I have a nice rule setup in my laundry room, Motion triggers on/off in combination status with sensors on doors. The switch is setup in a 4 way config, where the red series switch needing to be located in the least available/used spot. When someone is washing the dog and doesn’t hit my motion sensor, the light turns off.
Is there a way to override the rule machine rule with a double push on the GE Enbrighten add ons, or would I need to go back to the main Inovelli Red dimmer to run a scene? Is there another configuration setting/rule I should consider?
My other alternative is to get a second motion sensor to potentially better monitor the dead spot in coverage.
Thanks!
