestions.
Should point out that all this is probably moot. Murphy's law states that if I get a generator I will never need it....![]()
Actually, less hassle to install an interlock relative to a transfer switch. And you are correct - it's cheaper and provides way more flexibility. The only thing that is more difficult is detecting when utility power is back on.
FWIW, my utility sends me text messages when power is out and when it returns. It's reasonably accurate.
I think you are correct. @neonturbo's suggestion would be the way to go.
I have one of these. Not smart, but does the job.
For me, when power is out, cable internet is out.
Utility notifications are good-smart meter probably means I don't have to call it in, but I do anyway, so far.
Great idea! This is almost tailor-made for @j715's installation.
Mine does also, except they are very timely. Could be hours after it came back on.
That is probably what I will get. Was just hoping I could find something that would do more than sound alarm. It is possible that at night when I don't have my hearing aids in I might not even hear it. Being hard of hearing has it's advantages, can't hear the missus complain...
But does make it hard to hear things I should.
I can be hard to hear when it's in the basement-I leave the door open.
Looking for the link above just now, I came across some other devices on Amazon. Didn't look at them in detail yet, but there are other possibilities.
It may be possible to wire a low voltage LED in series with the siren, so it flashes.
Indeed. My grandfather found it difficult to hear my grandma from across the room. But could hear his grandkids from across the house ![]()
I looked at Amazon, and the only alternative to the Reliance was the one below. Still short cord.
edit: sorry about the weird link. I think it's Amazon, and not me, lol.
From the basement breaker box location to our bedroom is a long way. But kinda hoping to maybe hook a dry contact or something to trigger. Till I get one won't be able to tell.
I saw that one also. Probably not much difference between them.
