Watching this thread with interest!! My Door lock is still currently paired to ST with unnecessarily complex pairing to get the events to pass through to HE. Its the other ST Yale lock - but I have an L1 and the behaviour is exactly the same so I guess when its fixed on one it will be fixed on the other.
so I was also able to successfully pair my Keyless connected now.. however - the generic Z-wave Lock driver works but not perfectly with it... so I'm going to have to stick with the ST fallback for now
The EU Keyfree connected, Keyless Connected and Conexis L1 are all very similar devices (and I'm guessing share a lot of the underlying tech).
Until the latest update, I was unable to pair my Keyfree connected properly (it would pair but there must have been some security failure as no commands would get successfully sent between the hub and the device - I must have tried to pair it nearly 50 times with this result). Since the update it now pairs correctly, and using the generic z-wave device handler lock and unlock commands work. However, unfortunately user code setting does not work correctly - it works sporadically at best.. so not good enough to use for an actual door lock.
I'm not sure if this is something you could debug without the device - if you need the device, for a ridiculous reason (I once needed a replacement, and yale sent me 2 of the wrong devices and never asked for them back) I have a spare keyfree and keyless connected lock - however they are quite heavy so I think sending them to you may be out of the question from the UK.
Thanks @mike.maxwell@simon I now have my front door lock working with Hubitat. Gives me a warm feeling to know it's no longer exposed via Samsung's cloud.
In truth, I haven't tested it failing with every update, the last time I checked was about 4 months ago - so this is something that must have been fixed without my knowledge
Hi @mike.maxwell Would you be able to add an auto-lock time of 2 minutes to the driver settings? The lock can support 2 minutes and it would be useful to be able to select it from Hubitat.
