Possible Route to Home Kit?
Morning.
I take no credit for the app, but I have used Paul's smartthings to homebridge to home kit app and it works pretty well.
There is a post going within the GitHub where they are editing the JSON Api and creating the hubitat app to bring Homekit integration into Hubitat courtesy of homebridge.
Check it out and maybe someone can support this further?
[UPDATE] Please use @tonesto7 Tony's much more polished version of the homebridge-hubitat plugin from the thread linked immediately below. Thank you Tony for your work on making this easy to install for users, and easier to use with Hubitat.
[Begin original message]
Yea, that is me doing that editing. I have the "JSON Complete API" app running on my Hubitat. One thing that I have noticed is that Hubitat is removing spaces in the JSON response, specifically in the names of the device capabilties. For example, "Temperature Measurement" is coming over as "TemperatureMeasurement", which then confuses the homebridge-smartthings plugin. I have even edited portions of the plugin to account for this, which has helped. But right now the direct updates from Hubitat to Homebridge are not working.
I hope to have more time to debug this and then try to get it released to the Hubitat community. I am totally open to any assistance from community members who are a little more skilled in Groovy and NodeJS though!
Using the code below, I have a working Hubitat Homebridge conficguration, but the DIRECT UPDATES are not working for some reason. Which means, you can use Homekit on your iOS device to control devices, but their status in Homekit is not being updated automatically. (UPDATE: Using the old polling method for updates does work, however it is not ideal as it places an unnecessary workload on the Hubitat Hub.)
I could really use some help from the community, if anyone is interested.
Here is my "JSON Complete API" app, updated for Hubitat.
 *  JSON Complete API
 *  Copyright 2017 Paul Lovelace
 *  Modifications for Hubitat (in progress) - Dan Ogorchock 2/14/2018
definition(
    name: "JSON Complete API",
    namespace: "pdlove",
    author: "Paul Lovelace",
    description: "API for JSON with complete set of devices",
    category: "SmartThings Labs",
    iconUrl:   "https://raw.githubusercontent.com/pdlove/homebridge-smartthings/master/smartapps/JSON%401.png",
    iconX2Url: "https://raw.githubusercontent.com/pdlove/homebridge-smartthings/master/smartapps/JSON%402.png",
    iconX3Url: "https://raw.githubusercontent.com/pdlove/homebridge-smartthings/master/smartapps/JSON%403.png",
    oauth: true)
preferences {
    page(name: "copyConfig")
//When adding device groups, need to add here
def copyConfig() {
    if (!state.accessToken) {
        createAccessToken()
    dynamicPage(name: "copyConfig", title: "Configure Devices", install:true, uninstall:true) {
        section("Select devices to include in the /devices API call") {
            paragraph "Version 0.5.5"
            input "deviceList", "capability.refresh", title: "Most Devices", multiple: true, required: false
            input "sensorList", "capability.sensor", title: "Sensor Devices", multiple: true, required: false
            input "switchList", "capability.switch", title: "All Switches", multiple: true, required: false
            //paragraph "Devices Selected: ${deviceList ? deviceList?.size() : 0}\nSensors Selected: ${sensorList ? sensorList?.size() : 0}\nSwitches Selected: ${switchList ? switchList?.size() : 0}"
        section("Configure Pubnub") {
            input "pubnubSubscribeKey", "text", title: "PubNub Subscription Key", multiple: false, required: false
            input "pubnubPublishKey", "text", title: "PubNub Publish Key", multiple: false, required: false
            input "subChannel", "text", title: "Channel (Can be anything)", multiple: false, required: false
        section() {
            paragraph "View this SmartApp's configuration to use it in other places."
            //Original SmartThings cloud endpoint
            //href url:"${apiServerUrl("/api/smartapps/installations/${app.id}/config?access_token=${state.accessToken}")}", style:"embedded", required:false, title:"Config", description:"Tap, select, copy, then click \"Done\""
            //Hubitat cloud endpoint
            //href url:"${getApiServerUrl()}/${hubUID}/apps/${app.id}/config?access_token=${state.accessToken}", style:"embedded", required:false, title:"Config", description:"Tap, select, copy, then click \"Done\""
            //Hubitat local endpoint
            href url:fullLocalApiServerUrl("config") + "?access_token=${state.accessToken}", style:"embedded", required:false, title:"Config", description:"Tap, select, copy, then click \"Done\""
        section() {
        	paragraph "View the JSON generated from the installed devices."
            //href url:"${apiServerUrl("/api/smartapps/installations/${app.id}/devices?access_token=${state.accessToken}")}", style:"embedded", required:false, title:"Device Results", description:"View accessories JSON"
            //href url:"${getApiServerUrl()}/${hubUID}/apps/${app.id}/devices?access_token=${state.accessToken}", style:"embedded", required:false, title:"Device Results", description:"View accessories JSON"
            href url:fullLocalApiServerUrl("devices") + "?access_token=${state.accessToken}", style:"embedded", required:false, title:"Device Results", description:"View accessories JSON"
        section() {
        	paragraph "Enter the name you would like shown in the smart app list"
        	label title:"SmartApp Label (optional)", required: false
def renderDevices() {
    def deviceData = []
        deviceList.each {
        	try {
            deviceData << [name: it.displayName,
    				basename: it.name,
    				deviceid: it.id,
                    status: it.status,
                    manufacturerName: it.getManufacturerName(),
                    modelName: it.getModelName(),
                    lastTime: it.getLastActivity(),
                    capabilities: deviceCapabilityList(it),
                    commands: deviceCommandList(it),
                    attributes: deviceAttributeList(it)
      		} catch (e) {
      			log.error("Error Occurred Parsing Device "+it.displayName+", Error " + e)
        sensorList.each {
        	try {
    				basename: it.name,
    				deviceid: it.id,
                    status: it.status,
      		} catch (e) {
        switchList.each {
        	try {
    				basename: it.name,
    				deviceid: it.id,
                    status: it.status,
      		} catch (e) {
    return deviceData
def findDevice(paramid) {
	def device = deviceList.find { it.id == paramid }
  	if (device) return device
	device = sensorList.find { it.id == paramid }
  	device = switchList.find { it.id == paramid }
	return device
//No more individual device group definitions after here.
