I was able to get Securifi to send me the OTA file for the peanut plugs. However, I'm struggling to figure out a mechanism to send the OTA file to the device.
Given the peanut plugs are Zigbee devices, I have a raspbee module installed on a Raspberry Pi. I loaded deconz and Phoscon on the Pi in an attempt to push the OTA update. The update is queued and it looks like the device is checking, but it never takes the update. I let it sit all night and it didn't work.
Is there another method I can use to push OTA updates to Zigbee devices? Any ideas would be appreciated.
I thought the only way to update these was through the Almond router. You definitely can't update them through Hubitat. Hubitat doesn't support firmware updates. You would have to get some other hardware, like a Conbee, to perform the update. With a Conbee (or Conbee II), the dezonz software allows for OTA updates.
Also, if you wouldn't mind sharing that file, I would appreciate it. Just shoot me a pm if you could.
In the end...this isn't really any different than using an Almond router. Cheap clone, but still the same process. I was hoping for a better hack than "buy this, update it with Almond Firmware, and flash your device".
MIght be just as cheap to grab an Almond off ebay. Or ask someone on here with an almond to flash the firmware.
It should work. Based on what I read, you're effectively buying a hardware copy of an Almond 2015, so...with the Almond Firmware on it...you should be golden.
Using my Almond, getting the Peanuts flashed takes bout 5 minutes or so, and is pretty easy to do.
I flashed several the other day, and the nice thing is they are crazy easy to pair with either hub, so the process is pretty quick.
They work well as zigbee repeaters for ZHA 1.2 compliant devices with Hubitat (so no Xiaomi Mijia/Aqara devices). Also, once you flash the new firmware, they will power report even with the generic zigbee outlet driver.
Got the cheap HomeScreen router today. Flashed with Almond 2015 firmware (AL2-R109). Working my way through upgrading the firmware on my Peanut outlets now.
I have a couple that did not do power reporting with the generic driver which was okay because I put them where I didn't need/want it and didn't want to spend the money for an actual Almond...
Interestingly, some outlets that were reporting power also had updates available. So far the plugs I have updated are working just as before, but now with power monitoring.
I found the Peanut driver still delivers a Warning message in the logs for some message that Hubitat can't parse, so I went into the driver and commented out the warning generation.
Once I did that, my updated Peanuts are nice and quiet (log wise) but seem to report power utilization well.
Dude that is so freaking awesome. Grabbed one
Thank You, I love flashing stuff, it's like a frankenrouter.
and for 15 bucks, the fun will last longer than a case of beer and I won't have a hangover after!
Have you tried using the repeater function? I've been looking at expanding my wifi into my garage for a couple of low-bandwidth devices. For 15 bucks, it might be worth it.
I don't believe in the "Amazon Rental Program". I returned something recently that I didn't even open just because I changed my mind and I felt guilty about that! lol
