Feature Request :
Matthew - I would like to request an additional attribute - humiditySf - (name can be whatever!)...
You provide illuminance for a raw value and Illuminated for a value with a suffix (lx). The humidity attribute comes without a suffix variation. For my dashboard tiles it would be awesome not to have to manually add... for now I'm doing it manually:
Also - more of a question really, for pressure you provide a list of measurement choices - but 'pressured' attribute isn't showing - was that the intent?
Multiple people have commented that I should remove Illuminated as it is redundant to the raw value and anyone can add the suffix if they so desire. I have left it as it has been there for a long time and removing it might break what someone is doing with that attribute. I do not plan on adding a similar setup for Humidity (or any other attribute).
'pressured' is(was?) an attribute required by some older dashboards (SharpTools.io and/or SmartTiles?) It only existed for those that wanted that attribute to populate tiles in those dashboards. Again, It has been there for a long time and removing it might break what someone is doing with that attribute.
This was posted in the Weather-Display version of this driver (required a PWS and Weather-Display software, but the OWM poll is the same).
I don't know that there are any advantages of the 3.0 key versus the 2.5 key. The 2.5 key is no longer obtainable, so new users can only get a 3.0 key. In order to get a 3.0 key they must put in a payment method that will be charged should they exceed the 1,000 calls per day 'free' limit. As far as I have been able to determine the functionality is identical. A 2.5 key will only work on the 2.5 API endpoint. It will not work on the 3.0 API endpoint. A 3.0 key will only work on the 3.0 API endpoint. It will not work on the 2.5 API endpoint.
That is disappointing. Is there any free alternative for anyone (new) just looking to get some forecast data of today? I don't want to enter payment methods like credit card details.
I'm just looking for getting the temperature of today's noon/afternoon, to determine each morning whether I should let all blinds down on time, to keep the house cool.
I am new to this and I am having API issues. I know I have a good API key because I am able to plug it into other websites and get values returned. Any help would be appreciated. I tried both the 2.5 and 3.0 API settings on the driver.
dev:62022-08-31 11:37:17.370 am warnOpenWeatherMap.org Weather Driver - WARNING: 401:Unauthorized
dev:62022-08-31 11:37:17.368 am warnOpenWeatherMap.org Weather Driver - WARNING: Calling https://api.openweathermap.org/data/2.5/onecall?lat=39.833330&lon=-98.585522&exclude=minutely,hourly&mode=json&units=imperial&appid=[API]
dev:62022-08-31 11:37:17.366 am infoOpenWeatherMap.org Weather Driver - INFO: Polling OpenWeatherMap.org
dev:62022-08-31 11:37:17.066 am infoOpenWeatherMap.org Weather Driver - INFO: Poll OpenWeatherMap.org: [uri:https://api.openweathermap.org/data/2.5/onecall?lat=39.833330&
Unauthorized. The OWM API is not accepting your API. I took the URL provide in your error logs and plugged in my API and it returned data, so a valid API does work. Make sure your API is an OWM OneCall API. I know they offer other API services, but this driver uses only the legacy OneCall 2.5 API or the current OneCall 3.0 API.
I've been using your driver for a while, i stayed on an old version (because i edited it to remove the bottom banner/icon so the threedayfcstTile would fit on a 2x3 dashboard tile) -- i think i was on version 0.5.3, maybe 0.5.2--
So I just updated to 0.6.2 and the 'cloud' attribute is not behaving the same. I have RMs that compare cloud attribute, and they all show null in the rule and show ? in the edit conditions page.
I dont see anything interesting in the changelog-
Is there a different way to see how cloudy it is right now?
I've recently moved from Smarthing Webcore to Hubitat Webcore. Most everything has gone smoothly, but I'm deeply struggling with weather. I registered for API key ith OpenWeatherMap. I've added that key within the settings of Hubitat Webcore. (I also haveWebcore Storage installed.) I also went to git hub and retrieved the OpenWeatherMap-Alerts-Weather-Driver and pasted that into Hubitat as a driver code. Then, I created a virtual device named Weather and assigned it to use the new driver above. I'm able to see all of the settings for this device...I entered API key again, setup all my preferences, and it pulled in all of the Current weather, so I thought all was well. However, none of the states have updated since even though I have the External Source Poll Interval set for hourly. To troublehoost, I have pressed the "Save Preference" button and "Save Device" button and rebooted my hub on three separate occasions. However, none of the weather stats being displayed are updated. What am I missing?
This is your issue. OWM is not accepting your API Key as valid. Do you have a legacy OneCall 2.5 API Key, or do you have a recently acquired OneCall 3.0 API Key? You have the driver set to use the Legacy OneCall 2.5 API Key. If you have a recently acquired OneCall 3.0 API Key you need to change the setting in the driver to use the 3.0 API Key.
That was it! It seems to be working now. Thanks for your help with that. It defaulted to 2.5, and when I registered for the API, it wasn't clear to me which version I was registering for. Many thanks!
Hi, I'm a bit new here. I'm moving from SmartThings to Hubitat so I have a lot of gaps. Did I set up my OpenWeatherMap-Alerts-Weather-Driver correctly?
This is what I did:
Install the Driver using HPM
Add a virtual device called Open Weather Map
Add the virtual driver called OpenWeatherMap
Registered and obtained a free key from Open Weather Map
Put in my Key
Competed all the remaining Preferences
Save everything
I waited about hour or so then pushed the refresh button
"Current States" appears as follows:
city : New Toronto
cloudiness : 100
country : CA
humidity : 87
pressure : 1018
temperature : 18
weather : overcast clouds
weatherIcons : 04d
windDirection : 133
windspeed : 0.89
Just wonder why I don't see "Feelslike"? or other attrubutes?