def installed() {
	log.debug "Installed with settings: ${settings}"
	initialize()
def updated() {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
	initialize()
def initialize() {
	if(!state.accessToken) {
         createAccessToken()
    registerAll()
	state.subscriptionRenewed = 0
    subscribe(location, null, HubResponseEvent, [filterEvents:false])
    log.debug "0.5.5"
def authError() {
    [error: "Permission denied"]
def renderConfig() {
    def configJson = new groovy.json.JsonOutput().toJson([
        description: "JSON API",
        platforms: [
                platform: "SmartThings",
                //app_url: apiServerUrl("/api/smartapps/installations/"),
                //app_url: "${getApiServerUrl()}/${hubUID}/apps/",
                app_url: getLocalApiServerUrl() + "/",
                app_id: app.id,
                access_token:  state.accessToken
    def configString = new groovy.json.JsonOutput().prettyPrint(configJson)
    render contentType: "text/plain", data: configString
def renderLocation() {
    	latitude: location.latitude,
    	longitude: location.longitude,
    	mode: location.mode,
    	temperature_scale: location.temperatureScale,
    	zip_code: location.zipCode,
        hubIP: location.hubs[0].getDataValue("localIP"),
        //hubIP: location.hubs[0].localIP,
        smartapp_version: '0.5.5'
def CommandReply(statusOut, messageOut) {
	def replyData =
        	status: statusOut,
            message: messageOut
    def replyJson    = new groovy.json.JsonOutput().toJson(replyData)
    render contentType: "application/json", data: replyJson
def deviceCommand() {
	log.info("Command Request")
	def device = findDevice(params.id)
    def command = params.command
  	if (!device) {
		log.error("Device Not Found")
      	CommandReply("Failure", "Device Not Found")
  	} else if (!device.hasCommand(command)) {
      	log.error("Device "+device.displayName+" does not have the command "+command)
      	CommandReply("Failure", "Device "+device.displayName+" does not have the command "+command)
  	} else {
      	def value1 = request.JSON?.value1
      	def value2 = request.JSON?.value2
      	try {
      		if (value2) {
	       		device."$command"(value1,value2)
	    	} else if (value1) {
	    		device."$command"(value1)
	    	} else {
	    		device."$command"()
        	log.info("Command Successful for Device "+device.displayName+", Command "+command)
        	CommandReply("Success", "Device "+device.displayName+", Command "+command)
      	} catch (e) {
      		log.error("Error Occurred For Device "+device.displayName+", Command "+command)
 	    	CommandReply("Failure", "Error Occurred For Device "+device.displayName+", Command "+command)
def deviceAttribute() {
    def attribute = params.attribute
  	if (!device) {
    	httpError(404, "Device not found")
  	} else {
      	def currentValue = device.currentValue(attribute)
      	[currentValue: currentValue]
def deviceQuery() {
    if (!device) {
    	device = null
    if (result) {
    	def jsonData =
            	deviceid: device.id,
            	capabilities: deviceCapabilityList(device),
            	commands: deviceCommandList(device),
            	attributes: deviceAttributeList(device)
    	def resultJson = new groovy.json.JsonOutput().toJson(jsonData)
    	render contentType: "application/json", data: resultJson
def deviceCapabilityList(device) {
  	def i=0
  	device.capabilities.collectEntries { capability->
      		(capability.name):1
def deviceCommandList(device) {
  	def i=0
  	device.supportedCommands.collectEntries { command->
      		(command.name): (command.arguments)
def deviceAttributeList(device) {
  	device.supportedAttributes.collectEntries { attribute->
    	try {
        		(attribute.name): device.currentValue(attribute.name)
    	} catch(e) {
        		(attribute.name): null
def getAllData() {
	//Since we're about to send all of the data, we'll count this as a subscription renewal and clear out pending changes.
	state.subscriptionRenewed = now()
    state.devchanges = []
	def deviceData =
    [	location: renderLocation(),
        deviceList: renderDevices() ]
    def deviceJson = new groovy.json.JsonOutput().toJson(deviceData)
    render contentType: "application/json", data: deviceJson
def startSubscription() {
//This simply registers the subscription.
	def deviceJson = new groovy.json.JsonOutput().toJson([status: "Success"])
def endSubscription() {
//Because it takes too long to register for an api command, we don't actually unregister.
//We simply blank the devchanges and change the subscription renewal to two hours ago.
def registerAll() {
//This has to be done at startup because it takes too long for a normal command.
	log.debug "Registering All Events"
	registerChangeHandler(deviceList)
	registerChangeHandler(sensorList)
	registerChangeHandler(switchList)
def registerChangeHandler(myList) {
	myList.each { myDevice ->
		def theAtts = myDevice.supportedAttributes
		theAtts.each {att ->
		    subscribe(myDevice, att.name, changeHandler)
    	log.debug "Registering ${myDevice.displayName}.${att.name}"
def changeHandler(evt) {
	//Send to Pubnub if we need to.
    if (pubnubPublishKey!=null) {
	    def deviceData = [device: evt.deviceId, attribute: evt.name, value: evt.value, date: evt.date]
		def changeJson = new groovy.json.JsonOutput().toJson(deviceData)
		def changeData = URLEncoder.encode(changeJson)
        def uri = "http://pubsub.pubnub.com/publish/${pubnubPublishKey}/${pubnubSubscribeKey}/0/${subChannel}/0/${changeData}"
		log.debug "${uri}"
    	httpGet(uri)
  	if (state.directIP!="") {
    	//Send Using the Direct Mechanism
        //How do I control the port?!?
        log.debug "Sending Update to ${state.directIP}:${state.directPort}"
        def result = new hubitat.device.HubAction(
    		method: "GET",
    		path: "/update",
    		headers: [
        		HOST: "${state.directIP}:${state.directPort}",
                change_device: evt.deviceId,
                change_attribute: evt.name,
                change_value: evt.value,
                change_date: evt.date
        //log.debug "changeHandler: sending result = ${result}"
        sendHubCommand(result)
	//Only add to the state's devchanges if the endpoint has renewed in the last 10 minutes.
    if (state.subscriptionRenewed>(now()-(1000*60*10))) {
// 		if (evt.isStateChange()) {
        log.debug "evt.getIsStateChange() = ${evt.getIsStateChange()}"
        if (evt.getIsStateChange()) {
                state.devchanges << [device: evt.deviceId, attribute: evt.name, value: evt.value, date: evt.date]
    	} else if (state.subscriptionRenewed>0) { //Otherwise, clear it
            log.debug "Endpoint Subscription Expired. No longer storing changes for devices."
            state.devchanges=[]
            state.subscriptionRenewed=0
def getChangeEvents() {
    //Store the changes so we can swap it out very quickly and eliminate the possibility of losing any.
    //This is mainly to make this thread safe because I'm willing to bet that a change event can fire
    //while generating/sending the JSON.
    def oldchanges = state.devchanges
    state.devchanges=[]
	if (oldchanges.size()==0) {
        def deviceJson = new groovy.json.JsonOutput().toJson([status: "None"])
    } else {
    	def changeJson = new groovy.json.JsonOutput().toJson([status: "Success", attributes:oldchanges])
    	render contentType: "application/json", data: changeJson
def enableDirectUpdates() {
	log.debug("Command Request")
	state.directIP = params.ip
    state.directPort = params.port
	log.debug("Trying ${state.directIP}:${state.directPort}")
    		method: "GET",
    		path: "/initial",
    		headers: [
    		query: deviceData
def HubResponseEvent(evt) {
	log.debug(evt.description)
def locationHandler(evt) {
    def description = evt.description
    def hub = evt?.hubId
    log.debug "cp desc: " + description
    if (description.count(",") > 4)
def bodyString = new String(description.split(',')[5].split(":")[1].decodeBase64())
log.debug(bodyString)
def getSubscriptionService() {
	def replyData =
        	pubnub_publishkey: pubnubPublishKey,
            pubnub_subscribekey: pubnubSubscribeKey,
            pubnub_channel: subChannel
mappings {
/*    if (!params.access_token || (params.access_token && params.access_token != state.accessToken)) {
        path("/devices")                        { action: [GET: "authError"] }
        path("/config")                         { action: [GET: "authError"] }
        path("/location")                       { action: [GET: "authError"] }
        path("/:id/command/:command")     		{ action: [POST: "authError"] }
        path("/:id/query")						{ action: [GET: "authError"] }
        path("/:id/attribute/:attribute") 		{ action: [GET: "authError"] }
        path("/subscribe")                      { action: [GET: "authError"] }
        path("/getUpdates")                     { action: [GET: "authError"] }
        path("/unsubscribe")                    { action: [GET: "authError"] }
        path("/startDirect/:ip/:port")          { action: [GET: "authError"] }
        path("/getSubcriptionService")          { action: [GET: "authError"] }
    } else {
        path("/devices")                        { action: [GET: "getAllData"] }
        path("/config")                         { action: [GET: "renderConfig"]  }
        path("/location")                       { action: [GET: "renderLocation"] }
        path("/:id/command/:command")     		{ action: [POST: "deviceCommand"] }
        path("/:id/query")						{ action: [GET: "deviceQuery"] }
        path("/:id/attribute/:attribute") 		{ action: [GET: "deviceAttribute"] }
        path("/subscribe")                      { action: [GET: "startSubscription"] }
        path("/getUpdates")                     { action: [GET: "getChangeEvents"] }
        path("/unsubscribe")                    { action: [GET: "endSubscription"] }
        path("/startDirect/:ip/:port")          { action: [GET: "enableDirectUpdates"] }
        path("/getSubcriptionService")          { action: [GET: "getSubscriptionService"] }
And here is my edited version of smartthingsapi.js which runs on the homebridge app server (in my case, a raspberry pi).
