I would like to propose adding a new capability "Occupancy" that would be used especially with all the new mmWave sensors and others of course like BLE beacons and others. This would finally help in distinguishing between presence, motion when we are dealing with this new technology.
+1
Beat me to it. ![]()
- another...
Big +1
@kkossev yes and it's 1 1/2 years later and still not added, this new tech is moving fast and will most likely become main stream real fast!
I'll do Devil's Advocate:
If we can live with motor speed being controlled by setLevel, where the driver converts 0-100 to discreet speeds, then we can live with the interchangeability of "Presence" vs "Occupancy"
In fact, I'd assume that it would be coded as an Alias internally.
There's a real world difference but I'm pretty sure the words have changed meaning over the past decade. I have an "occupancy switch" in my Laundry room. The instructions offer several modes where it can turn the light on and then off OR only turn the light off. The latter is called 'occupancy' by them... motion does not turn the light on, but if it is on, when there's no motion, it will turn the light off after some delay. I use it in "presence" mode, where the light is both turned on and then off by motion, or lack.
The result is the words have context dependent meanings or in the wilder world, "occupancy" is the lower sensitivity version of the idea. Yet the OP wants it for MM Wave devices, which are the higher sensitivity version of the idea.
The problem I see is NOT the invention of a new capability, but in how the resulting attribute gets used. If you have a room with both a traditional PIR motion sensor AND a mmWave sensor, then the use, in an automation, would be WHAT? I have this situation in 3 of my rooms, so I know what I want, and since I have (today) only the choice of "motion" am I unable/confused to create an automation? No. ![]()
They'd both be binary attributes: true or false, expressed as the corresponding word(s): active, inactive, occupied, not occupied, which further emphasizes the lack of a distinction. ![]()
Here's a Driver that supports "Occupancy", "Presence", "Motion" and "Switch":
If this would be a very rare case of a capability, sure just add it in the driver as you like, it does not need to be supported from HE to be able to declare it and use it.
BUT having it officially supported from HE makes it a capability that all drivers and apps would eventually use, those sensors that have both occupancy and motion would be a lot more useful and clear of what they are reporting for everyone including new users.
As to the interchangeability of the words, sure in the english language they could be interchanged, but in the automation world (at least to me), occupancy seems more like the room is occupied or not vs the house has a presence or not (nothing to do with ghosts). I believe it's just a better way of separating both of them and making them more specific.
Just my 2C and it will be HE's decision in the long run, but I think that the faster it's implemented/added, the faster it will be adopted by the drivers/apps that we develop.
My Devil's Advocate position is that it adds confusion, not reducing it.
The Zwave and Zigbee specs don't make the distinction as far as I remember, meaning that product manufacturers must choose to send either motion or presence. "Occupancy" isn't available to them, although it's been a while since I read the specs.
Totally understand your point!
To me, motion and occupancy are way different things. Presence vs occupancy blurs a bit, but I think there is a distinction.
- Motion would be people actively moving about a space. I think that is fairly straightforward.
- Occupancy would be someone is in a particular area, but not necessarily moving about. You are lounging on the sofa to watch a movie. Or you manually set this to state to keep lights on while you are sitting to read at the dining room table. It also could be sensed from motion.
- Presence would be someone is home, but not necessarily in the area that is being watched by an occupancy or motion sensor. To me, it is derived from something like a fob, phone, or similar detecting you are within range of the home. Maybe you are home, but in the yard, and don't want to lock the house (automatically) and stop your automations.
Here is a nice distinction made from Google AI
EDIT: When I first did this search of "Occupancy vs presence vs motion", the AI response gave a description of presence as being the presence of a device like a phone or other physical device that reports that it's inside a geofenced area or within reach of another device. Now that a reread what I pasted below, even I'm as confused as the Google's AI
AI Overview
In the context of smart home or building automation, "motion," "presence," and "occupancy" describe different levels of detecting human presence and activity. Motion refers to detecting movement, presence detects even subtle movements or body heat, and occupancy often implies the overall state of being in a space, which can be triggered by motion or presence detection and may persist for a time even after movement stops.
Here's a more detailed breakdown:
- Motion Sensors:
- Detects: Movement of objects, often within a specific range and sensitivity.
- Typically used for: Triggering actions based on movement, like turning on lights or triggering an alarm.
- Limitations: Can be triggered by pets, objects, or fail to detect someone who is still.
- Presence Sensors:
- Detects:
Subtle human presence, including small movements like breathing or body heat.
More accurate detection of occupancy in spaces where people might be still (e.g., reading, working at a desk), and can be used for controlling lighting, temperature, or other systems.
- May use:
Technologies like PIR (Passive Infrared), ultrasonic, or radar/microwave sensors.
