Hi,
Is there any chance for getting working drivers for FGSD-002, at this moment there is no working driver for this device.
-Sebastian
Hi,
-Sebastian
Sounds delicious. Where do I get one of these smore sensors?
I have driver for ZW5 version.
I'm not on my PC at the moment. Will post later if you want.
Yop, this is really nice looking piece of sensor and can be found on amazon.
Unfortunetly i've tested it with ZW5 and there is some problem, temperature sensor works fine but when detecting smoke there is something like this in log:
2019-06-20 17:18:12.040 errorgroovy.lang.MissingMethodException: No signature of method: hubitat.zwave.Zwave.commandClass() is applicable for argument types: (java.lang.Short, java.lang.Integer) values: [113, 3] on line 520 (parse)
Are you using the native driver or a custom one?
I have tested Generic Z-Wave Smoke Detector, later i found this (below) and there is no info about detecting smoke.
* FIBARO Smoke Sensor
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Fibaro Smoke Sensor ZW5", namespace: "FibarGroup", author: "Fibar Group") {
capability "Battery"
capability "Configuration"
capability "Sensor"
capability "Smoke Detector"
capability "Temperature Measurement"
attribute "heatAlarm", "enum", ["overheat", "inactive"]
attribute "tamperStatus", "string"
fingerprint mfr:"010F", prod:"0C02"
fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x86, 0x72, 0x5A, 0x59, 0x85, 0x73, 0x84, 0x80, 0x71, 0x56, 0x70, 0x31, 0x8E, 0x22, 0x9C, 0x98, 0x7A", outClusters: "0x20, 0x8B"
simulator {
//battery
for (int i in [0, 5, 10, 15, 50, 99, 100]) {
status "battery ${i}%": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: i)
).incomingMessage()
status "battery 100%": "command: 8003, payload: 64"
status "battery 5%": "command: 8003, payload: 05"
//smoke
status "smoke detected": "command: 7105, payload: 01 01"
status "smoke clear": "command: 7105, payload: 01 00"
status "smoke tested": "command: 7105, payload: 01 03"
//temperature
for (int i = 0; i <= 100; i += 20) {
status "temperature ${i}F": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().sensorMultilevelV5.sensorMultilevelReport(scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1)
).incomingMessage()
preferences {
input(
title: "Fibaro Smoke Sensor manual",
description: "Tap to view the manual.",
image: "http://manuals.fibaro.com/wp-content/uploads/2017/07/sd_icon.png",
url: "http://manuals.fibaro.com/content/manuals/en/FGSD-002/FGSD-002-EN-A-v1.1.pdf",
type: "href",
element: "href"
parameterMap().each {
getPrefsFor(it)
tiles (scale: 2){
multiAttributeTile(name:"FGSD", type: "lighting", width: 6, height: 4){
tileAttribute ("device.smoke", key: "PRIMARY_CONTROL") {
def url = "http://fibaro-smartthings.s3-eu-west-1.amazonaws.com/smoke/"
attributeState("clear", label:"CLEAR", icon: url + "smoke-sensor0.png", backgroundColor:"#ffffff")
attributeState("detected", label:"SMOKE", icon: url + "smoke-sensor1.png", backgroundColor:"#e86d13")
attributeState("tested", label:"TEST", icon: url + "smoke-sensor1.png", backgroundColor:"#e86d13")
attributeState("unknown", label:"UNKNOWN", icon:url + "smoke-sensor1.png", backgroundColor:"#ffffff")
tileAttribute("device.multiStatus", key: "SECONDARY_CONTROL") {
attributeState("multiStatus", label: '${currentValue}')
valueTile("tamperStatus", "device.tamperStatus", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state("tamperStatus", label:'${currentValue}')
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:"%"
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("heatAlarm", "device.heatAlarm", inactiveLabel: false, width: 4, height: 2) {
state "inactive", label:'No temperature alarm', backgroundColor:"#ffffff"
state "overheat", label:'Temperature alarm', backgroundColor:"#bc2323"
standardTile("syncStatus", "device.syncStatus", decoration: "flat", width: 2, height: 2) {
def syncIconUrl = "http://fibaro-smartthings.s3-eu-west-1.amazonaws.com/keyfob/sync_icon.png"
state "synced", label: 'OK', action: "forceSync", backgroundColor: "#00a0dc", icon: syncIconUrl
state "pending", label: "Pending", action: "forceSync", backgroundColor: "#153591", icon: syncIconUrl
state "inProgress", label: "Syncing", action: "forceSync", backgroundColor: "#44b621", icon: syncIconUrl