var http = require('http');
var url = require('url');
var app_host;
var app_port;
var app_path;
var access_token;
function _http(data, callback) {
    //console.log("Calling Smartthings");
    var options = {
        hostname: app_host,
        port: app_port,
        path: app_path + data.path + "?access_token=" + access_token,
        method: data.method,
        headers: {}
    var that = this;
    if (data.data) {
        data.data = JSON.stringify(data.data);
        options.headers['Content-Length'] = Buffer.byteLength(data.data);
        options.headers['Content-Type'] = "application/json";
    var str = '';
    var req = http.request(options, function (response) {
        response.on('data', function (chunk) {
            str += chunk;
        response.on('end', function () {
            if (data.debug) console.log("response in http:", str);
            try {
                str = JSON.parse(str);
            } catch (e) {
                if (data.debug) {
                    console.log(e.stack);
                    console.log("raw message", str);
                str = undefined;
            if (callback) { callback(str); callback=undefined; };
    if (data.data) {
        req.write(data.data);
    req.end();
    req.on('error', function (e) {
        console.log("error at req: ", e.message);
        if (callback) { callback(); callback=undefined; };
function POST(data, callback) {
    data.method = "POST";
    _http(data, callback);
function PUT(data, callback) {
    data.method = "PUT";
function GET(data, callback) {
    data.method = "GET";
function DELETE(data, callback) {
    data.method = "DELETE";
var smartthings = {
    init: function (inURL, inAppID, inAccess_Token) {
        var appURL = url.parse(inURL);
        app_host = appURL.hostname || "graph.api.smartthings.com";
        app_port = appURL.port || "80";
        app_path = (appURL.path || "/api/smartapps/installations/") + inAppID + "/";
        access_token = inAccess_Token;
    getDevices: function (callback) {
        GET({ debug: false, path: 'devices' }, function (data) {
            if (callback) { callback(data); callback=undefined; };
    getDevice: function (deviceid, callback) {
        GET({ debug: false, path: deviceid + '/query' }, function (data) {
            if (data) {
            } else {
                if (callback) { callback(); callback=undefined; };;
    getUpdates: function (callback) {
        GET({ debug: false, path: 'getUpdates' }, function (data) {
            if (callback) { callback(data); callback=undefined; };;
    runCommand: function (callback, deviceid, command, values) {
        POST({ debug: false, path: deviceid + '/command/' + command, data: values }, function (data) {
    startDirect: function (callback, myIP, myPort) {
        GET({ debug: false, path: 'startDirect/' + myIP + '/' + myPort }, function (data) {
    getSubscriptionService: function (callback) {
        GET({ debug: false, path: 'getSubcriptionService' }, function (data) {
module.exports = smartthings;
And finally, here is my copy of smartthings.js which is modified to account for the lack of spaces in the device Capabilities names returned by Hubitat.
var inherits = require('util').inherits;
var Accessory, Service, Characteristic, uuid, EnergyCharacteristics;
 *   SmartThings Accessory
module.exports = function(oAccessory, oService, oCharacteristic, ouuid) {
    if (oAccessory) {
        Accessory = oAccessory;
        Service = oService;
        Characteristic = oCharacteristic;
        EnergyCharacteristics = require('../lib/customCharacteristics').EnergyCharacteristics(Characteristic)
        uuid = ouuid;
        inherits(SmartThingsAccessory, Accessory);
        SmartThingsAccessory.prototype.loadData = loadData;
        SmartThingsAccessory.prototype.getServices = getServices;
    return SmartThingsAccessory;
module.exports.SmartThingsAccessory = SmartThingsAccessory;
function SmartThingsAccessory(platform, device) {
    this.deviceid = device.deviceid;
    this.name = device.name;
    this.platform = platform;
    this.state = {};
    this.device = device;
    var idKey = 'hbdev:smartthings:' + this.deviceid;
    var id = uuid.generate(idKey);
    Accessory.call(this, this.name, id);
    var that = this;
    //Get the Capabilities List
    for (var index in device.capabilities) {
        if ((platform.knownCapabilities.indexOf(index) == -1) && (platform.unknownCapabilities.indexOf(index) == -1))
            platform.unknownCapabilities.push(index);
    this.getaddService = function(Service) {
        var myService = this.getService(Service);
        if (!myService) myService = this.addService(Service);
        return myService
    this.deviceGroup = "unknown"; //This way we can easily tell if we set a device group
	var thisCharacteristic;
    if (device.capabilities["SwitchLevel"] !== undefined) {
        if (device.commands.levelOpenClose) {
            //This is a Window Shade
            this.deviceGroup = "shades"
            thisCharacteristic = this.getaddService(Service.WindowCovering).getCharacteristic(Characteristic.TargetPosition)
            thisCharacteristic.on('get', function(callback) { callback(null, parseInt(that.device.attributes.level)); });
            thisCharacteristic.on('set', function(value, callback) { that.platform.api.runCommand(callback, that.deviceid, "setLevel", { value1: value }); });
			that.platform.addAttributeUsage("level", this.deviceid, thisCharacteristic);
            thisCharacteristic = this.getaddService(Service.WindowCovering).getCharacteristic(Characteristic.CurrentPosition)
        } else if (device.commands.lowSpeed) {
            //This is a Ceiling Fan
            this.deviceGroup = "fans"
            thisCharacteristic = this.getaddService(Service.Fan).getCharacteristic(Characteristic.On)
            thisCharacteristic.on('get', function(callback) { callback(null, that.device.attributes.switch == "on"); })
                    if (value)
                        that.platform.api.runCommand(callback, that.deviceid, "on");
                    else
                        that.platform.api.runCommand(callback, that.deviceid, "off"); });
		        that.platform.addAttributeUsage("switch", this.deviceid, thisCharacteristic);
	        thisCharacteristic = this.getaddService(Service.Fan).getCharacteristic(Characteristic.RotationSpeed)
            	    if (value > 0)
            	    	that.platform.api.runCommand(callback, that.deviceid, "setLevel", {value1: value }); });
        } else if (device.commands.setLevel) {
            this.deviceGroup = "lights";
            thisCharacteristic = this.getaddService(Service.Lightbulb).getCharacteristic(Characteristic.On)
            thisCharacteristic.on('get', function(callback) { callback(null, that.device.attributes.switch == "on"); });
                    if (value)
                    else
            thisCharacteristic = this.getaddService(Service.Lightbulb).getCharacteristic(Characteristic.Brightness)
            if (device.capabilities["ColorControl"] !== undefined) {
				thisCharacteristic = this.getaddService(Service.Lightbulb).getCharacteristic(Characteristic.Hue)
                thisCharacteristic.on('get', function(callback) { callback(null, Math.round(that.device.attributes.hue*3.6)); });
                thisCharacteristic.on('set', function(value, callback) { that.platform.api.runCommand(callback, that.deviceid, "setHue", { value1: Math.round(value/3.6) }); });
				that.platform.addAttributeUsage("hue", this.deviceid, thisCharacteristic);
                thisCharacteristic = this.getaddService(Service.Lightbulb).getCharacteristic(Characteristic.Saturation)
                thisCharacteristic.on('get', function(callback) { callback(null, parseInt(that.device.attributes.saturation)); });
                thisCharacteristic.on('set', function(value, callback) { that.platform.api.runCommand(callback, that.deviceid, "setSaturation", { value1: value }); });
				that.platform.addAttributeUsage("saturation", this.deviceid, thisCharacteristic);
    if (device.capabilities["GarageDoorControl"] !== undefined) {
        this.deviceGroup = "garage_doors";
        thisCharacteristic = this.getaddService(Service.GarageDoorOpener).getCharacteristic(Characteristic.TargetDoorState)
                if (that.device.attributes.door == 'closed' || that.device.attributes.door == 'closing')
                    callback(null, Characteristic.TargetDoorState.CLOSED);
                else if (that.device.attributes.door == 'open' || that.device.attributes.door == 'opening')
                    callback(null, Characteristic.TargetDoorState.OPEN); });
                if (value == Characteristic.TargetDoorState.OPEN) {
                    that.platform.api.runCommand(callback, that.deviceid, "open");
