Try setting your first delay to 6 minutes 5 seconds.
Then add up the times for the delays after.
Sorry, I guess I am not following. I think I kind of did that on the pic above with the 6:05 but I don't think you are referring to that one. Can you show a few lines of what you mean?
Do you mean change the Delay to 6:05 also?
The third line of your actions is delay 5 seconds. Make that delay 6 minutes 5 seconds. This will give the valve time to open. Wait 6 minutes and close. Then 5 seconds later station 2 should open.
Got it, I added that in the last post but I didn't explain that right. Thanks, I will try it. Makes sense.
I believe all those delays start when the action is triggered. Not after the command before it.
I could be wrong. Just thought I saw some talk on this somewhere.
I would then make the 6th line delay 21minutes 10 seconds. And so forth.
I set this up and it seems to be working. I set the min. in the station 1 device page to 10 min. It has counted down from 10 to 4, paused 5 sec. and went on to station 2. It is set to 20 min. on the device page and we will see if it goes on to station 3 at 5 min left.
The valve does expose open with a value. so in RM you can use a custom command to open the valve and pass a number that represents the number of minutes to open the valve for.
Oh wow, that will work great. Thanks, I will set up a test rule.
I think this is what you were talking about. It seems to work ok. I used "Run Custom Action". Was this the correct one to use?
Yeah, my bad, its called Custom Action now, and yes, that looks correct except for station 6 which appears to have an extra parameter
Ok, I redid valve 6 and it is like the rest. Nice catch. Thanks.
You don't need the Cancel Delayed Actions anymore.
Ok, thanks, I will remove it. Do I even need the last Delay either?
No, that can go too. The rule is done after that last valve command.
Ok, I thought so, thanks.
I tried to add this code and got this error.
unable to resolve class com.iris.protocol.zigbee.zcl.Thermostat @ line 45, column 1. unable to resolve class com.iris.protocol.zigbee.zcl.OnOff @ line 44, column 1.
Am I doing something wrong? I'm assuming this is for the old iris 12 station orbit timer.
Dave
That driver is for the iris platform it's not going to run on Hubitat.
@dave1652, Chuck created a driver for this in Hubitat so it does work very well.!!! I have two of them running well; however, beware there is a little bug that Chuck has not figured out. If this device is going through a repeater it will not reconnect if you Hubitat is rebooted or updated, a simple power cycle of the Orbit will fix the issue. If the Orbit connects directly to the hub you are 100%
I'm planning on trying this rule. I have a question though. I have a relay that turns the pump on, I'd rather not cycle the pump on and off between valve switches. Can I open the next valve before I close the previous one or will the timer not be able to handle 2 valves open at the same time.
I don't know anything about it. Sorry.