state "incomplete", label: "Incomplete", action: "forceSync", backgroundColor: "#f1d801", icon: syncIconUrl
state "failed", label: "Failed", action: "forceSync", backgroundColor: "#bc2323", icon: syncIconUrl
state "force", label: "Force", action: "forceSync", backgroundColor: "#e86d13", icon: syncIconUrl
main "FGSD"
details(["FGSD","temperature", "battery", "heatAlarm", "tamperStatus", "syncStatus"])
//UI Support functions
def getPrefsFor(parameter) {
input(
title: "${parameter.num}. ${parameter.title}",
description: parameter.descr,
type: "paragraph",
element: "paragraph"
input(
title: null,
type: parameter.type,
options: parameter.options,
range: (parameter.min != null && parameter.max != null) ? "${parameter.min}..${parameter.max}" : null,
defaultValue: parameter.def,
required: false
def updated() {
log.debug "Updated"
if (state.lastUpdated && (now() - state.lastUpdated) < 2000) return
def cmds = []
def cmdCount = 0
if (settings."$it.key" == null || state."$it.key" == null) {
state."$it.key" = [value: it.def as Integer, state: "notSynced"]
if (settings."$it.key" != null) {
if (state."$it.key".value != settings."$it.key" as Integer || state."$it.key".state == "notSynced") {
state."$it.key".value = settings."$it.key" as Integer
state."$it.key".state = "notSynced"
cmdCount = cmdCount + 1
} else {
if (state."$it.key".state == "notSynced") {
if (cmdCount > 0) {
logging("${device.displayName} - sending config.", "info")
sendEvent(name: "syncStatus", value: "pending")
state.lastUpdated = now()
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
log.info "Executing zwaveEvent 86 (VersionV1): 12 (VersionReport) with cmd: $cmd"
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} battery is low"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbatt = now()
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationBusy cmd) {
def msg = cmd.status == 0 ? "try again later" :
cmd.status == 1 ? "try again in $cmd.waitTime seconds" :
cmd.status == 2 ? "request queued" : "sorry"
createEvent(displayed: true, descriptionText: "$device.displayName is busy, $msg")
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
log.info "Executing zwaveEvent 71 (NotificationV3): 05 (NotificationReport) with cmd: $cmd"
def result = []
if (cmd.notificationType == 7) {
switch (cmd.event) {
case 0:
//result << createEvent(name: "tamper", value: "Tamper is inactive", displayed: false)
sendEvent(name: "tamperStatus", value: "Tamper inactive")
break
case 3:
//result << createEvent(name: "tamper", value: "Tamper is active", descriptionText: "$device.displayName casing was opened")
sendEvent(name: "tamperStatus", value: "Tamper active")
break
break
break
} else if (cmd.notificationType == 1) { //Smoke Alarm (V2)
log.debug "notificationv3.NotificationReport: for Smoke Alarm (V2)"
result << smokeAlarmEvent(cmd.event)
} else if (cmd.notificationType == 4) { // Heat Alarm (V2)
log.debug "notificationv3.NotificationReport: for Heat Alarm (V2)"
result << heatAlarmEvent(cmd.event)
} else if (cmd.notificationType == 8) {
if (cmd.event == 0x0A) {
def map = [:]
map.name = "battery"
map.value = 1
map.unit = "%"
map.displayed = true
result << createEvent(map)
} else if (cmd.notificationType == 9) {
if (cmd.event == 0x01) {
result << createEvent(descriptionText: "Warning: $device.displayName system hardware failure", isStateChange: true)
} else {
log.warn "Need to handle this cmd.notificationType: ${cmd.notificationType}"
result << createEvent(descriptionText: cmd.toString(), isStateChange: false)
result
private multiStatusEvent(String statusValue, boolean force = false, boolean display = false) {
sendEvent(name: "multiStatus", value: statusValue, descriptionText: statusValue, displayed: display)
def smokeAlarmEvent(value) {
def alarmInfo = "Last alarm detection: "
def alarmTestInfo = "Last alarm detection - TEST: "
log.debug "smokeAlarmEvent(value): $value"
def map = [name: "smoke"]
if (value == 2) {
map.value = "detected"
map.descriptionText = "$device.displayName detected smoke"
state.lastAlarmDate = "\n"+new Date().format("yyyy MMM dd EEE HH:mm:ss", location.timeZone)
multiStatusEvent(alarmInfo + state.lastAlarmDate)
} else if (value == 0) {
map.value = "clear"
map.descriptionText = "$device.displayName is clear (no smoke)"