                    that.device.attributes.door = "opening";
                } else if (value == Characteristic.TargetDoorState.CLOSED) {
                    that.platform.api.runCommand(callback, that.deviceid, "close");
                    that.device.attributes.door = "closing";
		that.platform.addAttributeUsage("door", this.deviceid, thisCharacteristic);
        thisCharacteristic = this.getaddService(Service.GarageDoorOpener).getCharacteristic(Characteristic.CurrentDoorState)
                switch (that.device.attributes.door) {
                    case 'open':
                        break;
                    case 'opening':
                        callback(null, Characteristic.TargetDoorState.OPENING);
                        break;
                    case 'closed':
                        break;
                    case 'closing':
                        callback(null, Characteristic.TargetDoorState.CLOSING);
                        break;
                    default:
                        callback(null, Characteristic.TargetDoorState.STOPPED);
                        break;
        this.getaddService(Service.GarageDoorOpener).setCharacteristic(Characteristic.ObstructionDetected, false);
    if (device.capabilities["Lock"] !== undefined) {
        this.deviceGroup = "locks";
        thisCharacteristic = this.getaddService(Service.LockMechanism).getCharacteristic(Characteristic.LockCurrentState)
                switch (that.device.attributes.lock) {
                    case 'locked':
                        callback(null, Characteristic.LockCurrentState.SECURED);
                        break;
                    case 'unlocked':
                        callback(null, Characteristic.LockCurrentState.UNSECURED);
                        break;
                    default:
                        callback(null, Characteristic.LockCurrentState.UNKNOWN);
                        break;
		that.platform.addAttributeUsage("lock", this.deviceid, thisCharacteristic);
        thisCharacteristic = this.getaddService(Service.LockMechanism).getCharacteristic(Characteristic.LockTargetState)
                    case 'locked':
                        break;
                    case 'unlocked':
                        break;
                    default:
                        break;
		if (value === false) {
                    value = Characteristic.LockTargetState.UNSECURED;
                } else if (value === true) {
                    value = Characteristic.LockTargetState.SECURED;
                switch (value) {
                    case Characteristic.LockTargetState.SECURED:
                        that.platform.api.runCommand(callback, that.deviceid, "lock");
                        that.device.attributes.lock = "locked";
                        break;
                    case Characteristic.LockTargetState.UNSECURED:
                        that.platform.api.runCommand(callback, that.deviceid, "unlock");
                        that.device.attributes.lock = "unlocked";
                        break;
//    if (devices.capabilities["Valve"] !== undefined) {
//        this.deviceGroup = "valve";
// Thinking of implementing this as a Door service.
    if (device.capabilities["Button"] !== undefined) {
        this.deviceGroup = " button";
    if (device.capabilities["Switch"] !== undefined && this.deviceGroup == "unknown") {
        this.deviceGroup = "switch";
        thisCharacteristic = this.getaddService(Service.Switch).getCharacteristic(Characteristic.On)
                if (value)
                else
    if ((device.capabilities["SmokeDetector"] !== undefined) && (that.device.attributes.smoke)) {
        this.deviceGroup = "detectors";
        thisCharacteristic = this.getaddService(Service.SmokeSensor).getCharacteristic(Characteristic.SmokeDetected)
                if (that.device.attributes.smoke == 'clear')
                    callback(null, Characteristic.SmokeDetected.SMOKE_NOT_DETECTED);
                else
                    callback(null, Characteristic.SmokeDetected.SMOKE_DETECTED);
 		that.platform.addAttributeUsage("smoke", this.deviceid, thisCharacteristic);
    if ((device.capabilities["CarbonMonoxideDetector"] !== undefined) && (that.device.attributes.carbonMonoxide)) {
		thisCharacteristic = this.getaddService(Service.CarbonMonoxideSensor).getCharacteristic(Characteristic.CarbonMonoxideDetected)
                if (that.device.attributes.carbonMonoxide == 'clear')
                    callback(null, Characteristic.CarbonMonoxideDetected.CO_LEVELS_NORMAL);
                else
                    callback(null, Characteristic.CarbonMonoxideDetected.CO_LEVELS_ABNORMAL);
 		that.platform.addAttributeUsage("carbonMonoxide", this.deviceid, thisCharacteristic);
    if (device.capabilities["MotionSensor"] !== undefined) {
        if (this.deviceGroup == 'unknown') this.deviceGroup = "sensor";
		thisCharacteristic = this.getaddService(Service.MotionSensor).getCharacteristic(Characteristic.MotionDetected)
        thisCharacteristic.on('get', function(callback) { callback(null, (that.device.attributes.motion == "active")); });
 		that.platform.addAttributeUsage("motion", this.deviceid, thisCharacteristic);
    if (device.capabilities["WaterSensor"] !== undefined) {
        thisCharacteristic = this.getaddService(Service.LeakSensor).getCharacteristic(Characteristic.LeakDetected)
                                var reply = Characteristic.LeakDetected.LEAK_DETECTED;
                                if (that.device.attributes.water == "dry") reply = Characteristic.LeakDetected.LEAK_NOT_DETECTED;
                    callback(null, reply); });
 		that.platform.addAttributeUsage("water", this.deviceid, thisCharacteristic);
    if (device.capabilities["PresenceSensor"] !== undefined) {
        thisCharacteristic = this.getaddService(Service.OccupancySensor).getCharacteristic(Characteristic.OccupancyDetected)
        thisCharacteristic.on('get', function(callback) { callback(null, (that.device.attributes.presence == "present")); });
 		that.platform.addAttributeUsage("presence", this.deviceid, thisCharacteristic);
    if (device.capabilities["RelativeHumidityMeasurement"] !== undefined) {
        thisCharacteristic = this.getaddService(Service.HumiditySensor).getCharacteristic(Characteristic.CurrentRelativeHumidity)
        thisCharacteristic.on('get', function(callback) { callback(null, Math.round(that.device.attributes.humidity)); });
		that.platform.addAttributeUsage("humidity", this.deviceid, thisCharacteristic);
    if (device.capabilities["TemperatureMeasurement"] !== undefined) {
        thisCharacteristic = this.getaddService(Service.TemperatureSensor).getCharacteristic(Characteristic.CurrentTemperature)
                if (that.platform.temperature_unit == 'C')
                    callback(null, Math.round(that.device.attributes.temperature*10)/10);
                else
                    callback(null, Math.round(((that.device.attributes.temperature - 32) / 1.8)*10)/10);
		that.platform.addAttributeUsage("temperature", this.deviceid, thisCharacteristic);
    if (device.capabilities["ContactSensor"] !== undefined && device.capabilities["GarageDoorControl"] === undefined) {
        thisCharacteristic = this.getaddService(Service.ContactSensor).getCharacteristic(Characteristic.ContactSensorState)
                if (that.device.attributes.contact == "closed")
                    callback(null, Characteristic.ContactSensorState.CONTACT_DETECTED);
                else
                    callback(null, Characteristic.ContactSensorState.CONTACT_NOT_DETECTED);
 		that.platform.addAttributeUsage("contact", this.deviceid, thisCharacteristic);
    if (device.capabilities["Battery"] !== undefined) {
        thisCharacteristic = this.getaddService(Service.BatteryService).getCharacteristic(Characteristic.BatteryLevel)
        thisCharacteristic.on('get', function(callback) { callback(null, Math.round(that.device.attributes.battery)); });
		that.platform.addAttributeUsage("battery", this.deviceid, thisCharacteristic);
        thisCharacteristic = this.getaddService(Service.BatteryService).getCharacteristic(Characteristic.StatusLowBattery)
                if (that.device.attributes.battery < 0.20)
                    callback(null, Characteristic.StatusLowBattery.BATTERY_LEVEL_LOW);
                else
                    callback(null, Characteristic.StatusLowBattery.BATTERY_LEVEL_NORMAL);
        this.getaddService(Service.BatteryService).setCharacteristic(Characteristic.ChargingState, Characteristic.ChargingState.NOT_CHARGING);
    if (device.capabilities["EnergyMeter"] !== undefined) {
        this.deviceGroup = 'EnergyMeter';
        thisCharacteristic = this.getaddService(Service.Outlet).addCharacteristic(EnergyCharacteristics.TotalConsumption1)
