I'm using a Silicon Labs Z-Stick and PC Controller; I have successfully removed several ghost devices.
My issue now is that I have three devices, numbered 52, 53, and 54 (one is a ghosted controller), but PC Controller shows only devices numbered up to 45, plus the current controller at 51.
True, and the secondary controller must ask the primary for the list. In PC Controller, near the end of the Controller Menu, there's a button labeled Update. That is what makes the request. Unfortunately, if the difference is large or the time since last update is large, it doesn't work and I found I had to exclude and then include the secondary again.
suck same issue.. not updating device list... luckily the device i needed to exclude which was a battery device and dead so i could not force a refresh and failure in hubitat was there and i was able to remove it.. but since i have stick plugged in i want to update the device list..
what is the option for removing a dead zwave battery device in hubitat witout leaving a ghost.. there doesnt seem to be a way>
It sucks that I run into a "does nothing" update so often. It seems to go through the motions of getting an update from the primary. But eventually I cave in and do another Include of the Secondary.
ya i couldnt get it to re-pair/include as well. tried like 10 times.. finally did a couple of extranous excludes for no good reason then got it to pair again and pull in the refreshed list.
I know people say to exclude it when done.. but i just disable the device in hubitat and have not had any issues.
Use Remove button on Z-Wave Detals page, never force remove a Z-Wave device from Devices page, as that may only get rid of the driver, effectively creating a ghost.
that is the issue no remove button.. just refresh and since it is a battery device remove never seems to show up.. is that a bug.
i was under the impression that is the way battery devices work..
and there is no choice to force remove the device on a dead battery zwave device as exclude if i am correct is not operable.. thus only option is a zwave stick?
Not a bug it's a "feature". You can't remove a node that isn't marked as failed by the radio. Unfortunately, we have no control over what gets marked as failed and stays in failed table in order for us to show the remove button. Refresh, reboot, and generally patience, would eventually force the radio to mark it failed so you can remove it.
Too late for me. After trying to remove it more than 10 times I forced a remove. Now I'm unable to re-add it again. That's a mess. Unable to remove and unable to re-add it. That's dead forever ? I tried many many times to remove and re-add.
Sure there is a ghost that will stay there forever I guess. More and more I prefer Zigbee.
I assume you mean via the Remove button for the device on the Z-Wave Details page.
Post a screen shot of the ghost from your Z-Wave Details page. If you have more than one neighbor listed for the ghost the Remove option on the Z-Wave Details page will usually fail.
If you haven't yet, reivew the approaches covered in this topic...
For future Z-Wave use you may want to move to Z-Wave LR (Long Range) devices, which don't depend on a mesh, and if they do have problems can't affect each other. However, Z-Wave LR is still very new on HE and there are still some kinks being worked out.