} else if (value == 3) {
map.value = "tested"
map.descriptionText = "$device.displayName smoke alarm test"
multiStatusEvent(alarmTestInfo + state.lastAlarmDate)
} else {
map.value = "unknown"
map.descriptionText = "$device.displayName unknown event"
createEvent(map)
def heatAlarmEvent(value) {
log.debug "heatAlarmEvent(value): $value"
def map = [name: "heatAlarm"]
if (value == 2) {
map.value = "overheat"
map.descriptionText = "$device.displayName overheat detected"
map.value = "inactive"
map.descriptionText = "$device.displayName heat alarm cleared (no overheat)"
} else {
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
log.info "Executing zwaveEvent 84 (WakeUpV1): 07 (WakeUpNotification) with cmd: $cmd"
log.debug "WakeUpNotification"
def event = createEvent(descriptionText: "${device.displayName} woke up", displayed: false)
def cmds = []
def cmdsSet = []
def cmdsGet = []
def cmdCount = 0
def results = [createEvent(descriptionText: "$device.displayName woke up", isStateChange: true)]
cmdsGet << zwave.batteryV1.batteryGet()
cmdsGet << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0)
if (device.currentValue("syncStatus") != "synced") {
if (device.currentValue("syncStatus") == "force") {
if (state."$it.key"?.value != null && state."$it.key"?.state == "notSynced") {
cmdsSet << zwave.configurationV2.configurationSet(configurationValue: intToParam(state."$it.key".value, it.size), parameterNumber: it.num, size: it.size)
cmdsGet << zwave.configurationV2.configurationGet(parameterNumber: it.num)
log.debug "Not synced, syncing ${cmdCount} parameters"
sendEvent(name: "syncStatus", value: "inProgress")
runIn((5 + cmdCount * 1.5), syncCheck)
if (cmdsSet) {
cmds = encapSequence(cmdsSet, 500)
cmds << "delay 500"
cmds = cmds + encapSequence(cmdsGet, 1000)
cmds << "delay " + (5000 + cmdCount * 1500)
cmds << encap(zwave.wakeUpV1.wakeUpNoMoreInformation())
results = results + response(cmds)
return results
def syncCheck(){
logging("${device.displayName} - Executing syncCheck()", "info")
log.warn "CHECK"
def notSynced = []
def count = 0
if (state."$it.key"?.state == "notSynced") {
notSynced << it
log.warn "Sync failed! Verify parameter: ${notSynced[0].num}"
log.warn "Sync $it.key " + state."$it.key"
sendEvent(name: "batteryStatus", value: "Sync incomplited! Check parameter nr. ${notSynced[0].num}")
count = count + 1
if (count == 0) {
logging("${device.displayName} - Sync Complete", "info")
sendEvent(name: "syncStatus", value: "synced")
} else {
logging("${device.displayName} Sync Incomplete", "info")
if (device.currentValue("syncStatus") != "failed") {
sendEvent(name: "syncStatus", value: "incomplete")
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
log.info "Executing zwaveEvent 31 (SensorMultilevelV5): 05 (SensorMultilevelReport) with cmd: $cmd"
def map = [:]
switch (cmd.sensorType) {
case 1:
map.name = "temperature"
def cmdScale = cmd.scale == 1 ? "F" : "C"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
map.unit = getTemperatureScale()
break
default:
map.descriptionText = cmd.toString()
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.deviceresetlocallyv1.DeviceResetLocallyNotification cmd) {
log.info "Executing zwaveEvent 5A (DeviceResetLocallyV1) : 01 (DeviceResetLocallyNotification) with cmd: $cmd"
createEvent(descriptionText: cmd.toString(), isStateChange: true, displayed: true)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.info "Executing zwaveEvent 72 (ManufacturerSpecificV2) : 05 (ManufacturerSpecificReport) with cmd: $cmd"
log.debug "manufacturerId: ${cmd.manufacturerId}"
log.debug "manufacturerName: ${cmd.manufacturerName}"
log.debug "productId: ${cmd.productId}"
log.debug "productTypeId: ${cmd.productTypeId}"
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.DeviceSpecificReport cmd) {
log.debug "deviceIdData: ${cmd.deviceIdData}"
log.debug "deviceIdDataFormat: ${cmd.deviceIdDataFormat}"
log.debug "deviceIdDataLengthIndicator: ${cmd.deviceIdDataLengthIndicator}"
log.debug "deviceIdType: ${cmd.deviceIdType}"
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
def result = []
if (cmd.nodeId.any { it == zwaveHubNodeId }) {
result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
} else if (cmd.groupingIdentifier == 1) {
