Iāve been working on a modified version of paulās SmartThing version that fixes bugs and adds SmartHomeMonitor support to Homekit.
Iām very close to having this functioning on Hubitat the holdup is HubitatSimpleMonitor status not being queriable yet.
What is this?
Think of it as the alarm system control.
Okā¦ thatās what I thought. I havenāt yet started down the path of alarm system control until I have full ācontrolā over presence (sort of difficult because we have babysitters).
You did great work on the ST Nest App so whatever you are brewing up (I am sure) will kick butt. Best of luck and if you need a dummy guinea pig that wonāt yell or get upset that you broke his smart home, sign me up because to simply have a home kit dashboard means quite a bit more than having a home kit dashboard with alarm capability.
My alarm system is independent of HomeKit and Iām completely fine with that. Itās job is to protect my home and notify me, and it does that quite reliably. Iām sure your additional features will be great, but weāre really anxious to get the core integration between Hubitat and Homebrige.
Thanks Tony! Iāll give this a try later this week and will let you know how the testing goes!
No problemā¦ Donāt enable the Alarm function yet it will just error out until itās added to the platform
Thank you so much!
I havenāt been able to test it with all devices so let me know if something doesnāt work
Definitely will. Just reading your instructions now. Thanks again.
you can generate your config data right in the App interface in Hubitat. Just copy/paste into the config.json in Homebridge
Anyone testing, be sure to disable HSM āAdd Alarm Control in HomeKit?ā in the Hubitat App, as it is enabled by default
I swear I disabled that setting by default. Itās corrected now
Iām a little confused by these instrutions:
If you installed the previous update that doesnāt allow selecting devices, you need to goto āMy Locationsā and then āList Smartappsā to remove the multiple installation.
and
- Click on the app in the list and then click āApp Settingsā
- Scroll down to the OAuth section and click āEnable OAuth in Smartappā
- Select āUpdateā at the bottom.
and
To get this information, open Hubitat on your phone, goto āAutomationā >āSmartAppsā >āJSON Complete APIā and tap on Config
They sound like SmartThings instructions. Am I missing something?
Iāve enable my devices in the Hubitat app, but when I click āView the Configuration Data for Homebridgeā, I get {āmessageā: āInternal server errorā} with the api id and token in the URL
Do we still need SmartThings for this? If so, can the SmartThings Homebridge plug-in still be used simultaneously?
I can manually configure the Config.json if thatās what Iām missing and misunderstanding the use of the āView the Configuration Data for Homebridgeā option. I apologies, as I havenāt been following your development of this. Maybe you mentioned that it would still require SmartThings and I missed that. I was under the impression this was simply Hubitat to Homebridge.
I apologize for the confusion I used the readme from the smartthings plugin and just tried to modify it.
I was trying to get this out there before I leave for vacation on Saturday.
I updated the instructions slightly to remove some confusion.
This does not require SmartThings at all and can be used along side the SmartThings homebridge-plugin.
Because Tony's going on Vacation I decided I would try to be "helpful"
I modified the instructions regarding format and a couple of typos... added 'advice' in the config.json area. Maybe better, maybe worse.. but free !!
Have you tried it? I'm not able to get it working. I do already have Homebridge configured and working for SmartThings, Wink and Insteon
When I click, āView the Configuration Data for Homebridgeā, it tries to open the URL, but I get {āmessageā: āInternal server errorā} with the api id and token showing in the URL
So I tried to manually configure the Config.json file with the API url and token that I see at the top of the error page, but it seems I donāt have it right because I get an error now when I try to start Homebridge. Hereās what Iāve entered in the config.json file and the result.
