Pool Water Temperature Sensor (2026)
Not directly. You’d need an Ecowitt gateway device as well.
Sensor talks to gateway over a proprietary RF connection, gateway connects to WiFi or Ethernet (depending on the model of gateway) and then there is a community-developed integration with Hubitat that can talk to the gateway over the LAN and bring the sensor data into Hubitat.
For some additional info, see here:
