Anyone having trouble with the OWM driver status not updating? It literally only updates for me when I go into the driver page and hit the refresh button.
Mike
Mike
I had the same experience.
I switched to this:
Same here, I also switched to apixu a few days ago.
I set just up a rule to refresh OWM every 5 minutes.
Thanks for the fix idea. I'd like to see the driver do that on it's own but if that's not how it was intended to work I guess this will do in a pinch. I'd never used the PERIODIC trigger before.
Mike
I tried that back when I was trying OWM. It didn't seem to work.
It's been working fine for me the last two weeks or so. What didn't work for you?
It just never seemed to update even though I made a rule to refresh every 5 minutes.
Not a big deal for me as I'm happy with my APIxu integration.
I might have to try that one too...lots of people seem to be having good results
Your periodic trigger tells it to update on the 5th minute of each hour. There's another setting somewhere to say update every x minutes. I'm not at home so can't screenshot my rule, but I'll post it when I get home later.
They don't update the data store it pulls continuously, they officially state, data update < 2 hours. So polling every 5 minutes is just wasting cycles. to get <10 minutes is big bucks.
See this page: https://openweathermap.org/price
The free account allows for 1 call per second. Sure the data isn't refreshed that often, but calling every few minutes is well within the limits and ensures that once the data is updated, we get it in HE fairly quickly. I don't see any issues with refreshing every 5 minutes.
I get it that it happens once an hour but this is what the selection looks like.
Mike
Where it says Each selected minute...you pick which minute of the hour you want it to refresh on. If you want it to refresh at 1:30, 2:30, 3:30, etc you would pick 30. If you want it to refresh at 1:15, 1:45, 2:15, 2:45, 3:15, 3:45, you would pick 15 and 45. You picked 5, so it will refresh at 1:05, 2:05, 3:05, 4:05, etc.
Again, there's another option in there somewhere (might be under a different trigger even, I can't remember off the top of my head) where you can tell it to refresh every x minutes. Alternatively, you could use your existing periodic trigger and select 0, 5, 10, 15, 20, 25, 30, etc to get a refresh every 5 minutes.
hmm, I don't get the "Every n minutes?" Slide switch when I pick periodic as a trigger. The screen shot I posted shows that. But, I'm caring less and less by n-minutes now that I know once an hour is good enough. Thanks all for the suggestions and information.
Mike
Alright I couldn't let it go. I remade my rule for an hour instead of 5 minutes. The slider appears when you make a new rule, but does not present when you try to edit the rule later.
Mike