result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
result
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
def map = [:]
case 1:
map.name = "smoke"
map.value = cmd.sensorState == 0xFF ? "detected" : "clear"
map.descriptionText = cmd.sensorState == 0xFF ? "$device.displayName detected smoke" : "$device.displayName is clear (no smoke)"
break
case 4:
map.name = "heatAlarm"
map.value = cmd.sensorState == 0xFF ? "overheat" : "inactive"
map.descriptionText = cmd.sensorState == 0xFF ? "$device.displayName overheat detected" : "$device.displayName heat alarm cleared (no overheat)"
break
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.timeparametersv1.TimeParametersGet cmd) {
log.info "Executing zwaveEvent 8B (TimeParametersV1) : 02 (TimeParametersGet) with cmd: $cmd"
def nowCal = Calendar.getInstance(TimeZone.getTimeZone("UTC"))
//Time Parameters are requested by an un-encapsulated frame
response(zwave.timeParametersV1.timeParametersReport(year: nowCal.get(Calendar.YEAR), month: (nowCal.get(Calendar.MONTH) + 1), day: nowCal.get(Calendar.DAY_OF_MONTH),
hourUtc: nowCal.get(Calendar.HOUR_OF_DAY), minuteUtc: nowCal.get(Calendar.MINUTE), secondUtc: nowCal.get(Calendar.SECOND)).format())
def zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "General zwaveEvent cmd: ${cmd}"
private command(hubitat.zwave.Command cmd) {
def secureClasses = [0x20, 0x5A, 0x70, 0x71, 0x84, 0x85, 0x8E, 0x9C]
if (isSecured() && secureClasses.find{ it == cmd.commandClassId }) {
log.info "Sending secured command: ${cmd}"
secure(cmd)
} else {
log.info "Sending unsecured command: ${cmd}"
crc16(cmd)
private secure(hubitat.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crc16(hubitat.zwave.Command cmd) {
//zwave.crc16encapV1.crc16Encap().encapsulate(cmd).format()
"5601${cmd.format()}0000"
private commands(commands, delay=200) {
log.info "inside commands: ${commands}"
delayBetween(commands.collect{ command(it) }, delay)
private setSecured() {
updateDataValue("secured", "true")
private isSecured() {
getDataValue("secured") == "true"
## Z-Wave Toolkit ##
def result = []
logging("${device.displayName} - Parsing: ${description}")
if (description.startsWith("Err 106")) {
result = createEvent(
descriptionText: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
displayed: true,
} else if (description == "updated") {
return null
} else {
def cmd = zwave.parse(description, cmdVersions())
if (cmd) {
logging("${device.displayName} - Parsed: ${cmd}")
zwaveEvent(cmd)
//event handlers related to configuration and sync
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
def paramKey = parameterMap().find({ it.num == cmd.parameterNumber }).key
logging("${device.displayName} - Parameter ${paramKey} value is ${cmd.scaledConfigurationValue} expected " + state."$paramKey".value, "info")
if (state."$paramKey".value == cmd.scaledConfigurationValue) {
state."$paramKey".state = "synced"
log.debug state."$paramKey"
//security
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
setSecured()
def encapsulatedCommand = cmd.encapsulatedCommand(cmdVersions())
if (encapsulatedCommand) {
log.debug "command: 98 (Security) 81(SecurityMessageEncapsulation) encapsulatedCommand: $encapsulatedCommand"
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = cmdVersions()[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
logging("${device.displayName} - Parsed Crc16Encap into: ${encapsulatedCommand}")
} else {
log.warn "Unable to extract CRC16 command from $cmd"
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
logging("${device.displayName} - Parsed MultiChannelCmdEncap ${encapsulatedCommand}")
zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
} else {
log.warn "Unable to extract MultiChannel command from $cmd"
private logging(text, type = "debug") {
if (settings.logging == "true") {
log."$type" text
private secEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using Secure Encapsulation, command: $cmd", "info")
private crcEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using CRC16 Encapsulation, command: $cmd", "info")
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private multiEncap(hubitat.zwave.Command cmd, Integer ep) {
logging("${device.displayName} - encapsulating command using MultiChannel Encapsulation, ep: $ep command: $cmd", "info")
zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint: ep).encapsulate(cmd)
private encap(hubitat.zwave.Command cmd, Integer ep) {
encap(multiEncap(cmd, ep))
private encap(List encapList) {
encap(encapList[0], encapList[1])
private encap(Map encapMap) {
encap(encapMap.cmd, encapMap.ep)
private encap(hubitat.zwave.Command cmd) {
if (zwaveInfo.zw.contains("s")) {
secEncap(cmd)
} else if (zwaveInfo.cc.contains("56")) {
crcEncap(cmd)
} else {
logging("${device.displayName} - no encapsulation supported for command: $cmd", "info")
cmd.format()
private encapSequence(cmds, Integer delay = 250) {
delayBetween(cmds.collect { encap(it) }, delay)
private List intToParam(Long value, Integer size = 1) {
def result = []
size.times {
result = result.plus(0, (value & 0xFF) as Short)
value = (value >> 8)
return result
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
log.warn "Flood Sensor rejected configuration!"
sendEvent(name: "syncStatus", value: "failed")
def zwaveEvent(hubitat.zwave.commands.securityv1.NetworkKeyVerify cmd) {
log.info "Executing zwaveEvent 98 (SecurityV1): 07 (NetworkKeyVerify) with cmd: $cmd (node is securely included)"
log.debug cmd
def zwaveEvent(hubitat.zwave.commands.securityv1.SecuritySchemeReport cmd) {
log.debug cmd
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
log.info "Executing zwaveEvent 98 (SecurityV1): 03 (SecurityCommandsSupportedReport) with cmd: $cmd"
def configure() {
state.lastAlarmDate = "-"
def cmds = []
//1. configure wakeup interval
cmds += zwave.wakeUpV1.wakeUpIntervalSet(seconds:4200, nodeid:zwaveHubNodeId)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, scaledConfigurationValue: 2)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: 0)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 20, size: 2, scaledConfigurationValue: 1)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 21, size: 1, scaledConfigurationValue: 11)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 30, size: 1, scaledConfigurationValue: 55)
cmds += zwave.wakeUpV1.wakeUpNoMoreInformation()
encapSequence(cmds, 500)
private Map cmdVersions() {
[0x86: 1, 0x72: 2, 0x59: 1, 0x73: 1, 0x80: 1, 0x56: 1, 0x31: 5, 0x22: 1, 0x98: 1, 0x7A: 2, 0x84: 1, 0x84: 2, 0x71: 3, 0x70: 1, 0x70: 2, 0x8E: 1, 0x8E: 2, 0x9C: 1, 0x5A: 1, 0x85: 1, 0x85: 2, 0x20: 1, 0x8B: 1]
private parameterMap() {
[key: "smokeSensorSensitivity", num: 1, size: 1, type: "enum", options: [
1: "High",
2: "Medium",
3: "Low"],
def: 2, title: "Fibaro Smoke Sensor sensitivity", descr: ""],
[key: "statusNotification", num: 2, size: 1, type: "enum", options: [
0: "all notifications disabled",
1: "casing opening notification enabled",
2: "exceeding temperature threshold notification enabled",
3: "casing opening and exceeding temperature threshold enabled"],
def: 0, title: "Status notification:", descr: "Notification sends in case of excess temperature and/or case opening"],
[key: "intervalOfTemperatureReports", num: 20, size: 2, type: "enum", options: [
1: "10s",
3: "30s",
6: "60s",
30: "300s",
60: "600s",
360: "3600s",
864: "8640s"],
def: 1, title: "Interval of temperature measurements", descr: "Time interval between temperature measurements. Report is sent when the measured value is different than previous one - specified in par. 21"],
[key: "temperatureReportsThreshold", num: 21, size: 1, type: "enum", options: [
3: "0.5°F / 0.3°C",
6: "1°F / 0.6°C",
11: "2°F / 1.1°C",
17: "3°F / 1.7°C",
22: "4°F / 2.2°C",
28: "5°F / 2.8°C"],
def: 11, title: "Temperature reports threshold ", descr: "Change of temperature resulting in temperature report being sent to the HUB."],
[key: "temperatureThreshold", num: 30, size: 1, type: "enum", options: [
55: "130°F / 55°C",
60: "140°F / 60°C",
65: "150°F / 65°C",
71: "160°F / 71°C",
77: "170°F / 77°C",
82: "180°F / 82°C",
93: "200°F / 93°C"],
def: 55, title: "Temperature threshold", descr: "Temperature above which the excess temperature notification is sent to the HUB (with visual and sound indication)"]
This is what Fibaro detector try to send to Hubitat
Crc16Encap(checksum:65535, command:5, commandClass:113, data:[0, 0, 0, 255, 1, 2, 0])
OK have some progress, after small modification i have correct tamper, temperature and smoke detection.