        thisCharacteristic.on('get', function(callback) { callback(null, Math.round(that.device.attributes.energy)); });
		that.platform.addAttributeUsage("energy", this.deviceid, thisCharacteristic);
    if (device.capabilities["PowerMeter"] !== undefined) {
        thisCharacteristic = this.getaddService(Service.Outlet).addCharacteristic(EnergyCharacteristics.CurrentConsumption1)
        thisCharacteristic.on('get', function(callback) { callback(null, Math.round(that.device.attributes.power)); });
		that.platform.addAttributeUsage("power", this.deviceid, thisCharacteristic);
    if (device.capabilities["AccelerationSensor"] !== undefined) {
    if (device.capabilities["ThreeAxis"] !== undefined) {
	if (device.capabilities["Thermostat"] !== undefined) {
        this.deviceGroup = "thermostats";
		thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.CurrentHeatingCoolingState)
                switch (that.device.attributes.thermostatOperatingState) {
                    case "pending cool":
                    case "cooling":
                        callback(null, Characteristic.CurrentHeatingCoolingState.COOL);
                        break;
                    case "pending heat":
                    case "heating":
                        callback(null, Characteristic.CurrentHeatingCoolingState.HEAT);
                        break;
                    default: //The above list should be inclusive, but we need to return something if they change stuff.
                        //TODO: Double check if Smartthings can send "auto" as operatingstate. I don't think it can.
                        callback(null, Characteristic.CurrentHeatingCoolingState.OFF);
                        break;
		that.platform.addAttributeUsage("thermostatOperatingState", this.deviceid, thisCharacteristic);
        //Handle the Target State
        thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.TargetHeatingCoolingState)
                switch (that.device.attributes.thermostatMode) {
                    case "cool":
                        callback(null, Characteristic.TargetHeatingCoolingState.COOL);
                        break;
                    case "emergency heat":
                    case "heat":
                        callback(null, Characteristic.TargetHeatingCoolingState.HEAT);
                        break;
                    case "auto":
                        callback(null, Characteristic.TargetHeatingCoolingState.AUTO);
                        break;
                        callback(null, Characteristic.TargetHeatingCoolingState.OFF);
                        break;
                switch (value) {
                    case Characteristic.TargetHeatingCoolingState.COOL:
                        that.platform.api.runCommand(callback, that.deviceid, "cool");
                        that.device.attributes.thermostatMode = 'cool';
                        break;
                    case Characteristic.TargetHeatingCoolingState.HEAT:
                        that.platform.api.runCommand(callback, that.deviceid, "heat");
                        that.device.attributes.thermostatMode = 'heat';
                        break;
                    case Characteristic.TargetHeatingCoolingState.AUTO:
                        that.platform.api.runCommand(callback, that.deviceid, "auto");
                        that.device.attributes.thermostatMode = 'auto';
                        break;
                    case Characteristic.TargetHeatingCoolingState.OFF:
                        that.device.attributes.thermostatMode = 'off';
                        break;
		that.platform.addAttributeUsage("thermostatMode", this.deviceid, thisCharacteristic);
            thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.CurrentRelativeHumidity)
                    callback(null, parseInt(that.device.attributes.humidity));
        thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.CurrentTemperature)
                else
        thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.TargetTemperature)
                var temp = undefined;
                    case "cool":
                        temp = that.device.attributes.coolingSetpoint;
                        break;
                    case "heat":
                        temp = that.device.attributes.heatingSetpoint;
                        break;
                    default: //This should only refer to auto
                       // Choose closest target as single target
                        var high = that.device.attributes.coolingSetpoint;
                        var low = that.device.attributes.heatingSetpoint;
                        var cur = that.device.attributes.temperature;
                        temp = Math.abs(high - cur) < Math.abs(cur - low) ? high : low;
                        break;
                if (!temp)
                    callback('Unknown');
                else if (that.platform.temperature_unit == 'C')
                    callback(null, Math.round(temp*10)/10);
                else
                    callback(null, Math.round(((temp - 32) / 1.8)*10)/10);
                //Convert the Celsius value to the appropriate unit for Smartthings
                var temp = value;
                    temp = value;
                else
                    temp = ((value * 1.8) + 32);
                //Set the appropriate temperature unit based on the mode
                    case "cool":
                        that.platform.api.runCommand(callback, that.deviceid, "setCoolingSetpoint", {
                            value1: temp
                        that.device.attributes.coolingSetpoint = temp;
                        break;
                    case "heat":
                        that.platform.api.runCommand(callback, that.deviceid, "setHeatingSetpoint", {
                            value1: temp
                        that.device.attributes.heatingSetpoint = temp;
                        break;
                        var isHighTemp = Math.abs(high - cur) < Math.abs(cur - low);
                        if (isHighTemp) {
                           that.platform.api.runCommand(callback, that.deviceid, "setCoolingSetpoint", { value1: temp });
                        } else {
                           that.platform.api.runCommand(null, that.deviceid, "setHeatingSetpoint", { value1: temp });
                        break;
		that.platform.addAttributeUsage("coolingSetpoint", this.deviceid, thisCharacteristic);
		that.platform.addAttributeUsage("heatingSetpoint", this.deviceid, thisCharacteristic);
        thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.TemperatureDisplayUnits)
                if (platform.temperature_unit == "C")
                    callback(null, Characteristic.TemperatureDisplayUnits.CELSIUS);
                else
                    callback(null, Characteristic.TemperatureDisplayUnits.FAHRENHEIT);
		//that.platform.addAttributeUsage("temperature_unit", "platform", thisCharacteristic);
        thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.HeatingThresholdTemperature)
                    callback(null, Math.round(that.device.attributes.heatingSetpoint*10)/10);
                else
                    callback(null, Math.round(((that.device.attributes.heatingSetpoint - 32) / 1.8)*10)/10);
                var temp = value;
                    temp = value;
                else
                    value1: temp
        thisCharacteristic = this.getaddService(Service.Thermostat).getCharacteristic(Characteristic.CoolingThresholdTemperature)
                    callback(null, Math.round((that.device.attributes.coolingSetpoint*10))/10);
                else
                    callback(null, Math.round(((that.device.attributes.coolingSetpoint - 32) / 1.8)*10)/10);
                var temp = value;
                    temp = value;
                else
                    value1: temp
    this.loadData(device, this);
function loadData(data, myObject) {
    var that = this;
    if (myObject !== undefined) that = myObject;
    if (data !== undefined) {
        this.device = data;
        for (var i = 0; i < that.services.length; i++) {
            for (var j = 0; j < that.services[i].characteristics.length; j++) {
                that.services[i].characteristics[j].getValue();
    } else {
        this.log.debug("Fetching Device Data")
        this.platform.api.getDevice(this.deviceid, function(data) {
            if (data === undefined) return;
            this.device = data;
function getServices() {
    return this.services;
@justin.bennett, I did a hubitat bridge similar to the homebridge. The problem is I don’t have homebridge so there’s no way I can do any testing for it. I wouldn’t really know where to even start without having Homebridge and knowing how it works.
So, I am almost there… just need a little help… Maybe @chuck.schwer, @bravenel, @mike.maxwell, or @patrick can take a quick look, please? It appears that Hubitat is producing different results versus SmartThings when sending a HTTP request to my raspberry pi.
In SmartThings, the “JSON Complete API” SmartApp sends a hubaction to the HomeBridge server any time a device is updated. Here is an example from SmartThings that show everything working correctly.
(from ST Live Logging)
result = GET /update HTTP/1.1
Accept: */*
User-Agent: Linux UPnP/1.0 SmartThings
HOST: 192.168.1.145:8000
change_device: 29a0e0db-a238-4e3b-9f17-873b8510abc4
change_attribute: temperature
change_value: 65
change_date: Thu Feb 15 15:16:31 UTC 2018
And you can see the homebridge-smartthings plug-in on my raspberry pi receives the following:
[2018-2-15 10:26:26] [SmartThings] Direct Update request.url /update
[2018-2-15 10:26:26] [SmartThings] Direct Update request.headers["change_device"] 29a0e0db-a238-4e3b-9f17-873b8510abc4
[2018-2-15 10:26:26] [SmartThings] Direct Update request.headers["change_attribute"] temperature
[2018-2-15 10:26:26] [SmartThings] Direct Update request.headers["change_value"] 66
[2018-2-15 10:26:26] [SmartThings] Direct Update request.headers["change_date"] Thu Feb 15 15:26:25 UTC 2018
However, the same code running in Hubitat produces the following
(from Hubitat Live Logging)
result = hubitat.device.HubAction(LAN, GET, /update, [ACCEPT:*/*, USER-AGENT:Linux UPnP/1.0 Hubitat, change_device:457, change_attribute:switch, change_date:Thu Feb 15 10:33:44 EST 2018, CONTENT-TYPE:text/xml; charset="utf-8", HOST:192.168.1.145:8000, change_value:off], null, 192.168.1.145:8000, null, null, null)
resulting in the following in the homebridge-smartthings plug-in on my raspberry pi
[2018-2-15 10:27:06] [SmartThings] Direct Update request.url /update
[2018-2-15 10:27:06] [SmartThings] Direct Update request.headers["change_device"] undefined
[2018-2-15 10:27:06] [SmartThings] Direct Update request.headers["change_attribute"] undefined
[2018-2-15 10:27:06] [SmartThings] Direct Update request.headers["change_value"] undefined
[2018-2-15 10:27:06] [SmartThings] Direct Update request.headers["change_date"] undefined
So, the NodeJS server is able to correct parse the .url field, but not the .headers field
Here is the snippet of groovy code which is producing these hub actions
	method: "GET",
	path: "/update",
	headers: [
        change_date: evt.date ]
log.debug "changeHandler: result = ${result}"
and here is the NodeJS code that is trying to parse the incoming request
function smartthings_HandleHTTPResponse(request, response, mySmartThings)  {
        mySmartThings.log(`Direct Update request.url ${request.url}`);
        mySmartThings.log(`Direct Update request.headers["change_device"] ${request.headers["change_device"]}`);
        mySmartThings.log(`Direct Update request.headers["change_attribute"] ${request.headers["change_attribute"]}`);
        mySmartThings.log(`Direct Update request.headers["change_value"] ${request.headers["change_value"]}`);
        mySmartThings.log(`Direct Update request.headers["change_date"] ${request.headers["change_date"]}`);
        if (request.url=='/initial')
                mySmartThings.log("SmartThings Hub Communication Established");
        if (request.url=='/update') {
                var newChange = { device: request.headers["change_device"],
                                                  attribute: request.headers["change_attribute"],
                                                  value: request.headers["change_value"],
                                                  date: request.headers["chande_date"]};
                mySmartThings.processFieldUpdate(newChange, mySmartThings);
        response.end('OK');
From a very high level, homebridge is a neat piece of software that sits in a docker container on a server or on a raspberry pi device (costs $30). Home bridge allows a user to build a "hub" that can be seen by iOS devices as a home kit solution.
You can manually add some LAN devices to the setup (such as Netatmo) and they will be seen as home kit devices on an iOS device and can be controlled through Siri.
Why Hubitat is so important to the equation is because the Hubitat bridge can house, detect and automate z-wave and zigbee devices so your GE Switches/Bulbs and other less expensive home automation devices can be automated through Hubitat (and Rule Machine), but you can enjoy the UI and Siri input.
Check out this site. I probably have the programming experience of a novice compared to others on this site and it took me about 90 minutes to setup a Raspberry Pi and configure homebridge to work with ST.
Sounds like the HomeBridge part would be easy. I don’t have any apply devices which probably why I’ve never looked into it.
All,
OK - It has taken me a while to hack together a solution, but I seem to have a working Hubitat-to-Homebridge-to-HomeKit solution. I finally was able to get the direct updates to work by passing a “body:” with the event data, instead of trying to make custom headers: work. I am really not sure what the “correct way” is to do this, but I am trying to learn.
It is not probably the prettiest code, and it is really not ready for release to most users due to the significant number of manual steps to get it working. Currently, it cannot coexist on the same Raspberry PI as the normal homebridge-smartthings plug-in.
Fortunately, the original author (@pdlovelace) of homebridge-smartthings has a Hubitat Elevation hub on order. Looks like he joined the Hubitat community a few hours ago! Welcome @pdlovelace!
I will be happy to work with @pdlovelace to get him up to speed on my changes that were necessary to get things to work. Hopefully he’ll take up the challenge to create a npm installable version of ‘homebridge-hubitat’ for the community.
Dan
This is interesting - I may have observed something related (or maybe not) when trying to port over codersaur’s influxdb logger smart app.