- Occupancy Sensors:
- Concept:
Encompasses the overall state of being in a space, which can be triggered by motion or presence sensors.
- Functionality:
May combine motion and/or presence detection with a timer or other logic to determine occupancy and control systems.
- Example:
A light might turn on when motion is detected (motion sensor) and stay on for a set period after the last motion (occupancy logic).
- Often used for:
Controlling lighting, HVAC, and other systems based on whether a space is occupied or not, even if the occupants are not actively moving.
In essence:
- Motion sensors are basic movement detectors.
- Presence sensors are more sensitive and can detect subtle movements or body heat.
- Occupancy sensors combine motion and/or presence detection with logic to determine if a space is occupied, and may persist after the initial trigger.
Just to add to the fun and confusion, we have Hubitat's (thanks to its SmartThings heritage) use of "Presence" to indicate geofence-based user location. Whereas many mmWave sensor manufactures have chosen to call their devices "Presence Sensors" instead of "Motion Sensors."
I wonder if the Matter specification calls these out separately or not? If so, I wonder what that team's thinking was?
Just playing with some of these Moe's Human Presence Sensors (as they say on the box) so in my Hubitat labelling system (if one can call it that
) I've added HPS to the Motion designation of the device.
Seems like the logical Capability name to use would be Human. ![]()
Personally, that's ideally what I want to know, if a Human is in a specific area, or not. ![]()
I still don't see the big distinction between occupancy and presence so that occupancy should be its own capability. Presence always represents an area. In a geofence driver, the presence attribute indicates the house occupancy. The motion attribute in a motion driver indicates area occupancy. Why do we need different names? The driver that is reporting tells us what kind of area we are monitoring based on the device location itself.
There is no reason presence capability cannot be used in a motion sensor driver to indicate occupancy. The mmWave sensors that can track multiple bodies and determine when they enter or leave the area can report when the area is empty. A Hubitat driver can just implement an empty area report as presence, using the existing capability, while still using motion capability for the motion attribute (which in this case indicates area activity, not occupancy, though an active area would always be occupied by definition). Thing is, a custom attribute called occupancy works just as well without being part of a defined capability like presence, if you really want to know when the area has emptied.
I personally do not care if this occupancy attribute that gets updated by the sensor driver is part of a defined capability or not, I only want the status it represents to trigger things. Presence is a defined capability that can be used for occupancy, so there is no need for an occupancy capability. Occupancy as a custom named attribute in the driver is really all that is needed, or the driver can use the presence attribute if you really want it to use an existing capability attribute to represent occupancy.
Only in a geofence device driver does presence indicate geofense. It can be used for anything, it is just a capability, and that is simply the way it is commonly used.
Just like soil moisture sensors use the humidity capability, and there is no moisture capability. The capabilities are really more general than what the specific devices measure. There is a water sensor capability, for example, but many leak sensor drivers just use the contact sensor capability, because that is what they actually are - dry contact sensors.
I think I get the distinction between occupancy and presence. For presence, you know which device/who is there, but you don’t know precisely were. With occupancy, you would know that someone is in a place, but not which device/who.
Having occupancy would be very valuable. If I want to open the lights and keep them open, I don’t care who’s in the house, I care someone’s in the room.
But what about "occupancy" and "motion"?
Your use case sounds the same as motion sensors -- most of which now happen to be PIR, though video-based detection is also used by some cameras that are supported by Hubitat and expose this feature via this capability, so there's really no connection to the underlying technology.
While I don't think it's inherently a bad idea, none of the arugments I've seen so far have convinced me that a new capability is necessary. The drawbacks to adding a new capability for similar functionality are significant, as all apps would need to be updated to use this new capability (assuming you want to use it easily, which is presumably part of the intention). And then there's the question of what apps could do with it differently even if it existed -- isn't the use case the same as motion? Some apps already offer different options for different motion sensors, like an option to use some to turn on lights and some to keep (but not turn) on the lights, so if the intent is to just use the sensors differently, this would already be possible to add at an app level without platform changes (if the app can't do whatever the difference would be already -- this was just one example that does already exist).
Just my opinion. I like hearing others and am open to being convinced; just so far I'm not. ![]()
Let's make a more simple example of presence VS motion. Sleeping person. They are present. They are not moving around.
I like the idea of a virtual presence object. Keep it fed with indicators like power usage, water usage, motion etc including mmwave that detects micro movements like breathing and heartrate.
Motion could be anything that is moving. That’s not occupancy. That my robovac is going through the room, or some fan, or drapes, or a sheet is moving, that’s motion. That’s not occupancy.
One day we will have sensors that can tell if a mass of about 30-45 Celsius of the size and shape of a person is present in the room. It won’t matter if they are sleeping or moving or completely still. It may not be the mmWave sensors, but it’s going to happen.