def encapsulatedCommand = zwave.getCommand(cmd.commandClass, cmd.command, cmd.data, version)
} else {
log.warn "Unable to extract CRC16 command from ${cmd}"
Nice work, I've been waiting to get these working
Glad to hear I just finished additional fixes and now everything works (for me) perfect:
metadata {
definition (name: "Fibaro Smoke Sensor FGSD-002 ZW5", namespace: "FibarGroup", author: "Fibar Group", modifier: "Sebastian Urbanski") {
capability "Sensor"
simulator {
//battery
).incomingMessage()
//smoke
//temperature
).incomingMessage()
preferences {
input(
type: "href",
element: "href"
getPrefsFor(it)
tiles (scale: 2){
backgroundColors:[
main "FGSD"
input(
type: "paragraph",
input(
title: null,
required: false
def updated() {
log.debug "Updated"
def cmds = []
def cmdCount = 0
} else {
if (cmdCount > 0) {
map.value = 1
} else {
createEvent(map)
def result = []
case 0:
break
case 3:
break
break
break
def map = [:]
map.value = 1
map.unit = "%"
} else {
result
if (value == 2) {
map.value = "clear"
} else {
createEvent(map)
if (value == 2) {
} else {
createEvent(map)
def cmds = []
def cmdsSet = []
def cmdsGet = []
def cmdCount = 0
//runIn((5 + cmdCount * 1.5), syncCheck)
if (cmdsSet) {
cmds << "delay 500"
return results
def syncCheck(){
log.warn "CHECK"
def notSynced = []
def count = 0
notSynced << it
count = count + 1
if (count == 0) {
} else {
def map = [:]
case 1:
break
default:
createEvent(map)
def result = []
result
def map = [:]
case 1:
map.name = "smoke"
break
case 4:
break
createEvent(map)
secure(cmd)
} else {
crc16(cmd)
def result = []
eventType: "ALERT",
value: "failed",
displayed: true,
return null
} else {
if (cmd) {
zwaveEvent(cmd)
//security
setSecured()
} else {
} else {
} else {
log."$type" text
//crcEncap(cmd)
cmd.format()
def result = []
size.times {
return result
log.debug cmd
log.debug cmd
def configure() {
def cmds = []
1: "High",
2: "Medium",
3: "Low"],
1: "10s",
3: "30s",
6: "60s",
30: "300s",
60: "600s",
360: "3600s",
864: "8640s"],
3: "0.5°F / 0.3°C",
6: "1°F / 0.6°C",
11: "2°F / 1.1°C",
17: "3°F / 1.7°C",
22: "4°F / 2.2°C",
28: "5°F / 2.8°C"],
55: "130°F / 55°C",
60: "140°F / 60°C",
65: "150°F / 65°C",
71: "160°F / 71°C",
77: "170°F / 77°C",
82: "180°F / 82°C",
Works a treat
This makes me sooo happy I have been waiting a while for this. Thank you for the great work @urbanski urbanski
Now I can finally buy some more of these great devices.
Have fun and I agree this is really nice piece of hardware.
No problem
Hey guys I am looking for a smoke sensor. Has the ZW5 been working well ?
For me still working fine. I tested it several times with real smoke and everything works like it should.
Same here