Using this hubaction code would send the post but not write the data successfully
try {
    //def hubAction = new physicalgraph.device.HubAction(
    def hubAction = new hubitat.device.HubAction(
            method: "POST",
            path: state.path,
            body: data,
            headers: state.headers
        null,
        [ callback: handleInfluxResponse ]
    sendHubCommand(hubAction)
    //logger("hubAction command sent", "info")
catch (Exception e) {
		logger("postToInfluxDB(): Exception ${e} on ${hubAction}","error")
This is the same code written w/ an httppost and writes the data
 def url = "http://${state.databaseHost}:${state.databasePort}/write?db=${state.databaseName}"
    try {
      httpPost(url, data) { response ->
          if (response.status != 999 ) {
              //log.debug "Response Status: ${response.status}"
             //log.debug "Response data: ${response.data}"
              //log.debug "Response contentType: ${response.contentType}"
  } catch (e) {
      logger("postToInfluxDB(): Something went wrong when posting: ${e}","error")
Here are my current edited files from homebridge-smartthings. @pdlovelace, let me know if you have any questions. I am looking forward to having a more industrialized version! I don’t really know how to thoroughly test everything, but I do know basic devices seem to be working.
json-complete-api.groovy (installed as a Hubitat App with OAUTH enabled)
 *  JSON Complete API
 *  Modifications for Hubitat (in progress) - Dan Ogorchock 2/15/2018
definition(
    oauth: true)
preferences {
def copyConfig() {
        createAccessToken()
        section() {
        section() {
        section() {
    def deviceData = []
        deviceList.each {
        	try {
    				basename: it.name,
    				deviceid: it.id,
                    status: it.status,
      		} catch (e) {
        sensorList.each {
        	try {
    				basename: it.name,
    				deviceid: it.id,
                    status: it.status,
      		} catch (e) {
        switchList.each {
        	try {
    				basename: it.name,
    				deviceid: it.id,
                    status: it.status,
      		} catch (e) {
    return deviceData
	return device
def installed() {
	initialize()
def updated() {
	unsubscribe()
	initialize()
def initialize() {
         createAccessToken()
    registerAll()
    log.debug "0.5.5"
def authError() {
        platforms: [
                app_id: app.id,
	def replyData =
        	status: statusOut,
            message: messageOut
  	if (!device) {
  	} else {
      	try {
      		if (value2) {
	    	} else {
	    		device."$command"()
      	} catch (e) {
  	if (!device) {
  	} else {
def deviceQuery() {
    if (!device) {
    	device = null
    if (result) {
    	def jsonData =
  	def i=0
      		(capability.name):1
  	def i=0
    	try {
    	} catch(e) {
def getAllData() {
	def deviceData =
def registerAll() {
		log.debug "${uri}"
    	httpGet(uri)
        def json = new groovy.json.JsonBuilder(deviceData)
        //log.debug "JSON = " + json.toString()
    		method: "POST",
    		path: "/update",
    		headers: [ HOST: "${state.directIP}:${state.directPort}" ],
            //changed the event data from headers: to body:
            body: json.toString()
 // 	if (evt.isStateChange()) {  //Hubitat function name change
        state.devchanges=[]
    state.devchanges=[]
    } else {
    		method: "GET",
    		path: "/initial",
    		headers: [
    		query: deviceData
    log.debug "enableDirectUpdates: result = ${result}"
	def replyData =
mappings {
    //commented out due to Hubitat error (don't think the check is really necessary...)
    } else {
homebridge-smatthings plug-in files (installed on the raspberrypi)
index.js
var PubNub = require('pubnub')
var smartthings = require('./lib/smartthingsapi');
var os = require('os');
var Service, Characteristic, Accessory, uuid, EnergyCharacteristics;
var SmartThingsAccessory;
module.exports = function (homebridge) {
	Service = homebridge.hap.Service;
	Characteristic = homebridge.hap.Characteristic;
	Accessory = homebridge.hap.Accessory;
	uuid = homebridge.hap.uuid;
	SmartThingsAccessory = require('./accessories/smartthings')(Accessory, Service, Characteristic, uuid);
	homebridge.registerPlatform("homebridge-smartthings", "SmartThings", SmartThingsPlatform);
function SmartThingsPlatform(log, config) {
	// Load Wink Authentication From Config File
	this.app_url = config["app_url"];
	this.app_id = config["app_id"];
	this.access_token = config["access_token"];
	//This is how often it does a full refresh
	this.polling_seconds = config["polling_seconds"];
	if (!this.polling_seconds) this.polling_seconds = 3600; //Get a full refresh every hour.
	//This is how often it polls for subscription data.
	this.update_method = config["update_method"];
	if (!this.update_method) this.update_method='direct';
	this.update_seconds = config["update_seconds"];
	if (!this.update_seconds) this.update_seconds = 30; //30 seconds is the new default
	if (this.update_method==='api' && this.update_seconds<30)
		that.log("The setting for update_seconds is lower than the SmartThings recommended value. Please switch to direct or PubNub using a free subscription for real-time updates.");
	this.direct_port = config["direct_port"];
	if (!this.direct_port) this.direct_port = 8000;
	this.direct_ip = config["direct_ip"];
	if (!this.direct_ip) this.direct_ip = smartthing_getIP();
	this.api = smartthings;
	this.log = log;
	this.deviceLookup = {};
	this.firstpoll = true;
	this.attributeLookup = {}
SmartThingsPlatform.prototype = {
	reloadData: function (callback) {
		var that = this;
		var foundAccessories = [];
		this.log.debug("Refreshing All Device Data");
		smartthings.getDevices(function (myList) {
			that.log.debug("Received All Device Data");
			// success
			if (myList && myList.deviceList && myList.deviceList instanceof Array) {
				var populateDevices = function (devices) {
					for (var i = 0; i < devices.length; i++) {
						var device = devices[i];
						var accessory = undefined;
						if (that.deviceLookup[device.deviceid]) {
							accessory = that.deviceLookup[device.deviceid];
							accessory.loadData(devices[i]);
						} else {
							accessory = new SmartThingsAccessory(that, device);
							if (accessory != undefined) {
								if ((accessory.services.length <= 1) || (accessory.deviceGroup == "unknown")) {
									if (that.firstpoll) that.log("Device Skipped - Group " + accessory.deviceGroup + ", Name " + accessory.name + ", ID " + accessory.deviceid + ", JSON: " + JSON.stringify(device));
								} else {
									that.log("Device Added - Group " + accessory.deviceGroup + ", Name " + accessory.name + ", ID " + accessory.deviceid)//+", JSON: "+ JSON.stringify(device));
									that.deviceLookup[accessory.deviceid] = accessory;
									foundAccessories.push(accessory);
				if (myList && myList.location) {
					that.temperature_unit = myList.location.temperature_scale;
				populateDevices(myList.deviceList);
			} else if ((!myList) || (!myList.error)) {
				that.log("Invalid Response from API call");
			} else if (myList.error) {
				that.log("Error received type " + myList.type + ' - ' + myList.message);
			} else {
			if (callback)
				callback(foundAccessories)
			that.firstpoll = false;
	accessories: function (callback) {
		this.log("Fetching Smart Things devices.");
		var that = this;
		this.deviceLookup = [];
		this.unknownCapabilities = [];
		this.knownCapabilities = ["Switch", "ColorControl", "Battery", "Polling", "Lock", "Refresh", "LockCodes", "Sensor", "Actuator",
			"Configuration", "SwitchLevel", "TemperatureMeasurement", "MotionSensor", "ColorTemperature",
			"ContactSensor", "ThreeAxis", "AccelerationSensor", "Momentary", "DoorControl", "GarageDoorControl",
			"RelativeHumidityMeasurement", "PresenceSensor", "Thermostat", "EnergyMeter", "PowerMeter",
			"ThermostatCoolingSetpoint", "ThermostatMode", "ThermostatFanMode", "ThermostatOperatingState",
			"ThermostatHeatingSetpoint", "ThermostatSetpoint", "Indicator"];
		this.temperature_unit = 'F';
		smartthings.init(this.app_url, this.app_id, this.access_token);
		this.reloadData(function (foundAccessories) {
			that.log("Unknown Capabilities: " + JSON.stringify(that.unknownCapabilities));
			callback(foundAccessories);
			setInterval(that.reloadData.bind(that), that.polling_seconds * 1000);
			//Initialize Update Mechanism for realtime-ish updates.
			if (that.update_method==='api') //Legacy API method.