āplatformsā: [
āplatformā: āHubitatā,
ānameā: āHubitatā,
āapp_urlā: āhttps://cloud.hubitat.com/api/92f88315-8a7a-4ae3-99cc-1c599bfda070/apps/174/ā,
āaccess_tokenā: āc4642434-ad64-4ded-b8dd-5f3c58c4bb0dā,
ādirect_ipā: ā192.168.1.126ā,
ādirect_portā: 8000,
Terminal output isā¦
/usr/local/lib/node_modules/homebridge/lib/server.js:201
config = JSON.parse(fs.readFileSync(configPath));
SyntaxError: Unexpected token } in JSON at position 727
at Object.parse (native)
at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:201:19)
at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:57:38)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
at Object. (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:570:32)
at Object.Module._extensionsā¦js (module.js:579:10)
at Module.load (module.js:487:32)
at tryModuleLoad (module.js:446:12)
at Function.Module._load (module.js:438:3)
Working... hmm. I guess No is the most correct answer.
I had it working with SmartThings and my Thermostat.
But after restarting with the Hubitat config, my Home app on the phone does not see Homebridge.
The Homebridge server starts and reads in all of the Hubitat devices, so I'm thinking that part is ok. However, when I delete everything from the Home app on IOS to repair.. it asks for the pin and when I type that in, it says "Already connected, you may have to reset." and does not see Homebridge. It DOES show the Lutron Pro, which I have no need to pair to Homekit. The message is odd given I'm deleting the entire "home" from the Home IOS App AND restarting Homebridge.
I did follow the full install instructions which included upgrading Homebridge itself, along with installing the all new Hubitat-Homebridge connector. Maybe I will retry that in a different order.
A portion of startup of Homebridge looks like:
2018-3-21 13:36:29 > [2018-3-21 13:36:29] Loading 3 platforms...
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [Thermostat] Initializing tcc platform...
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [Thermostat] Logging into tcc...
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [Hubitat] Initializing Hubitat platform...
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [Hubitat] Fetching Hubitat devices.
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [Hubitat] update_method: direct
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [SmartThings] Initializing homebridge-smartthings.SmartThings platform...
2018-3-21 13:36:29 > [2018-3-21 13:36:29] [SmartThings] Fetching Smart Things devices.
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Thermostat] Logged into tcc! [ { deviceID: '864866', name: 'Main Floor' } ]
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Thermostat] Adding TCC Device Main Floor 864866
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Thermostat] Initializing platform accessory 'Main Floor'...
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Thermostat] getServices Main Floor
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Thermostat] updateValues 1
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Hubitat] Unknown Capabilities: ["Outlet","UltravioletIndex","Tone","SpeechSynthesis"]
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Hubitat] Initializing platform accessory 'BBQ Domitech Bulb'...
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Hubitat] Initializing platform accessory 'BBQ Switch'...
Followed by the other 50 Hubitat devices, plus:
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Hubitat] Initializing platform accessory 'MasterBath Light'...
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Hubitat] Direct Connect Active On: ( 192.168.7.129:8005)
2018-3-21 13:36:31 > [2018-3-21 13:36:31] [Hubitat] Hubitat Hub Communication Established
my config.json is abreviated and taken from the App itself:
{ "platform": "Hubitat", "name": "Hubitat", "app_url": "http://192.168.7.66/apps/api/236/", "access_token": "bxxxxxxx-6xxx-xxx-xxxx03" }
Try pasting your config into this site:
it's helped me everytime I had a json to cure.
Ah, OK. I went ahead and posted my access token because you just delete the app and reinstall it and you get a new access token anyway. I just donāt understand why I get an error when I click to get the config details.
Anyway, Iāll manually configure if I have the right details to put in there. I guessed at what should be set for app_url based on what I saw on the error page, so based on what you have, I obviously have that wrong. What is 192.168.7.66 ? Is that the IP of your Hubitat or your Homebridge?
.66 is the Hubitat Hub.
go into apps and pick the Hubitat app... then scroll down.
click that "View Configuration Data..." and you'll see a FULL config.json
As you can see from my previous response, I used just the "middle" portion of what it displays. I copy/pasted that into the middle of my existing config.json (added a comma between) and that is what worked for me.
Save your config.json. Then create a new/empty one. Paste in the config from the app. See if that gets you further.
