Here we go again...
Still testing so I donβt want to say everything is fixed yet but definitely seeing an improvement on the first couple of things I tested.
And Iβd much rather have the team kicking out updates quickly in an agile fashion then holding everything waiting to ensure they had addressed 100% of the issues so Iβm not complaining about getting another update 24-hrs from the last one.
I agree completely. Keep 'em coming!
Do you have the zwave poller running?
He's not the only one. Here's my C7, running today's update, no polling. Hub is sending out constant Busy Zwave network messages...
I have a ghost device in my Zwave Details device list, evidently a relic of a failed inclusion, that is likely the cause of my issues according to staff.
No zwave repair isn't running. I have a bunch of ghost devices I can't get rid of.
Is there anyone who has successfully removed C7 ghosts via the "PC Controller" route? Can you do it with a Z-Stick/UZB-3 or do you need a UZB-7 (or any other 700 series stick)?
Same. 10 second interval on mine.
sys:12020-08-26 08:35:10.645 am warn Z-Wave Network responded with Busy message.
sys:12020-08-26 08:35:00.714 am warn Z-Wave Network responded with Busy message.
sys:12020-08-26 08:34:50.605 am warn Z-Wave Network responded with Busy message.
sys:12020-08-26 08:34:40.684 am warn Z-Wave Network responded with Busy message.
sys:12020-08-26 08:34:30.584 am warn Z-Wave Network responded with Busy message.
Do you have a ghost node?
Just wanted to chime in, also seeing ghost nodes and network busy in the middle of the night, when network should be anything but busy
Sorry, should have said. Yes, and I am unable to remove it under 2.2.3.135 despite various attempts and cold restarts.
I got rid of 3 with a uzb-7 but just about any stick will work.
I got the same "Z-Wave network busy situation after updating to 2.2.3.135 on my C-7 - not immediately, it did work normally for several hours first. I'd not yet seen this under earlier software versions.
I shut down the hub and removed power for 30 seconds, and it's been working without problems since then, probably for 8-9 hours. Despite some issues with inclusion the C-7 has mostly worked ok for me so far, so I'm hoping this doesn't return. I have had ghost devices in the past but I think I'd successfully removed them all before this update.
I haven't tried a full-network repair even though most of the devices are plain Z-Wave (not Plus) - not sure if it will make things better or worse. I have repaired a handful of individual devices which were showing as "FAILED" though I suspect they would have been fine without.
On the inclusion front I still can't include a Leviton DZPD3-2BW. I still need to test a couple of fibaro contact sensors which tried to include but never quite made it under .118 and .119 (these failure were probably the source of most ghost devices)
I had a precisely 2 minute time window between the initialization log lines following a cold restart and the first "Z-Wave Network responded with Busy message" line appearing.
That's cool - I've used the Z-Stick with my C4's and it's worked well. I might need it (and or the UZB-7) for my C7 work today.. thanks
I am also getting the network busy errors, again, after upgrading and letting the system run for a couple of hours.
How do I check if I have ghost nodes? Would node 006 in the screenshot be an example?
If using "Remove" does not work on it then likely yes.
But if "Remove" does work, doesn't that mean I just removed a legitimate node meaning a device was removed?