				setInterval(that.doIncrementalUpdate.bind(that), that.update_seconds * 1000);
			else if (that.update_method==='pubnub') { //Uses user's PubNub account
				that.api.getSubscriptionService(function(data) {
					pubnub = new PubNub({ subscribeKey : data.pubnub_subscribekey });
					pubnub.addListener({
							status: function(statusEvent) { if (statusEvent.category==='PNReconnectedCategory') that.reloadData(null); },
							message: function(message) { that.processFieldUpdate(message.message, that); } });
        			pubnub.subscribe({ channels: [ that.pubnub_channel ] });
			else if (that.update_method=='direct') { //The Hub sends updates to this module using http
				smartthings_SetupHTTPServer(that);
				smartthings.startDirect(null,that.direct_ip, that.direct_port);
	addAttributeUsage: function(attribute, deviceid, mycharacteristic) {
		if (!this.attributeLookup[attribute])
			this.attributeLookup[attribute] = {};
		if (!this.attributeLookup[attribute][deviceid])
			this.attributeLookup[attribute][deviceid] = [];
		this.attributeLookup[attribute][deviceid].push(mycharacteristic);
	doIncrementalUpdate: function() {
		var that=this;
		smartthings.getUpdates(function(data) { that.processIncrementalUpdate(data, that)});
	processIncrementalUpdate: function(data, that) {
		if (data && data.attributes && data.attributes instanceof Array) {
			for (var i = 0; i < data.attributes.length; i++) {
				that.processFieldUpdate(data.attributes[i], that);
	processFieldUpdate: function(attributeSet, that) {
		//that.log("Processing Update");
		if (!((that.attributeLookup[attributeSet.attribute]) && (that.attributeLookup[attributeSet.attribute][attributeSet.device]))) return;
		var myUsage = that.attributeLookup[attributeSet.attribute][attributeSet.device];
		if (myUsage instanceof Array) {
			for (var j = 0; j < myUsage.length; j++) {
				var accessory = that.deviceLookup[attributeSet.device];
				if (accessory) {
					accessory.device.attributes[attributeSet.attribute] = attributeSet.value;
					myUsage[j].getValue();
function smartthing_getIP() {
	var myIP = '';
	var ifaces = os.networkInterfaces();
	Object.keys(ifaces).forEach(function (ifname) {
  		var alias = 0;
		ifaces[ifname].forEach(function (iface) {
    		if ('IPv4' !== iface.family || iface.internal !== false) {
      			// skip over internal (i.e. 127.0.0.1) and non-ipv4 addresses
      			return;
    	myIP = iface.address;
	return myIP;
function smartthings_SetupHTTPServer(mySmartThings) {
	//Get the IP address that we will send to the SmartApp. This can be overridden in the config file.
	//Start the HTTP Server
	const server = http.createServer(function(request,response) {
				smartthings_HandleHTTPResponse(request, response, mySmartThings)});
	server.listen(mySmartThings.direct_port, (err) => {
  		if (err) {
    		mySmartThings.log('something bad happened', err);
			return '';
		mySmartThings.log(`Direct Connect Is Listening On ${mySmartThings.direct_ip}:${mySmartThings.direct_port}`);
	return 'good';
    	if (request.url == '/update') {
		var jsonString = '';
	        request.on('data', function (data) {
			jsonString += data;
        	request.on('end', function () {
	    		var tmp = JSON.parse(jsonString.trim());
            		//console.log(tmp);
 			var newChange = { device: tmp.device,
                                  attribute: tmp.attribute,
                                  value: tmp.value,
                                  date: tmp.date};
			//console.log(`Direct Update tmp.device ${tmp.device}`);
	else {
	response.end('OK');
smartthingsapi.js
var app_host;
var app_port;
var app_path;
var access_token;
    var options = {
        hostname: app_host,
        port: app_port,
        headers: {}
    var that = this;
    if (data.data) {
    var str = '';
            str += chunk;
            try {
            } catch (e) {
                if (data.debug) {
                str = undefined;
    if (data.data) {
    req.end();
var smartthings = {
        GET({ debug: true, path: 'devices' }, function (data) {
        GET({ debug: true, path: deviceid + '/query' }, function (data) {
            if (data) {
            } else {
        GET({ debug: true, path: 'getUpdates' }, function (data) {
        POST({ debug: true, path: deviceid + '/command/' + command, data: values }, function (data) {
        GET({ debug: true, path: 'startDirect/' + myIP + '/' + myPort }, function (data) {
        GET({ debug: true, path: 'getSubcriptionService' }, function (data) {
continued in next post due to size limitations… :wink:
smartthings.js
    if (oAccessory) {
        Service = oService;
        uuid = ouuid;
    this.state = {};
    var that = this;
        return myService
                    if (value)
                    else
            	    if (value > 0)
                    if (value)
                    else
                    case 'open':
                        break;
                    case 'opening':
                        break;
                    case 'closed':
                        break;
                    case 'closing':
                        break;
                    default:
                        break;
                    case 'locked':
                        break;
                    case 'unlocked':
                        break;
                    default:
                        break;
                    case 'locked':
                        break;
                    case 'unlocked':
                        break;
                    default:
                        break;
                switch (value) {
                        break;
                        break;
                if (value)
                else
                else
                else
                else
                else
                else
                    case "cooling":
                        break;
                    case "heating":
                        break;
                        break;
                    case "cool":
                        break;
                    case "heat":
                        break;
                    case "auto":
                        break;
                        break;
                switch (value) {
                        break;
                        break;
                        break;
                        break;
                else
                    case "cool":
                        break;
                    case "heat":
                        break;
                        break;
                if (!temp)
                else
                var temp = value;
                    temp = value;
                else
                    case "cool":
                            value1: temp
                        break;
                    case "heat":
                            value1: temp
                        break;
                        if (isHighTemp) {
                        } else {
                        break;
                else
                else
                var temp = value;
                    temp = value;
                else
                    value1: temp
                else
                var temp = value;
                    temp = value;
                else
                    value1: temp
    var that = this;
        this.device = data;
    } else {
            this.device = data;
My Hubitat arrived today. I should be able to get it setup with some bulbs tonight and then I’ll start work on a targeted homebridge-hubitat plugin.
So installed a docker version of homebridge and installed the JSON app into hubitat.
Edited the config.json and got to the following:image
I think this is due to the fact that I did not edit the index.js and smartthingsapi.js files. Reason being, I can't find them. Where are they to edit?__
Anyone now how to edit the index.js?
I just used nano to edit it. Are you still having trouble finding the files? I had to google how to use the linux “find” command to find them. I do not recall their locations off the top of my head.
If you want to simply copy the pre-edited files I posted above from a windows pc to your raspberry pi (after figuring out where these files are located, of course), you might want to use WinSCP via a SSH connection. You’ll need to enable SSH in the raspberry pi first, of course.
Hopefully Paul (@pdlovelace) is making some progress on a Hubitat specific homebridge plug-in.
Editing the file is easy, but I cannot seem to find the file in the docker repository.
It is in the root of this GitHub repository... I did not use Docker. I just followed the installation instructions and then started hacking on the files until I got something to work. The files I posted above are the ones that I hacked up! :wink:
I guess that I made the assumption that anyone trying this had already been through the exercise of installing Homebridge + the Homebridge-SmartThings plug-in already. That was my starting point. Probably a good idea to get it working with SmartThings first to know the basics are in place before starting to edit things.
Hi Paul - just checking in to see how you're progressing with your new Hubitat... Any status update on the homebridge plug-in?
Thanks,
Dan
Any progress on this?
Please don’t let this die.
Agreed! @pdlovelace Paul - any update on your progress for a Homekit/Hubitat integration solution?
