I have this switch and when I saw that it was a new driver, I tried to change it. I was using a community driver before.
I can't get it to work under the Nue driver. I tried to reset and re-add the Nue and it came up as a generic zigbee outlet. Well not an outlet? It works so no big complaints here but just wondering if something went wrong somewhere?
I think there are several different versions of this device, some of them vastly different in the way work zigbee wise. The drivers were written for the current production firmware.
Actually, @mike.maxwell, I didnt realise that there was a specific driver called "Nue zigbee switch". I re-paired it this morning, and it auto assigned to generic zigbee switch, and the status wasnt working. However, after seeing this thread, I went and found the Nue driver, and it's all working.
Thank mate.
FYI, I have an old version. So it's working for the previous generation too. Only tested 1 gang so far. Muchos gracios.
I just switched over the driver, without re-pairing, and it's working well. I know @mike.maxwell said we should re-pair them, but it seems to be working with a simple driver change.
I've had one of my single gang switches fall off the zigbee network (a few days in a row). The last hope RSSI is -77.
Before your driver, I had to refresh these devices to keep them on the network, usually once an hour. I went to make a rule, but I cant select "refresh" for these devices? It's listed as an attribute in the device page, but not selectable under Rule Machine (for refresh). I used custom action, and got around it.
Most of the time they work well. I just had a 3 gang fall off the network this week. But I am having zigbee issues at present, and it could be related to that.
Bit confused - are the Nue native drivers replacing the "HUI Zigbee Wall Switch" community drivers? Are Nue Zigbee switches called: HGZB-41-US (for example)?
